my vtx 1300 won't start
+ Reply to Thread
Results 1 to 21 of 21
Thread: my vtx 1300 won't start
  1. #1
    Junior Member ronjr74's Avatar
    Join Date
    Feb 2009
    Location
    wausau, wi
    Posts
    11
    Default my vtx 1300 won't start
    if someone could please help me my vtx 1300r wont start,just a single click. battery new power to the starter when u hit starter swich. i lost my mind!!!
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member arcangel455's Avatar
    Join Date
    Mar 2010
    Location
    Windham, ME
    Posts
    370
    Default
    Quote Originally Posted by ronjr74 View Post
    I would start by checking the battery connections to make sure that they are tight.
    Also you stated that the battery is new? How new? I ask because I know some batterys that are bought new need to be charged before you can use them.
    Last but not least ( and I doubt this is the problem) your starter switch may be on its way out.
    Give these ideas a check and let us know where your at. With all the smart people on this site im sure we will have you back up and running in no time.
    The journey begins by getting on the bike!
  4. #3
    Join Date
    Feb 2009
    Location
    wausau, wi
    Posts
    11
    Default
    well the battery is new and charged it before i put it in, the starter switch seems to be fine i just not sure about the relay, four wires in and one wire is very dim when you hit the starter switch.
  5. #4
    Join Date
    Nov 2003
    Location
    RI
    Posts
    15,774
    Default
    kickstand up?
    killswitch to run?
    http://www.vtxoa.com/forums/signaturepics/sigpic173_1.gif
    '04 1300 C, black, RIP
    '04 1300 C, orange, for now
    shut up and ride
  6. #5
    Join Date
    Feb 2009
    Location
    wausau, wi
    Posts
    11
    Default
    ya i think i tried all the dumb moves but keep them coming i might have missed one
  7. #6
    Senior Member cruiser7734's Avatar
    Join Date
    Mar 2008
    Location
    Haines City fl
    Posts
    762
    Default
    Check fuses
  8. #7
    Super Moderator mneccspv's Avatar
    Join Date
    Feb 2009
    Location
    Portland, TN
    Posts
    1,312
    Default wont start
    Try running hot lead diretly to starter to make sure it is working.
  9. #8
    Join Date
    Nov 2003
    Location
    RI
    Posts
    15,774
    Default
    you can jump across the 2 terminals at the starter relay and see if that works. If so, you have a problem with one of the safeties or start button.
    Make sure you are in neutral for this test as the bike absolutely will roll off on you if in gear.
    Also, a new battery can be bad.
    shut up and ride
  10. #9
    Join Date
    Feb 2009
    Location
    wausau, wi
    Posts
    11
    Default
    i jumped by the starter relay and nothing. i suppose that means starter is out?
  11. #10
    Join Date
    Feb 2009
    Location
    wausau, wi
    Posts
    11
    Default
    plus there is no draw on battery, battery stays at 12.54 even when i hit the starter switch
  12. #11
    Join Date
    Nov 2003
    Location
    RI
    Posts
    15,774
    Default
    maybe a bad ground cable? or the other end of it loose from the block?
    shut up and ride
  13. #12
    Senior Member gulliverstoe's Avatar
    Join Date
    Nov 2008
    Location
    Tucson
    Posts
    1,307
    Default
    how's the headlight?
    it sounds like you were good and just replaced the battery and now dead-skees.
    Too young to be where I am going
    but too old to go back again
    2008 Honda X 13T- Gone Feb 2010
    2010 Vic X Country
  14. #13
    Senior Member jamieP's Avatar
    Join Date
    Jun 2007
    Posts
    988
    Default
    New battery in known good bike. now doesn't work. I highly suspect battery.
    Upstate SC.
  15. #14
    Senior Member JOSHWALEE's Avatar
    Join Date
    Feb 2010
    Location
    MT. SERBAL
    Posts
    2,901
    Default
    Quote Originally Posted by jamieP View Post
    entia non sunt multiplicanda praeter necessitatem
    support your
    LOCAL 81
  16. #15
    Senior Member Donut's Avatar
    Join Date
    Jan 2005
    Location
    Coloma, Mi. MixRider Member
    Posts
    6,013
    Default
    I've been threw this over the years and putting a new battery didn't help.
    Three weeks ago I went threw all my wiring and checked everything. Since I did the below instructions I have not had any problems since.
    There are times when there is corrosion/oxidation and you cant even see it.
    First the charging system on you're bike is most likely OK. There is rarely any problem's with the system.
    I'd go back and clean the end of the cables on top and bottom of the connector and the battery post on the battery with a wire brush or better yet a Dremmel (with wire-brush) and also the threads on the battery bolt. Then add a lock washer (not a star washer) under the bolt head) to keep it tight. Then coat everything with Vaseline to prevent corrosion and oxidation. Also remove the left bottom cover below the Key and tighten the battery ground that is to the right of the shift pivot point, Its a 10MM. Mine was a little loose. A poor ground or week connection will draw a lot more current when under load. tightening with a screwdriver is not good enough, use a wrench or socket. Be careful and don't try to be superman, watch closely because you can brake the terminals off the battery.
    Donut
    Donut Doug
  17. #16
    Join Date
    Feb 2010
    Location
    MT. SERBAL
    Posts
    2,901
    Default
    Quote Originally Posted by donut View Post
    Donut
    Wow, you've got that copy and paste function down!
    support your
    LOCAL 81
  18. #17
    Join Date
    Jan 2005
    Location
    Posts
    6,013
    Default
    Yep! Copy and past works real good. Most of the time that is where the problem is. And when it done it eliminates a lot of guessing. I almost replaced my Starter and Solenoid because my symptoms were looking like they were bad. Now all my starting problems were fixes. Its a lot cheaper than replacing good battery's.
    Corrosion and oxidation can cause unseen problems. The battery ground has been known to be loose.
    Donut
    Donut Doug
  19. #18
    Join Date
    Jan 2005
    Location
    Posts
    6,013
    Default
    JOSHWALLE "Wow, you've got that copy and paste function down!"
    If it helps some dose it really matter.
    Donut
    Donut Doug
  20. #19
    Join Date
    Feb 2010
    Location
    MT. SERBAL
    Posts
    2,901
    Default
    Relax Donut... I'm just poking at the bear.
    support your
    LOCAL 81
  21. #20
    Join Date
    Jan 2010
    Location
    southern calif
    Posts
    1,205
    Default "new" batteries are often old from setting in an wharehouse
    for months+. The way batteries are made is very revealing. Back in 1981,I audited the Gould battery plant in Kankakee,Il and the big,big $$ batteries for both nuclear power plant emergency generators and for submarines are super units as well they must be. I observed a man sweeping up some of the spilled lead and saw him toss this into a barrel. When I inquired,I was told,"that stuff goes down the road to the "car" battery plant as they use much cheaper or "contaminated"(the sweepings I saw)stuff. If the voltage isn't dropping when you hit the starter,no connection is being made for whatever reason. These guys are all steering you in the right direction and keep listening to them.
  22. #21
    Join Date
    Feb 2009
    Location
    Portland, TN
    Posts
    1,312
    Default wont start
    is power getting to the relay? you did check the fuse right?
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
