Turn Signal Problem
+ Reply to Thread
Results 1 to 8 of 8
Thread: Turn Signal Problem
  1. #1
    Senior Member tlfuller's Avatar
    Join Date
    Jan 2004
    Location
    Fort Worth, Texas
    Posts
    412
    Default Turn Signal Problem
    I'm having a turn signal problem.
    Let me start by giving some particulars. 03 1800R, Kuryakyn R/T/B and headlight modulator.
    The turn signals are working but when they are on they blink erratically. They will blink normal then all of a sudden they blink very fast, then normal then fast.
    Any ideas?
    2010 Victory Cross Country, 03 VTX1800R, 04 AERO
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    Jan 2004
    Location
    Fort Worth, Texas
    Posts
    412
    Default
    bump
  4. #3
    Join Date
    Apr 2005
    Location
    New Hampshire
    Posts
    3,421
    Default
    I know they shouldn't have anything to do with each other, but try disconnecting the headlight modulator and see if it makes a difference. Just something to try.
    On a side note, I know a local that has this and his signals are not led, there was something that he had to take off, a jumper or something like that, if not it would act weird and then the fuse would pop. It has to do with LED bulbs, helps it so they don't flash fast, I can find out what it was if you can't find anything else on it.
    IF YOU ARE GOING TO BE DUMB, YOU BETTER BE TOUGH! 2003 1800C BLACK & DARKSIDE!
  5. #4
    Senior Member CRUZR's Avatar
    Join Date
    Jul 2004
    Location
    Seattle, WA USA (actually Tukwila)
    Posts
    2,439
    Default
    Why do you mention the headlight modulator?
    What kind of lights do you have in your blinkers?
    Does the RTB come with an Electronic Flasher built in?
    I have a '03 1800 S and have led blinkers and needed to add an electronic flasher so the blinkers would blink correctly.
    Gary
    Gary Scherler aka "CRUZR" at
    www.scherler.com
    '03 VTX 1800 S
    Click the pic to go to my web site.
  6. #5
    Default
    Quote Originally Posted by tlfuller View Post
    Any ideas?
    That is pretty strange. Have you looked to see if when they speed up that both are still working, front and back?
    How long has the unit worked? Or did you just install it?
    Changed any bulbs recently? To LED maybe?
    Almost sounds like the flasher has gone bonkers.
  7. #6
    Senior Member X'N's Avatar
    Join Date
    Apr 2006
    Location
    MN
    Posts
    10,507
    Default
    I've had problems with older bikes when the flasher got worn out it would do things like that. Also in some in some cases when the RTB module is installed it will isolate the load of the rear turnsignals thus by making the flash rate increase. if a load eq is not installed. It also sounds like you could have a bad connection some where.
    Headlight modulator should have no bearing on the operation of your turnsignals unless you did some funky wiring.
    2012 Victory Cross country
    http://www.vtxoa.com/forums/attachment.php?attachmentid=75391&d=1342403272
  8. #7
    815wanggaoshu
    Guest
    Default
    Sehr cooles Motorrad
  9. #8
    Senior Member fubar606's Avatar
    Join Date
    Jul 2005
    Location
    Endicott WA.
    Posts
    677
    Default
    Quote Originally Posted by 815wanggaoshu View Post
    WHAT ?
    life is sexuality transmitted and ALWAYS fatal
    Double Dark
    2002 vtx 1800 C silver (the faster )color
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
