Anyone have problems with Valvoline Oil?
+ Reply to Thread
Results 1 to 12 of 12
Thread: Anyone have problems with Valvoline Oil?
  1. #1
    Join Date
    Feb 2011
    Location
    Pittsburgh, PA
    Posts
    109
    Default Anyone have problems with Valvoline Oil?
    On the last (first since I bought the bike) oil change I used Valvoline MC oil (made for wet clutches). The standard "slip" of the clutch is WAY worse. I wanted to know if anyone else has experienced this, and if so, what are you using now?
    I ordered a new MTC clutch and steel rings because before the oil change it would slip occasionally. Since this oil change, it seems I can't give it full throttle without slipping in any gear.
    I plan on changing the oil again when I change the clutch.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member texasmike's Avatar
    Join Date
    Aug 2009
    Location
    el paso texas
    Posts
    5,324
    Default
    i've never used it on my x i use amsoil. but i did use it all the time on my yamaha raptor and it worked great.
    texasmike
    1300c 8 degree rake, cobra pipes, c&c seat, darkside and lots more
  4. #3
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    58,896
    Default
    It's not the oil, it's the clutch. You've found the VTXs weakest link in the drivetrain.
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  5. #4
    Join Date
    Feb 2011
    Location
    Pittsburgh, PA
    Posts
    109
    Default
    I know that it is spike, but it literally got WAY worse and I think it happened when I changed the oil.
  6. #5
    Senior Member speedsville's Avatar
    Join Date
    Sep 2005
    Location
    Detroit, Mi
    Posts
    5,881
    Default
    did you do anything else?
    I put on the wide clutch lever and suddenly the clutch started slipping.
    Examining the lever the new one's rest anvil was just a touch deeper than the
    stock. I ground that back and everything was fine.
    Just saying that sometimes it is not the obvious!!!
    Dump the chump: Trump
  7. #6
    Senior Member 2002VTX's Avatar
    Join Date
    Mar 2006
    Location
    Rancho Santa Margarita, CA
    Posts
    1,692
    Default
    If it was really oil recommended for wet clutch motorcycles, then it shouldn't make that much difference. Try an oil and filter change with Shell Rotella full synthetic. Run it for a couple hundred miles, then change the oil and filter again.
    Odds are it is something mechanical verses just your oil.
    Paul Schweizer
    SoCal
    2002 Honda VTX 1800C
    2001 Kawi Concours
  8. #7
    Senior Member GTvtx's Avatar
    Join Date
    Sep 2006
    Location
    Taylorsville, GA
    Posts
    1,881
    Default
    use 20 w 50 and it will improve the clutch issues.
    Not synthetic
    synthetic is more slippery than conventional oil.
  9. #8
    Join Date
    Feb 2011
    Location
    Pittsburgh, PA
    Posts
    109
    Default
    Well even though I just changed it, now that I am changing the clutch (draining the oil) I am going to do a fluid/filter change. Will report back on what I find out.
    And no, nothing else changed.
  10. #9
    Member jjohn2308's Avatar
    Join Date
    Jun 2006
    Location
    denton,texas
    Posts
    56
    Default oil
    i have been using valvoline 20w-50 for about 7 years with no problems at all.
    2003 black 1800C vtx. switchblade windshield. k&n air filter.lots of chrome
  11. #10
    Banned
    Join Date
    Aug 2008
    Location
    Washington State, just north of Libtardistan!
    Posts
    8,514
    Default
    The only problem with Valvoline is that it's really lousy on pancakes!
    I use Amsoil myself!
  12. #11
    Senior Member freedom's Avatar
    Join Date
    Jan 2005
    Location
    shelbyville il
    Posts
    723
    Default mobile 1
    I use mobile 1 4t it works great. I was under the impression 20w 50 is to heavy for a water cooled bike. Maybe my impression is wrong who knows
    2003 vtx 1800c, black fastest color sold 4-14-2012 2010 kawasaki voyager traded 8-21-2013 a 2013 Victory Vision.
  13. #12
    Senior Member tin-indian's Avatar
    Join Date
    Mar 2005
    Location
    N/E Ohio
    Posts
    1,197
    Default
    Quote Originally Posted by X-Beast Driver View Post
    But it looks like it would be delicious on pancakes!
    I deliver motor oils for a living, I can't tell you how many times after unhooking the hose and watching a stream of oil drip, I've said "that looks like it would be delicious on my pancakes" to the receiver.
    '02 VTX1800C
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
