A/F screw
+ Reply to Thread
Results 1 to 8 of 8
Thread: A/F screw
  1. #1
    Senior Member mightywarrior72's Avatar
    Join Date
    Apr 2010
    Location
    Long Beach, Ca.
    Posts
    1,347
    Default A/F screw
    Sorry for the novice question. Where is the A/F screw on my 05 13R?? Running a bit rich.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member Pork Rind's Avatar
    Join Date
    May 2008
    Location
    Montpelier, Oh - N/W Ohio
    Posts
    437
    Default
    Quote Originally Posted by mightywarrior72 View Post
    If it is the same as 07 which I'm pretty sure it is under the airbox, search the tech forms, you have to remove the gas tank. Unless someone beats me to it I try and post a pic.
    2007 1300 R Black Cherry--1800 FD,Big Bike Driving lights,Memphis Shades Big Shot,NC Paladin Engine Guard,Honda Back Rest + Luggage Rack,Willie & Max Saddlebags,Roadhouse Slip ons,Mustang Seat & Desmoged
    [SIGPIC][/SIGPIC]
  4. #3
    Senior Member Gumbo820's Avatar
    Join Date
    Nov 2008
    Location
    Spring, TX
    Posts
    539
    Default
    under the carb, if you lay down look up you will see it, very hard to get to but it can be done. I installed Glens tool it works very well. Do you have a tool to adjust with?
    2007 VTX 1300R / 2006 VTX 1800R
    "The moment you taste it, something wet and dark leaps on you and starts humping you like a swamp dog in heat, and the only way to get it off you is to eat it off, It's Gumbo!! If you don't eat it then the mystery beast will go right on humping you."
  5. #4
    Supporting Vendor dearsleigher's Avatar
    Join Date
    Oct 2006
    Location
    Chicagoland
    Posts
    1,261
    Default
    Some info and pics in the link below.
    http://www.vtxcafe.com/showthread.php?t=15732
    Glens VTX Garage Blinker Bar (driving lights not included)
  6. #5
    Join Date
    Nov 2008
    Location
    Spring, TX
    Posts
    539
    Default
    Quote Originally Posted by Gumbo820 View Post
  7. #6
    Senior Member Pfalzy's Avatar
    Join Date
    Oct 2009
    Location
    Fond du Lac, WI
    Posts
    409
    Default
    I recommend Glen's permanent mount adjustment tool. That way you only have to take everything apart once.
  8. #7
    Senior Member Donut's Avatar
    Join Date
    Jan 2005
    Location
    Coloma, Mi. MixRider Member
    Posts
    6,144
    Default
    Quote Originally Posted by Pfalzy View Post
    +1 It is really hard to adjust it the way Honda has it set up. Glen's A/F makes it simple to adjust.
    Why do you think you are running rich. If you are using the choke/enriches then your plugs will look like you are running rich. But you are most likely running lean on the A/F, it should be set at 2.5 turns. The factory sets the A/F lean to pass EPA so you have to use the Choke/Enhancer which dumps lots of fuel in to foul the plugs. With the A/F set at 2.5 you will only have to twist the throttle a couple of times and rarely have to use the choke and it will worm up quickly.
    Doud
    Donut Doug
  9. #8
    Senior Member JOSHWALEE's Avatar
    Join Date
    Feb 2010
    Location
    MT. SERBAL
    Posts
    2,901
    Default
    Ah... 2.5.
    Word of advice MightyWarrior... 2.5 is not a magic number.
    Set it properly. It may end up around 2.5 or it may not, but knowing is better than guessing.
    entia non sunt multiplicanda praeter necessitatem
    support your
    LOCAL 81
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
