Grinding noise after replacing brake pads
+ Reply to Thread
Results 1 to 9 of 9
Thread: Grinding noise after replacing brake pads
  1. #1
    jrevans122
    Guest
    Default Grinding noise after replacing brake pads
    Had the Honda dealer replace my brake pads while I had him mounting the tires this weekend. Now there is a terrible grinding noise coming from the front wheel. I assume that it's the new pads. What could be causing such a racket? I used the OEM pads.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Member
    Join Date
    Mar 2010
    Location
    BOCA RATON FLORIDA
    Posts
    64
    Default
    Had the same problem on my 1300. I replaced them myself and thought I messed up. Apparrently this is normal. I beveled the leading edge of the pads and most of the noise went away. My new 1800 with 200 miles on it has brake noise but not that bad. As long as it stops all is good. Good luck.
  4. #3
    Senior Member fastspek's Avatar
    Join Date
    Jan 2006
    Location
    Belgium(Europe)
    Posts
    1,161
    Default
    Quote Originally Posted by jrevans122 View Post
    Terrible grinding is not normal but some noise is, so return to the dealer.
    My further advice:
    1) Buy or download service manual
    2) Next time take your wheel off and bring it to the dealer for tire replacement only
    3) Reinstall the wheel yourself and if necessary do the brake pad replacement
    4) Take a look at www.bareasschoppers.com for more information
    2003 VTX 1800C (forever)
    2002 HD FLSTF since 07/2008
    " Today you raised more questions than giving answers "
  5. #4
    Senior Member ToMang07's Avatar
    Join Date
    Jul 2009
    Location
    Maine - CAVEO ADSUM!
    Posts
    3,206
    Default
    Quote Originally Posted by fastspek View Post
    My further advice:
    4) Take a look at www.bareaschoppers.com for more information
    Bikeless...
    Want AMSOIL? PM ME! (Local P/U)
  6. #5
    Senior Member mark_1bx's Avatar
    Join Date
    Oct 2004
    Location
    IL
    Posts
    8,540
    Default
    I wouldn't assume that the grinding noise is normal.
    I also wouldn't assume that the dealer did the job correctly.
    I've seen many a bikes with improperly aligned front wheels. I have also seen brakes installed by the dealer done incorrectly. If you don't know how to do it yourself or have some else that can help you, then your either live with it or take it back to the stealer and hope they get it right this time.
    M STAR KMA
  7. #6
    jrevans122
    Guest
    Thanks for the replies. Turns out the dealer (stealer) installed front tire incorrectly. I checked the position of the tire on the left side and the spacing was incorrect. I put it up on the jack, and corrected the spacing myself. Now the noise is gone. It's a shame that someone would bill $85 an hour for labor and do such a crappy job.
  8. #7
    Senior Member ELLWEL's Avatar
    Join Date
    Feb 2010
    Location
    Southampton New Jersey
    Posts
    206
    Default Noise from day one
    I have had that same noise from the day i got the bike
  9. #8
    Member
    Join Date
    Jun 2008
    Location
    Rochester, NY
    Posts
    62
    Default
    I had the same noise after I had removed the front brake pads for inspection.
    When I removed the removed the pads a second time, I found that I had not fitted the tip of pads correctly into the caliper the first time. I checked the end of the pad opposite the retaining pin end and I saw where the rubbing had occurred. The retaining pin fit correctly but the tip end had missed its locator slot. When I fitted the pads correctly, the noise disappeared.
    If you don't fix the problem, the noise will go away as the edge of the brake pad will be worn away by the brake disk mounting bracket.
    If you're luggin, you're crudin.
  10. #9
    Senior Member twin1300's Avatar
    Join Date
    Feb 2006
    Location
    Denham Springs, LA
    Posts
    4,993
    Default
    There shouldn't be any grinding noise. The tolerances are tight for the caliper and sometimes the caliper isn't centered correctly and the housing can rub the rotor!
    .....................twin
    In HIS Service...........twin
    http://mcdarksiders.forumotion.com/forum.htm
    ****Anti-Aardvark Crusader!!!*****
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
