How to change oil and filter
+ Reply to Thread
Results 1 to 11 of 11
Thread: How to change oil and filter
  1. #1
    Default How to change oil and filter
    Hello Gents,
    My 2007 VTX 1300 R has 7000 miles on it. Last time the oil was change at 800 miles and was done by the dealer.
    Is there a step-by-step instruction to change oil and filter?
    Also please suggest if what oil / filter to be bought.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member Pork Chop ...'s Avatar
    Join Date
    May 2009
    Location
    St. Paul . Minnesota ......
    Posts
    683
    Default
    http://www.bareasschoppers.com/
    Look on the left side of the page.......
    2008 1800T - Spec 1 - Two-tone Black ,Candy Black Cherry - Honda Light Bar - Cobra Tach - Cobra Fatty's - Ulimate Big Boy - 10-40 Amsoil - 75-90 Amsoil - Metzeler's .....
  4. #3
    Join Date
    Dec 2006
    Location
    gulf breeze, fl.
    Posts
    109
    Default Oil Change
    1. Run the engine a few minutes. 2. Place 5 quart oil holder under bike(About 3 bucks from Wally World). 3. 16mm socket to unscrew oil plugs(2 of them-1 under bike and 1 lower left side of engine. 4. Unscrew and keep and eye on the crush washers. When stops dripping slide the container back and unscrew the filter. 5. Put everything back in you just took out and don't over tighten. 6. Pour 4 qts. in the engine. When the last qt. starts to drip when pouring, stop, you're real close to 3.9.
    You'll get a bunch of advice on types of filters and oil. I use Honda and with 36,000 on my 06 it doesn't use a drop, so I think I'll just keep that routine. Honda says 8000 between changes. To me that's a stretch so I change every 4000. ooops, everything back you took out means a new filter. Good luck.
  5. #4
    Senior Member dan3's Avatar
    Join Date
    Aug 2006
    Location
    MD burbs of Baltimore and DC
    Posts
    12,693
    Default
    Quote Originally Posted by Pork Chop ... View Post
    That's a very good link. Also if you have the manual it has a step by step.
    Dan
  6. #5
    Senior Member JOSHWALEE's Avatar
    Join Date
    Feb 2010
    Location
    MT. SERBAL
    Posts
    2,901
    Default
    Quote Originally Posted by bike jib View Post
    Except I do 5k intervals with full synthetic. The engine, trans, and clutch all operate in this fluid and I ride the he[[ out of it. Just gives me piece of mind. I haven't sent it out for analysis or anything.
    entia non sunt multiplicanda praeter necessitatem
    support your
    LOCAL 81
  7. #6
    Member sprocketz's Avatar
    Join Date
    Apr 2010
    Location
    Appleton, WI
    Posts
    75
    Default
    I would also recomend reading Tappers oil article in the "how to, step by step" section for what kind of oil to use. Most people seem to go with either Mobile 1 or Amsoil.
    For oil filters... I go with Purolator PL14610 PureONE oil filter because I have gotten feedback from some pretty experienced people both motorcylce and otherwise who think Purolator makes great filters, but there are other good filters out there as well, but stay away from Fram filters for sure. I think there is some stuff on the "how to, step by step" section as well on oil filters.
  8. #7
    Senior Member oasysco's Avatar
    Join Date
    May 2007
    Location
    Newport News, VA
    Posts
    4,956
    Default
    Quote Originally Posted by Bulletman View Post
    Hello Gents,
    Any Honda MC dealer can sell you the right filter.
    Greg in SE Virginia
    2000 Harley UC
    Gone, but not forgotten: VTX1300S, VTX1800C, Aero 750 (couch on wheels)
  9. #8
    Member Knuddy's Avatar
    Join Date
    May 2009
    Location
    Oceanside CA
    Posts
    35
    Default Oil Change
    When draining your oil just get an aluminum turkey pan from Walmart. Slips right under and when your done you can put the old oil in the containers that you got with the new oil. Most automotive shops will accept your old oil for recycling.
    As for the throwaway pan put it in a plastic bag and your all set for the next oil change.
    Don't forget to use new crush gaskets.
  10. #9
    Default Ocassionally Bike does not start
    My 2007 VTX 1300 R does not start some times. The battery is not the problem. Even when I tried to jump it, the bike does not start.
    I have checked the pet-cock, choke, etc. and they look okay. Couple of times it started with choke on but died in a minute. COuld this be a carb problem??
    I am not an expert and scared to touch the carb. Could some one give me some tips to fix the issue?
    Thanks.
  11. #10
    Old Goat TennX's Avatar
    Join Date
    Jul 2006
    Location
    Memphis,Tn.
    Posts
    21,748
    Default
    With all due respect get a manual either hard copy or disc , with it and this forum you will get miles O smiles. good luck
    I Was ......
    Phil "I should be riding" Ford
    06 CBC 1300R Darkside/Foots
    "Have You Hugged Your Dog Today"
    R.I.P. Buddie 2003 - 2015
  12. #11
    Join Date
    Nov 2003
    Location
    RI
    Posts
    15,774
    Default
    Does it turn over but not fire...or just not turn over.
    Have you checked to see if your bike is on the recall list for the petcock problem.
    Make : HONDA Model : VTX1300 Year : 2007
    Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Mfr's Report Date : MAR 25, 2008
    NHTSA CAMPAIGN ID Number : 08V141000 N/A
    NHTSA Action Number: N/A
    Component: FUEL SYSTEM, GASOLINE DELIVERY
    Potential Number Of Units Affected : 38934
    Summary:
    HONDA IS RECALLING 38,934 MY 2006-2007 VT600 AND MY 2007-2008 VT750 AND VTX1300 MOTORCYCLES. THE MOTORCYCLES MAY HAVE AN IMPROPERLY MANUFACTURED FUEL CONTROL VALVE DIAPHRAGM AND THE FUEL VALVE MAY DRIP FUEL.
    Consequence:
    IN THE PRESENCE OF AN IGNITION SOURCE, DRIPPING FUEL POSES THE RISK OF FIRE.
    Remedy:
    DEALERS WILL REPLACE THE FUEL CONTROL VALVE DIAPHRAGM ASSEMBLY, FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON OR ABOUT APRIL 10, 2008. OWNERS MAY CONTACT HONDA AT 1-866-784-1870.
    Notes:
    HONDA RECALL NO. Q75. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
    http://www.vtxoa.com/forums/signaturepics/sigpic173_1.gif
    '04 1300 C, black, RIP
    '04 1300 C, orange, for now
    shut up and ride
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
