Headlight adjustment???
+ Reply to Thread
Results 1 to 4 of 4
Thread: Headlight adjustment???
  1. #1
    Junior Member
    Join Date
    Apr 2010
    Posts
    21
    Default Headlight adjustment???
    I was riding my 02 vtx 1800c the other night and i noticed that the headlight points way to low. I didn't notice in the city with all the other lights around but in the country holy crap!! I had to leave my brights on just to make it home. I thought i could simply just raise it up a little bit but of course there is no adjustment at least from what i can see. Has anyone run into this? Or has anyone found a fix? Thanks!
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    Jun 2009
    Location
    Garland, TX
    Posts
    787
    Default
    two holes on the underside of the headlight housing. When facing the headlight, the hole on the right is the vertical adjustment. Left hole is horizontal. You need a small flat head driver. Use a flashlight and look up in there and you can see the adjustment screws.
    George
    2006 1800R3 Titanium/Black Progressive 440HD, L&R forwards, Phatriser II's, Tsukayu VTX bags, Cobra Speedster Longs
    "There's a fine line between genius and insanity. I have erased this line.."
  4. #3
    Senior Member Tejas_Ranger's Avatar
    Join Date
    Mar 2004
    Location
    NE Oklahoma
    Posts
    2,892
    Default
    Quote Originally Posted by wisuperhawk View Post
    • Motorcycle Headlight Aiming
      Getting a correctly aimed headlight is straightforward. You need to make a couple of measurements and then aim the light at a flat wall, as follows:
      With the bike on its wheels and you astride, have a helper measure the distance from the floor to the center of the headlight lens.
      Pick a flat wall where you can locate the bike so the headlight is 17 feet from the wall. Place a horizontal mark on the wall two (2) inches lower than the height of the center of the headlight.
      The headlight beam (on low beam) should be relatively flat on the top, and may rise rather sharply at the right edge. Adjust the headlight vertically so that the flat top of the beam is just up to that line (marked two inches down at 17 feet).
      Horizontal adjustment should center the beam ahead of the line of the bike.
    Quote Originally Posted by GOG View Post
    I thought it was a small phillips but either screw driver may work. One other thing to keep in mind, sometimes the adjustment screws don't work. You may have to take the headlamp out of it's housing to adjust the metal parts that the screws are supposed to adjust to free the parts up so that the screws will move the headlamp like it's supposed to once it's back in the headlamp and bolted up.
    Tejas
  5. #4
    Junior Member
    Join Date
    Apr 2010
    Posts
    21
    Default
    Sounds good thanks! I'll try it tomorrow morning.
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
