Dyna Beads
+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 30 of 81
Thread: Dyna Beads
  1. #1
    Senior Member dbass's Avatar
    Join Date
    Aug 2010
    Location
    Bartow-Florida
    Posts
    932
    Default Dyna Beads
    Okay with so much mixed talk about the beads I did a little web search and found a world of arguments for and against Dyna Beads. One web review they said they tested the beads using a high speed balancing machine and the beads failed every time.
    Now some supporters of dyna beads that have seen this test claim you canít use a balance machine to test dyna beads, not sure why.
    So how do you know for sure they are working if you can use a balance machine?
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member ToMang07's Avatar
    Join Date
    Jul 2009
    Location
    Maine - CAVEO ADSUM!
    Posts
    3,214
    Default
    Quote Originally Posted by dbass View Post
    Here's testing for ya, I have had it up to 120mph w/ dynabeads and no wobble/shake!
    Bikeless...
    Want AMSOIL? PM ME! (Local P/U)
  4. #3
    Senior Member surfshrink's Avatar
    Join Date
    Oct 2007
    Location
    SW Missouri
    Posts
    2,640
    Default
    All I know is that since I started using them, my front no longer shakes, my ride is much smoother, and my tires are lasting significantly longer. No scientific research here, just anecdotal evidence.
    AN ATTITUDE OF GRATITUDE! Thank you, Jesus. (I am amazed at the grace and patience you have shown.)
    Silver 2005 VTX1300S
  5. #4
    Senior Member scup's Avatar
    Join Date
    Sep 2005
    Location
    NorthWest NJ, W.Haven, CT
    Posts
    3,536
    Default
    Watch this: [ame]http://www.youtube.com/watch?v=eq263AYgyYg[/ame]
    I use dyna-beads in 6 tube motorcycle tires w/o any troubles
    "The American Paratrooper exists to give the enemy soldier the best chance to die for his country." ~~ General George S Patton.
    '03 1800S '04 1300S
  6. #5
    Senior Member NDAna's Avatar
    Join Date
    Aug 2005
    Location
    Seattle Metro, U.S.A.
    Posts
    12,953
    Default
    They seem to work for me but then maybe I'm just disillusioned?
    Sam/NDAna #15542 IB#38401 '04 1800 C, HID, Audiovox Cruise, 2xDarkSide & enough other stuff to keep me comfortable. Now have H4 HID & LED headlights available NDs.HIDs@gmail.com "Can you see me now?" For DarkSide info go here http://mcdarksiders.forumotion.com
  7. #6
    Senior Member Flags's Avatar
    Join Date
    Feb 2010
    Location
    Garfield Hts., OHIO
    Posts
    366
    Default
    Quote Originally Posted by ToMang07 View Post
    Quote Originally Posted by surfshrink View Post
    Experience: the best test ever - bar none.
    Ride safe and ride often...
    Ride safe and ride often...Chief Petty Officer, U. S. Navy, RETIRED...Black 2007 1300-R, a few chrome nic nacs, debadged, clayton mod, Kury RTB, breakaway throttle lock, Honda passenger backrest and pad, Honda hard leather bags, Kury deep dish bezels, Kury ISO grips, Curved lay down license plate C.R.A.P. mod, AEROMACH 4" Risers, Kisan modulator, Kickstand extender, keeping it stock - just making it mine.
  8. #7
    Senior Member Kalten's Avatar
    Join Date
    Jul 2010
    Location
    Marysville
    Posts
    1,896
    Default
    If I had to make a guess as to why a balance machine would not work, I would think it has something to do with the fact that the machine does not vibrate to assist with redistribution of the beads. One other thing is most spin balancers run for a very short time and would not give enough time either. Just a theory though...
    Woody's fairing, Parrot Asteroid, Rockford Fosgate 300x4 and Polk db521 speakers. All mounted and wired. Needs paint!
  9. #8
    Senior Member mark_1bx's Avatar
    Join Date
    Oct 2004
    Location
    IL
    Posts
    8,556
    Default
    As far as I know Dyna Beads has always said you can't test with a balancing machine.
    Ask the people that use them...I use them and they work for me.
    M STAR KMA
  10. #9
    Join Date
    Oct 2004
    Location
    IL
    Posts
    8,556
    Default
    M STAR KMA
  11. #10
    Senior Member ervin260's Avatar
    Join Date
    Oct 2006
    Location
    Minnetonka, MN
    Posts
    850
    Default
    Quote Originally Posted by mark_1bx View Post
    I'd like to hear their explanation for this to better understand the whole situation.
    Ervin
    VTX 1800/280
  12. #11
    Member dclark31's Avatar
    Join Date
    Oct 2010
    Location
    Schertz, TX
    Posts
    97
    Default
    From the FAQ section on the Dyna Bead website:
    Can I put the tire on a balancer to see if it's working?
    No. Dyna Beads operates on physics principles, and requires the tire assembly to be in motion against a road surface to detect the exact counterbalance position. An electronic balancer has a solid, fixed mount, and does not allow the tire to react to imbalance.
    DJay - Welcome to Texas and Semper Fi
    Common Sense is an Uncommon Virtue
    2003 VTX1800R, Memphis Shades Fats & Lowers, Mustang Vintage Sport seat, Hondaline Tall backrest, Cobra Fatty Highway bar
  13. #12
    Join Date
    Oct 2006
    Location
    Minnetonka, MN
    Posts
    850
    Default
    Quote Originally Posted by dclark31 View Post
    Thanks, but unfortunately this is not a really detailed explanation.
    Ervin
    VTX 1800/280
  14. #13
    Join Date
    Aug 2010
    Location
    Bartow-Florida
    Posts
    932
    Default
    Okay I can understand how when you run the tire on the road the beads would vibrate, bounce, and move around redistributing the beads in the tire. I also understand that this would change the distribution of weight within the tire. I guess what I don’t understand is how the dyna bead company can be so sure the redistribution of weight is as good or better then fixed weights without testing.
    If you were on a bumpy road traveling at say 5-mils / hour you would feel the bumps more then say 70-mils / hour. Did the bump smooth out; no, all that occurred was the frequency of the vibration was changed to a cycle the suspension could mask or eliminate. So to say you can feel the difference is understood but doesn’t mean the vibration is gone. It could be cycling at a frequency that is almost completely taken up in the suspension which doesn’t mean it’s good for equipment like bearing.
    I’m not trying to discredit using dyna beads I’m trying to see if someone knows of testing other than I feel it in my butt. Increased tire life mentioned has merit, how much life increase and were they the same brand and model of tire
  15. #14
    Seasoned Member VTX1300cnME's Avatar
    Join Date
    Feb 2008
    Location
    Southern Maine
    Posts
    7,747
    Default
    Quote Originally Posted by ervin260 View Post
    Ervin
    Based on the physics, both centrifugal and centripetal, of how they redistribute (I'm not going to put a physics lesson on here, here are a couple wiki links, yeah, i know, Wikipedia. . lol. ).
    http://en.wikipedia.org/wiki/Centrifugal_force
    http://en.wikipedia.org/wiki/Centripetal_force
    As you spin the tire on the road, and the tire goes "out of balance" the beads will redistribute to rebalance the tire. Without an understanding of how physics really work, it's going to be hard to explain exactly what's happening inside the tire when the rubber hits the road.
    Bub Club member #361
  16. #15
    Senior Member GeminiII's Avatar
    Join Date
    Feb 2006
    Location
    Marietta, GA
    Posts
    2,232
    Default
    Seems Iíve read tire balancing machines simply do not spin up to the proper speed (RPMs) to adequately distribute the dyno beads. I believe that speed is equilivant to somewhere around 15 MPH. I assume a wheel's balance is not very important at very low speeds.
    _____________ Valkyrie F6, Std, Silver & Black, '99
    VTX1800R, Black, '02 ~~~ VTX1800R, Maroon & Black, '06 ~~~ VTX1800F, Tribal Titanium, '05
    VTX1300R, Silver, '05 ~~~ Shadow Ace Tourer, Black, '00
  17. #16
    Senior Member arebee's Avatar
    Join Date
    Oct 2005
    Location
    Winter Haven, Florida.
    Posts
    2,607
    Default
    They fixed my front end hop at 35mph, good enough for me...
    2007 1300R Titanium, de-badged, Coyote gas cap hinge, National Cycle highway bars, progressive 412, loud ass Stebel horn, Batwing, Harley Aux Lights, Rivco solo rack and some Pony paint..
  18. #17
    Join Date
    Jun 2009
    Location
    Garland, TX
    Posts
    787
    Default
    Not Dynabeads but the same basic principal. I thought this explained things pretty well. Check it out:
    [ame="http://www.youtube.com/watch?v=skY6qvzpNXI&feature=player_embedded"]http://www.youtube.com/watch?v=skY6qvzpNXI&feature=player_embedded[/ame]
    George
    2006 1800R3 Titanium/Black Progressive 440HD, L&R forwards, Phatriser II's, Tsukayu VTX bags, Cobra Speedster Longs
    "There's a fine line between genius and insanity. I have erased this line.."
  19. #18
    Senior Member hilf's Avatar
    Join Date
    Oct 2004
    Location
    Catskill Mountains (Hurleyville, NY)
    Posts
    780
    Default
    I add my experience with those who use dyna beads and are satisfied with the outcome. I've used them for about three years and whatever the theory and physics illuminates, the results for me has been a predictable and stable ride.
    '03 1800 Retro, purple
    1999 Valkyrie Standard (black and silver) w/Hannigan super sport sidecar
    IBA member #31504
  20. #19
    Join Date
    Oct 2009
    Location
    central North Carolina
    Posts
    572
    Default
    But it would be extremely easy to mount vibration sensors on the axles, ride a course, install the beads and ride the same course again. The engine mod folks use a dyno to show how well their product works. The DynaBead folks could do a similar thing that would absolutely prove whether their product works or not but, for some strange reason, have chosen not to do so.
    Steve.
  21. #20
    Senior Member NVR2FST's Avatar
    Join Date
    May 2007
    Location
    Collegeville PA (SE PA)
    Posts
    7,174
    Default
    Been using them for a few years and they are more balanced the the wheel weights and look better than wheel weights especially on my polished wheels. For the price of the beads just go ahead and try them yourself if they didn't work they would have been long gone by now
    2012 Kawasaki Concours GTR 1400
    2006 VTX 1300C - Gone
    Had Kids
    2003 Suzuki GSXR 1000
    2002 Suzuki Hyabusa (Twin Turbo mod) - Gone
    2001 Honda CBR F4i - Gone
    2001 Suzuki Bandit 1200 - Gone
    2000 Honda RC51 - gone
    2000 HD Fat Boy - Gone
    1997 Suzuki GSX 1100
  22. #21
    Senior Member XRiderChuck's Avatar
    Join Date
    Mar 2005
    Location
    Rapid City, SD
    Posts
    3,531
    Default
    they work better'n wheel weights for me, and thats all I give a crap about.
    If you can read this, Thank a teacher; since you're reading it in English; Thank a Veteran! All gave some; Some gave All...
  23. #22
    Join Date
    Feb 2009
    Location
    Indy
    Posts
    324
    Default
    Quote Originally Posted by XRiderChuck View Post
    Ditto
  24. #23
    Old Goat TennX's Avatar
    Join Date
    Jul 2006
    Location
    Memphis,Tn.
    Posts
    21,596
    Default
    If I may add Dyna beads are kinda like the Darkside you got to try em to know they work....
    I Was ......
    Phil "I should be riding" Ford
    06 CBC 1300R Darkside/Foots
    "Have You Hugged Your Dog Today"
  25. #24
    Senior Member 2wheelsforme's Avatar
    Join Date
    Jul 2004
    Location
    gulf breeze fl
    Posts
    3,148
    Default
    I tried them with poor results. I also have had poor results from some other type balancers. I do know when it is right on. I had a rear tire once that after mounting the guy said it needed no weights and it was perfect. Makes me wonder what would have happened if I had added beads to an already perfect balance. I'll stick with the computer balance and weights.
    <img src=http://i45.photobucket.com/albums/f90/2wheelsforme/IMG_0910.jpg?t=1279762000 border=0 alt= />
  26. #25
    Senior Member ShowTime56's Avatar
    Join Date
    Oct 2005
    Location
    Saint Louis, Missouri
    Posts
    5,579
    Default
    ..............been running the beads for almost 5 years now..............love em. I also change out quite a few customer tires and only balance with the beads. Zero complaints!
    Show
    "Specializing in Chrome teeth" "Thats 31Ts if you know what I mean!"
  27. #26
    Senior Member WildHorse's Avatar
    Join Date
    Nov 2005
    Location
    Ulasigi Ulogilv, OK
    Posts
    2,358
    Default
    Quote Originally Posted by TennX View Post
    Chrome Cowgirl- Real & Steel
    1800N Carlini Apes DS & 1800R Carlini Apes- the back-up
    ~Geyatahi Soquili~
    Rebecca WildHorse
    SIS National Director/CEO
    www.SistersInSpirit.org
  28. #27
    Senior Member edgee's Avatar
    Join Date
    Aug 2009
    Location
    St. Peters, Missouri
    Posts
    1,867
    Default
    Quote Originally Posted by ShowTime56 View Post
    Show
  29. #28
    Join Date
    Apr 2008
    Location
    USA
    Posts
    705
    Default
    Yep I had a horrible vibration at highway speeds when I rode my bike home when it was new, I took the weights off and put Dynabeads in and it rode smooth as glass with them. I've used them ever since.
  30. #29
    Senior Member RRider's Avatar
    Join Date
    Jul 2010
    Location
    US
    Posts
    655
    Default
    You also have to remember that as you ride,your tire wears. First when tires are made,they are not perfectly round weight wise to keep this simple. Thats why you have to balance them in the first place. As you ride you are removing rubber from the tire. Quick switch but stay with me! When you drive your car the same thing happens,you are loosing rubber when you drive. When you turn your front wheels the outside edge loses even more due to wear-follow me so far! So you rotate your tires on your car and have the tires REBALANCED. Why,because now the tire has different weight characteristics due to rubber being removed as you road on the tire. If you kept the same weights when you first bought the tires and continued to ride on them,the tire would develope a wobble,due to the tire being out of balance-rubber removed during use!
    In the end,dyna beads consistantly balance your tire through its distibution of beads inside the tire as it wears. If you think of the beads as a solid wheel weight,just like you would put on your rim,just broken up into little peices. These peices just gather inside your tire like a regular weight to stop the wobble/vibration. Benefit,they can move on there own to adjust for tire wear while the regular wheel weight is stuck in one position. The biggest problem why we are sceptical about dyna beads is that most motorcycle tires do not last as long as car tires and we do not rotate them. You would get more milage out of your bike tires if you did balance them once a year with regular wheel weights-lots of post on here about front end wobble/choppy tires(Not Bearing related)-would it have happened so soon if the tire was balanced once a year?
  31. #30
    Join Date
    Oct 2004
    Location
    IL
    Posts
    8,556
    Default
    LOL......Oh Boy!
    M STAR KMA
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
