how often should thermostat be replaced
+ Reply to Thread
Results 1 to 25 of 25
Thread: how often should thermostat be replaced
  1. #1
    Junior Member
    Join Date
    Sep 2010
    Location
    shelby oh
    Posts
    10
    Default how often should thermostat be replaced
    how often should the thermostat be replaced on the vtx1800. im changing my antifreeze on my 2003 and thought i would change it as well as far as i know it has never been replaced.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member VTXCRZR's Avatar
    Join Date
    Oct 2004
    Location
    New Braunfels, TX
    Posts
    3,530
    Default
    I've be driving since 1967 and have owned too many cars and motorcycles to count. Two or three years ago I calculated that I have driven close 1.25 million miles over my life time. Most of that in high mileage old vehicles. My Suburban, that I bought new in 1994, has about 265,000 and accounts for about 20% of my 1.25 million miles and still has the original thermostat.
    In all those vehicles and all those miles I have had to replace 1 thermostat and that was in a 1964, drop top, 4 on the floor, alumimum block V-6 Buick Special with 120,000 miles on that I bought for $300 and drove the snot out of for 4 years and put on about 75,000. Even then I am not sure the thermostat needed replacing but the guy at the autoparts store told me I should since I was replacing the water pump so I did .
    So guess the anwser is change the thermostat once every 1.25 million miles or every 44 years or if it breaks. But I don't see it as a preventative maintenance issue.
    According to the official Honda Service Manual, under normal conditions your coolant should be changed every 2 years. More often if you live in either the Death Valley or International Falls, MN. The same recomendation is made for brake and clutch fluid. I do mine about every other year and it takes me about two hours. The biggest pain is pumping out the brake fluid and bleeding in the correct order.
    2003 VTX 1800 C, Rinehart Exhaust, Hypercharger, PCIII, Custom map for each cylinder, 1300 FD, Spec 3 F-wheels, 200x50x18 Metzler
  4. #3
    Senior Member Garand1957's Avatar
    Join Date
    Feb 2009
    Location
    The War Room
    Posts
    895
    Default
    Quote Originally Posted by VTXCRZR View Post
    I've be driving since 1967 and have owned too many cars and motorcycles to count. Two or three years ago I calculated that I have driven close 1.25 million miles over my life time. Most of that in high mileage old vehicles. My Suburban, that I bought new in 1994, has about 265,000 and accounts for about 20% of my 1.25 million miles.
    Only 1 thermostat in all those miles and all those vehicles ?
    WOW.... that's so unlike reality
    I have owned vehicles and been driving since 1975.
    My experience has been that thermostasts give out over time not mileage.
    In general they start to give out after about 4-5 years service or around the same time the service life of the first or any battery goes south.
    I change the coolant when I change the thermostat.
    "Two-thirds of all quotes found on the internet are, more or less, complete bullsh*t". - Abraham Lincoln
  5. #4
    Senior Member toboggan's Avatar
    Join Date
    Jul 2009
    Location
    Canton, MI
    Posts
    254
    Default
    It should be replaced when/if it stops working.
    Great Lakes Road Riders
    2002 1800S2, Cobra Fatty Highway Bars, Memphis Shades, LeatherLykes, Honda Light Bar, Honda Deluxe Backrest and Luggage Rack, Ultimate Big Boy Seats, Rostra Electonic Cruise Control w/ switch housing by cybrhick, HID Headlight by NDAna.
  6. #5
    Join Date
    Feb 2005
    Posts
    7,959
    Default
    Quote Originally Posted by toboggan View Post
    That's my vote...is there anything in the manual saying to replace? Don't think so...
    Bull
  7. #6
    Senior Member Beermand's Avatar
    Join Date
    May 2007
    Location
    Kimberling City, Missouri
    Posts
    820
    Default
    Ok I have had a drivers license for 33 years and I have only changed one thermostat in one vehicle in all those years. My 03 VTX 1800 has 38,000 miles on it and I am not planning to change the thermostat unless it fails? Why would you? I keep up on my maintenance changed coolant and oil and brake fluid final drive oil etc., but why would i change parts that aren't worn out or in need of changing?
    03 VTX 1800S Illusion Blue Ultimate X Big Boy GYTT 205/65-15 Darkside and Loving it!
    [IMG][/IMG]
  8. #7
    Senior Member edgee's Avatar
    Join Date
    Aug 2009
    Location
    St. Peters, Missouri
    Posts
    1,866
    Default
    If it's not broken don't fix it
  9. #8
    Senior Member Ironhorse17's Avatar
    Join Date
    Sep 2008
    Location
    GATINEAU QC
    Posts
    760
    Default
    Maybe alot are broken and we do not know what are the signs if it stuck in a open position?
  10. #9
    Senior Member VTX Candy Red's Avatar
    Join Date
    Dec 2003
    Location
    Oregon, Ohio
    Posts
    2,278
    Default
    Quote Originally Posted by Ironhorse17 View Post
    Takes a long time to warm up.
  11. #10
    Senior Member Gonzo1970's Avatar
    Join Date
    Oct 2009
    Location
    Belleville, IL
    Posts
    1,479
    Default
    Varies.
    Ive replaced the Thermostat in a 1972 Big Block Olds after 36 years and 180k miles.
    Ive replaced the thermostat in my POS Chevy Tahoe Z71 after 4 years and 60k miles.
    Depends on the thermostat itself.
    You can get good ones. You can buy brand new ones that dont work.
    Easiest to test them with a pot of boiling water on the stove. Dip it in boiling water for about 30 seconds... pull it out, and see if its open.
    -Gonz
    Harley Owners Need Dependable Alternatives
    "Dear Fox News: I am writing today to request that you add a laugh track to your coverage to properly identify it for the comedy that it is.
    Also, clown noses for the reporters would be nice."
  12. #11
    Join Date
    Jun 2009
    Location
    Garland, TX
    Posts
    787
    Default
    Quote Originally Posted by Gonzo1970 View Post
    -Gonz
    That's how my dad showed me to test them when I was a kid. If they open up in the boiling water and close when you take it out then its good. If it doesn't then leave it out till you have time to go pick up a new one. Half the time I would forget to put the new one back in unless it was the middle of winter.
    George
    2006 1800R3 Titanium/Black Progressive 440HD, L&R forwards, Phatriser II's, Tsukayu VTX bags, Cobra Speedster Longs
    "There's a fine line between genius and insanity. I have erased this line.."
  13. #12
    Join Date
    Jul 2009
    Location
    Canton, MI
    Posts
    254
    Default
    Quote Originally Posted by VTX Candy Red View Post
    The other failure mode is when they don't open at all. Then, your engine gets too hot, which should trigger an idiot light (or see it on a guage if you have one).
    Testing it in boiling water is the easy way to really tell if it's broken, though. I wouldn't even bother disturbing the gasket if it's not even suspected of being bad, though.
  14. #13
    Senior Member j pate's Avatar
    Join Date
    Oct 2008
    Location
    Anniston Al
    Posts
    212
    Default
    as said if it sticks closed on a road trip all the time and money would be worth changing least 5 years , what 5.00 plus coolant gasket comes with kit
    04 1300c black 27,000 miles. Hard chrome pipes, pro hype for looks i guess, jet kit, tech, Corbin light bar, fatty front axle covers, pull back risers magnachrom gas cables,so grips ,o and chromed front bearings not. Avon tires venom 2- set waiting on ups. half floorboards
  15. #14
    Join Date
    Feb 2009
    Location
    Indy
    Posts
    324
    Default
    Had cars since I was 16 (am 67 now) and can't remember ever changing out a thermostat because it failed. Back in the day in ND we used to change them out for winter and summer use, but haven't done that for years --- this is definitely a "don't mess with it till it fails" situation. On the other hand there we could change out the oil, filter, final drive oil, brake and clutch fluid, coolant and install a new clutch, flange bearings, tires, spark plugs, brake pads and air filter every 3000 miles just to be safe ---
  16. #15
    Join Date
    Oct 2004
    Location
    New Braunfels, TX
    Posts
    3,530
    Default
    Quote Originally Posted by ALVTX View Post
    Don't forget that we should also tear her down to the bare frame to inspect all welds and repaint about every 3,000 miles or once a year. (http://www.weldprocedures.com/inspection.html) More often if you live where they salt the road or near the ocean.
    Honda never recommends this, but better safe than sorry. Imagin being out on the open road, fully loaded, heading for Sturgis at 80 MPH and your frame falls apart. Then a bunch of HD guys drive by . But you can always point out that your thermostat is good. That is unless you pulled out a perfectly good one and installed a brand new defective one. To which the HD guys will reply, Whats a thermostat and whats it used for?
  17. #16
    Join Date
    Feb 2009
    Location
    Indy
    Posts
    324
    Default
    Now I am concerned about my '02 C being over 8 years old and still has the same bulbs in the headlight, tailight and turn signals --- I better change them all out this week-end ---
  18. #17
    Senior Member tin-indian's Avatar
    Join Date
    Mar 2005
    Location
    N/E Ohio
    Posts
    1,197
    Default
    While I haven't had nearly the same luck as the other guys (in 25 years of being the family mechanic I've probably gone thru 50 thermostats). I agree that unless there's signs that it's bad I wouldn't touch it. My experience is that none of the aftermarket thermostats are as good as the factory ones.
    '02 VTX1800C
  19. #18
    Senior Member RAH16's Avatar
    Join Date
    Jul 2008
    Location
    Dalton, Massachusetts
    Posts
    1,302
    Default
    I had a 76 F150 that had one go bad. Then it was a string of them. Replace 6 in a month and a half. I finally went to a different parts store to get a different batch and all was good. must have had a bad batch of wax
    But I've had a few go in my 20 years of driving, none in late model cars only the older ones pre 80's...
    2006 VTX 1800C (Gone)
    VTXOA 'Members Who Can Help' Map
    A computer once beat me at chess, but it was no match for me at kick boxing.
    -- Emo Philips
  20. #19
    Senior Member Harkon's Avatar
    Join Date
    May 2010
    Location
    Calgary, Alberta, Canada
    Posts
    728
    Default
    I've had to replace a few, and many just because I had things apart anyway. Part of the rebuild / renew process. Out of the ones that failed, maybe 3 or 4 of them, I have never had one fail closed. I don't know if this was just lucky or what. I live in Canada where the winters can get quite chilly and almost all of them that have failed, failed in the cold and failed open, resulting in the vehicle not achieving a proper running temp, and by consequence, sufficient heat from the heater core.
    '02 1800C, V&H Big Shots, Kury Corsair intake, DeBadged, Desmogged, PCIII Dyno Tuned, Mustang seat, NDAna
    HID kit, 1300 final.
    '12 Road Glide Ultra, Kuryakyn Alley Cat intake, American Custom Bomber slip-ons, V&H Dresser Duals header, V&H Fuelpak, NDana HID kits
    '13 CRF450X (mine) , '09 KX85 (for my son) , '03 TTR225 (for my wife)
  21. #20
    Senior Member wbi7686's Avatar
    Join Date
    Jun 2006
    Location
    HV. Texas
    Posts
    243
    Default
    It is quite common for thermostats to weaken with age and the engine to not fully warm up. When you install a new thermostat in a vehicle with a gauge it is often obvious when with the new one it reads in the middle of the gauge again instead of in the left 1/4. Iv'e seen this dozens of times.
    If the engine does not reach proper operating temperature it is not operating at maximun efficiency. Often not noticed in warm weather
    VTX1300C- Black Cherry
    1984 V65 Sabre
    1976 GT500 Suzuki
    1972 380 Suzuki
    1970 Bridgestone 100
  22. #21
    Senior Member leroys73's Avatar
    Join Date
    Feb 2010
    Location
    Dallas Area
    Posts
    625
    Default Thermostat replacement
    Well, I guess I am an odd one. Not all stick open. I have owned cars for almost 50 years with experience and professional training in auto mechanics. I was taught to change thermostats when changing hoses. I still change the 'stat with hoses. On many of today's cars they are a bitch. I have had at least three failures on personal vehicles that I aquired as used. Two were open and one closed. The closed one tried to cost me over $400 in Lubock, Texas at a Firestone store while on vacation in the 80s. They claimed it was the water pump. I called BS on that. Since some coolant was moving through the by pass I turned on the heater, opened the windows and drove 50MPH to get home 200 miles later so I could replace the thermostat. It was a used vehicle so I guess that is what I get for not doing my own service when I bought it. I do not plan to be stuck in the middle of nowhere on my VTX when a non expensive thermostat would have kept me on the road. I have 32K on my '07, I change the coolant (+ inspect hoses) and brake fluid every two years. I believe it can go longer but I keep it in warranty. I'll change the hoses and 'stat in about 2-3 years. Time is probably the main enemy of the thermostat.
  23. #22
    Join Date
    Sep 2009
    Location
    East TN Dragon Slayer
    Posts
    860
    Default
  24. #23
    Join Date
    Sep 2009
    Location
    Posts
    860
    Default
    Quote Originally Posted by wbi7686 View Post
    WHAT'S A GAUGE?
  25. #24
    Join Date
    Jan 2009
    Location
    In the Heart Of Dixie in Montgomery, alabama, home of Hank williams and Nat King cole
    Posts
    1,520
    Default DITTO......
    BLURBN
    Dixie Rose
  26. #25
    Senior Member MidLifeCrisisNC's Avatar
    Join Date
    Nov 2003
    Location
    Lexington, North Carolina
    Posts
    2,381
    Default
    Varies.
    -Gonz
    and there you go....test it if you plan on removing it, if it opens in boiling water, and if it closes when it cools down also it is a good thermostat, matter of fact, always perform that test before installing a new thermostat!!!
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
