Snow blower trouble
+ Reply to Thread
Results 1 to 22 of 22
Thread: Snow blower trouble
  1. #1
    Senior Member Ghost-Flame's Avatar
    Join Date
    Dec 2005
    Location
    Doylestown, Pa
    Posts
    3,915
    Default Snow blower trouble
    I would have put this on the OTB but those knuckle heads would tell me Obama is causing all my mechaincal problems...
    Any who, to keep this MC related The snow blower clars the driveway so I can get the bike out.
    About 2 weeks ago in that crazy snow storm my Snow blower started running really ragged and would stall under load. I could start it up run it for 30 seconds and stall. Okay so I did all the stuff I know how to do on a small engine. I checked the oil, sat on a chair, scratched my head and said Awe Frick!!! Now I have to shovel.
    I took it over to the dealer and right away he starts telling me the gas is stale... maybe but it was new in November of 2010 and I put some Seafoam in to stabilize the fuel. So he drains the gas rebuilds the carb.
    I get it home and it runs like sh1t. better but not much.
    I look at the spark plug hole and it has cob webs arond the bottom. So, I pull it and it was glistening with oil and it was covered with carbon. Would an oil fouled plug case the engine to run ragged?
    Any way I guess I'll get a new plug and see what happens. Why would a factory trained rep not check the plug???? I'll never go back there. I can't wait till I got to Florida for 10 days
    I just notice the threads on the cylinder head are soaked with oil
    Here's a picture I stupidly wiped the oil before I took the pic.
    2004 vtx1800c.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    Mar 2005
    Location
    Michigan
    Posts
    1,248
    Default
    The short answer is yes. Don't store any small gas engine with gas in it. At the end of season drain whatever it is, then run it until it stalls. Gas is not what it used to be due to fewer additives ,purpose being to reduce emmissions.
  4. #3
    Join Date
    Dec 2005
    Location
    Doylestown, Pa
    Posts
    3,915
    Default
    the plug is oil fouled, and there is oil moisture on top of the piston.
    About 1 month ago I changed the oil, when I refilled I wasn't thinking and dumped in 1 whole qt, the proper fill is 19 ozs. So, the pan was over filled by 13 ozs. go ahead call me stupid
    After filling and running it for about 20 minutes I realized that I put too much in. I looked at the manual after the fact. I drained the qt out then put in the proper amount of oil.
    The overfill must have forced oil up into the combustion chamber.
    I just put in a new plug and the machine ran real good for about 5 minutes then it stalled. I took out the new plug and it was covered with oil. I shined a light into the hole and there is oil in there
    I think I need to get that oil out of the combustion chamber. Any ideas as to how to?
    By the way snow blowers don't have air filters, I dont know why... no air filter
    2004 vtx1800c.
  5. #4
    Senior Member 2002VTX's Avatar
    Join Date
    Mar 2006
    Location
    Rancho Santa Margarita, CA
    Posts
    1,692
    Default
    I always thought the best way to burn off oil in the combustion chamber is to run the crap out of it with engine fogger.
    Paul Schweizer
    SoCal
    2002 Honda VTX 1800C
    2001 Kawi Concours
  6. #5
    Member
    Join Date
    Aug 2010
    Location
    Topeka, KS
    Posts
    99
    Default
    Got an air compressor? If so just rotate the engine until the exhaust valve is open so you can blow air through the exhaust system via the spark plug hole. Then get yourself a spray bottle and some mineral spirits paint thinner. Spray it in the hole, blow it through, repeat. Do that about ten times and then blow a little WD40 in it to lube the cylinder walls on restart. Keep in mind, Mineral spirits is flammable. If that doesn't fix it,
    you likely have a broken ring or other issue.
  7. #6
    Senior Member X'N's Avatar
    Join Date
    Apr 2006
    Location
    MN
    Posts
    10,507
    Default
    If its just a normal 5-8hp flat head motor just yank the head off, like 6-7 bolts and your to it. Few bucks for a head gasket...
    2012 Victory Cross country
    http://www.vtxoa.com/forums/attachment.php?attachmentid=75391&d=1342403272
  8. #7
    Senior Member scup's Avatar
    Join Date
    Sep 2005
    Location
    NorthWest NJ, W.Haven, CT
    Posts
    3,504
    Default
    Quote Originally Posted by X'N View Post
    Sounds to me that the piston rings got hosed 'hydralic locked' due to too much oil. If you have a compression tester, I'd start there, I forget but anything over 100 psi rings a bell. After the heads removed there are like 4 bolts that hold the jug on if I remember right, or you'll have to slide the piston out the bottom... it's been ages since I broke one down so this is all from a 35-40yr memory.
    If the enginge is a tecumceh (sp) just pull it and replace it w/ a Briggs & Stratton... those tecumech engines are junk IMO they always seem to break rods.
    Good luck... better hurry... da snows a-commin'
    "The American Paratrooper exists to give the enemy soldier the best chance to die for his country." ~~ General George S Patton.
    '03 1800S '04 1300S
  9. #8
    Join Date
    Mar 2008
    Location
    petersburg indiana
    Posts
    1,239
    Default
    You havent really said, is that thing smoking like crazy?
    Over filling with oil wouldnt have hurt the rings, even a hydrolock wouldnt hurt the rings, it might snap a rod, or bust a piston, but not the rings.
    If it is a regular 4 stroke engine, that you have previously over filled with oil, you will need to remove the cover where you check valve clearance, and get the oil out of the crankcase vent. It is on the side of the engine and has a hose running to the carburetor. It has a "filter" type media in it, and it will be saturated with oil, and the oil is getting "sucked" into the intake.
    If the engine ran with the overfilled oil, and didnt seize, then the engine will be ok from that.
    I dont suggest removing the head yet, as I think your trouble is elsewhere.
    What little oil that would remain in the head area would burn off in under a minute. If there is oil arriving from somewhere else, that is what you have to find, and I believe you will find it to be the crankcase vent.
    Honda factory trained technician, since 1996.
    Riding a 2005 VTX 1800 N SPEC2.
    Member; Darkside, Exhaust; Sydewynders Custom
    1300 final, Honda Lowers with Memphis shields windscreen, Kury Cruise Pegs
  10. #9
    Senior Member Glenn W's Avatar
    Join Date
    Nov 2003
    Location
    S.E. WI
    Posts
    2,030
    Default
    Quote Originally Posted by tnvnl View Post
    Bingo. Pick up a second plug for later and and make sure the oil is back down to the right level. Then you can either keep changing/cleaning plugs till you burn off the excess oil or get rid of the oil by cleaning up the vent system. Don't forget to check the air filter IF it has one. Most OEM snowblower powerheads won't have an air filter but I don't want to assume yours doesn't have one like in the case of a replacement engine from a lawn mower, etc.
  11. #10
    Senior Member RAH16's Avatar
    Join Date
    Jul 2008
    Location
    Dalton, Massachusetts
    Posts
    1,299
    Default
    Quote Originally Posted by Ghost-Flame View Post
    Big O trained him. Sorry couldn't resist...
    Anyway I think your best bet is to bring it to a small engine repair shop.
    If it has electric start pull the plug and turn it over a few times. That should blow excess oil out the plug hole. Just my opinion
    BTW is it a two stroke by any chance?
    2006 VTX 1800C (Gone)
    VTXOA 'Members Who Can Help' Map
    A computer once beat me at chess, but it was no match for me at kick boxing.
    -- Emo Philips
  12. #11
    Join Date
    Dec 2005
    Location
    Doylestown, Pa
    Posts
    3,915
    Default
    Thanks guys. I'm going to try to clean the oil out
    It has the right amount of oil in it now.
    Its a 4 stroke, single cylinder, 7 hp, Tecumseh
    Its not showing any blue smoke at all
    I have a compressor, Blow out through exhaust valve
    I can crank the engine w the spark pl hole open
    It does not have a air filter
    I can take the valve cover off and check that filter medium
    I'll get a few plugs to have to keep on hand til the thing is clear
    I hope I don't need to take the heads off.
    2004 vtx1800c.
  13. #12
    Member BLC's Avatar
    Join Date
    Nov 2010
    Location
    WEST VIRGINIA
    Posts
    42
    Default
    This is how i get the oil out of the top end i pull the plug and put my finger over the hole and pull the starter rope the compression will blow your finger off the spark plug hole and in the process it will blow the remaining oil out try it it works i work on small engines alot
  14. #13
    Join Date
    Nov 2003
    Location
    S.E. WI
    Posts
    2,030
    Default
    Quote Originally Posted by BLC View Post
    And have a friend who owes you money hold the sparkplug boot and have HIS finger over the plug hole while you pull the cord
  15. #14
    Join Date
    Dec 2005
    Location
    Doylestown, Pa
    Posts
    3,915
    Default
    Quote Originally Posted by Glenn W View Post
    Thanks GlennW... and everyone else I love this board!!
    Alright I'm out in the garage. I took off the valve cover, filter medium and (what my novice eyes interpret as a) "REED" valve. as soon I cracked the plate about 2 tablespoons of oil drained out. the filter medium was dirty and dripping with oil, there was a puddle in the back of the valve cavity. The vent tube was dripping oil all over the side of the engine. (I couldn't see it because the Carbuerator heat shroud covered the leaking oil).
    I called NVR2fast aka Shaun (he and VTXRosa, Bob are our Technical consultants assigned to this region of the VTXOA for all things internal combustion).
    Shaun confirmed that there should not be any excess oil in there.
    I took all the disassembled parts and soaked them in WD-40 and scrubed them gently. I then washed out all the parts with warm/hot soapy water. a lot of gunk came off. Then I used compressed air to dry all the parts. I'm going to let them sit over night to throughly dry. I also used a few clean paper towels to absorb the puddle inside the valve body.
    Question 1: Should I put a drop or 2 of oil on the filter medium and rub it in before I put it back together or should I just leave it dry?
    Question 2: I had to take the muffler off to get to the valve cover in doing so I broke the gasket. Is that important or should I get a new gasket?
    Most importantly, Question 3: do young beautiful girls think the same thing I'm thinking when I meet them?
    In case you are wondering why I'm willing to put so much time and money into this 1985 snow blower, when I could buy one for $700 at big box USA. Well,When I bought it new in '85 it was the entry level higher end model. The dealer told me a comparable model today would be $1500. This machine is worth even a new engine at $400 or so if the engine needs replaced someday. This the first time I've had to repair it, in 25 years of use, except for grease, oil and belts. Its the first time I've ever taken the valve cover off. They don't make em like this anymore.
    2004 vtx1800c.
  16. #15
    Senior Member Padre Blanco's Avatar
    Join Date
    Apr 2008
    Location
    Greenbrier County, WV
    Posts
    1,396
    Default
    If they are thinking "man, she's hot" I'm going to have to defer my answer to a referral for psychiatric evaluation, to which they will tell you...it's Obama's fault.
    Padre Blanco
    2007 VTX 1300 R Titanium, Honda 24L Bags, Memphis Shades Shield, Kury Flame Grips, Mustang Vintage Sport Touring Seat, Progressive Front Springs and Alls Balls Tapered Bearings
  17. #16
    Join Date
    Nov 2003
    Location
    S.E. WI
    Posts
    2,030
    Default
    Question 1: Should I put a drop or 2 of oil on the filter medium and rub it in before I put it back together or should I just leave it dry? no, it'll oil itself like it or not, and it's not operating in an intake mode like a carb
    Question 2: I had to take the muffler off to get to the valve cover in doing so I broke the gasket. Is that important or should I get a new gasket?if really should be replaced to keep from there being any chance of sucking in cold air past the valve as it closes & cracking it should there be a big leak. (in the real world if you don't hear a ticking noise from the exhaust or feel/hear a leak I wouldn't shovel by hand until you can get a gasket)
    Most importantly, Question 3: do young beautiful girls think the same thing I'm thinking when I meet them? Yes, they're all wondering what they taste like, too.
    In case you are wondering why I'm willing to put so much time and money into this 1985 snow blower, when I could buy one for $700 at big box USA. Well,When I bought it new in '85 it was the entry level higher end model. The dealer told me a comparable model today would be $1500. This machine is worth even a new engine at $400 or so if the engine needs replaced someday. This the first time I've had to repair it, in 25 years of use, except for grease, oil and belts. Its the first time I've ever taken the valve cover off. They don't make em like this anymore. Very true, finally had to replace my late 80s Ariens 724 machine two years ago when it siezed & snapped the connecting rod. Prior to that I'd only replaced belts, shear pins, and axle bearings.
  18. #17
    Senior Member ken c's Avatar
    Join Date
    Mar 2008
    Location
    Southeast Michigan
    Posts
    378
    Default
    Why are those dogs in jail?
    2005 1800R-3 Mustang Wide touring, Custom Switchblade, VTX Exhaust, Leatherworks 110's, Honda deluxe sissybar, scootworks PHAT 2 risers, Cobra Fatties, PAIR valve removal, sec air system removal, Sharpe high beam indicator, GYTT...
  19. #18
    Senior Member kdarsey's Avatar
    Join Date
    Jul 2010
    Location
    Sinking Turtle Resort In Bleckley County, Georgia
    Posts
    287
    Default
    What's a Snowblower ? ? ?
  20. #19
    Senior Member RRider's Avatar
    Join Date
    Jul 2010
    Location
    US
    Posts
    655
    Default
    Quote Originally Posted by kdarsey View Post
    A hooker that does snowmen!
  21. #20
    Senior Member ShowTime56's Avatar
    Join Date
    Oct 2005
    Location
    Saint Louis, Missouri
    Posts
    5,576
    Default
    Quote Originally Posted by RRider View Post
    Whats the difference between Snowmen, and Snowwomen?
    .............wait, wait for it...............someone knows for sure!
    "Specializing in Chrome teeth" "Thats 31Ts if you know what I mean!"
  22. #21
    Member
    Join Date
    Mar 2010
    Location
    Sidney, OH
    Posts
    56
    Default
    snow balls?
  23. #22
    Senior Member mrmustang69's Avatar
    Join Date
    May 2008
    Location
    Perry, Fl.
    Posts
    817
    Default
    quote I would have put this on the OTB but those knuckle heads would tell me Obama is causing all my mechaincal problems...
    No sir Obama did not cause your machainal problems...Al GORE did !!! If it was not for his global warming you would not need that snowblower
    And about that #3 question ..I hope she's not thinking the same thing I am ..Tha would make her a lesbian.
    Don't run your fingers over my bike ,and I won't run my bike over your fingers!!!
    '03 1800 c .Hard krome sideburners,desmog,ground fix,pair vaule blocked, baron X bars,quick release back rest, flame mirrors, pcIII,MS fats shield and lowers,iso grips and throttle boss, darkside GYTT,corbin young guns seat...more to come ...
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
