Homemade single wheel trailer - Coffin Style
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 30 of 56
Thread: Homemade single wheel trailer - Coffin Style
  1. #1
    Senior Member imabass's Avatar
    Join Date
    Jan 2011
    Location
    Tulsa, OK
    Posts
    262
    Default Homemade single wheel trailer - Coffin Style
    Coffin trailer started as a thought and then I put it down on paper. Now it is in process of building.
    Using 1x2 steel tubing for the frame.
    2x2 steel tubing for the toung
    Yokes and U joint from farm supply
    Plan to skin it with pine.
    building coil over shoks from old fork spring, 100# shock absorbers, and square tubing. Will cover it with bicycle tube to protect the shock seals.
    using 10 inch scooter wheel
    homemade swingarm that is hinged with brass bushings like the 70's hond swingarms were made.
    Homemade VTX hitch from 1/2 plate. Welded it to the sub frame.
    I had a few hours to work on the trailer. As you can see I am almost done with the frame. I need to finish out the swing arm. I need to find the correct size tubing and bushings that I should be able to get at the parts store. i will also have to make the spacers. I put this on the scales and it currently weighs just under 75 pounds. I am hoping to finish it out for a total of 140-150 range or possibly less.
    Need help posting video from youtube...
    http://youtu.be/b-HqEQ4Yhcc?hd=1
    Check out my other home at www.SOHC750.net. Home of the CB750 SOHC ( 1969-1978 ) Choppers, Bobbers, & Cafe Racers.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member joe low's Avatar
    Join Date
    Jun 2010
    Location
    Niagara area
    Posts
    282
    Default
    LOOKING interesting so far ........keep us posted
  4. #3
    Join Date
    Dec 2004
    Location
    out in the sticks
    Posts
    14,240
    Default
    Very impressive.
    Back on the road. 2003 lightly moddified 118ci C model.
  5. #4
    Senior Member pappy in MN's Avatar
    Join Date
    Mar 2006
    Location
    Saint Paul, MN
    Posts
    1,552
    Default
    very cool. will you offset the tire mounting bracket? with a spacer on the non-rotor side of that wheel, the tire is off-center. might that cause a pull to one side, or uneven tire wear?
    Pat H 04 1300 S
    "To the world you may be one person,
    but to one person you may be the world."
  6. #5
    Senior Member enduro's Avatar
    Join Date
    Jun 2008
    Location
    Montrose, Pa.
    Posts
    1,348
    Default
    This guy sells them made out of actual blemished coffins. Note the arm hanging out the back.
    05 1300R - sold, 04 BMW K1200LT - Luxury Tourer, smooth efficient quiet power, sporty mile eater
    05 BMW F650GS - rugged and elegant adventure tourer, does it all well, high speed cruising to rough dirt roads,
    IBA: SS1000, SS2000, SS3000, BBG1500, 50CC, UCC, LGL1000, 4 Corners
  7. #6
    Senior Member Fla.Cableguy's Avatar
    Join Date
    Feb 2008
    Location
    St. Pete Florida
    Posts
    4,176
    Default
    , Smitt
    Lot's of time and money. I trust no one's wrench, but my own. Avon Monster Club, Black Out Club, Mat Black Fastest Color....Pay it forward .
  8. #7
    Join Date
    Jan 2011
    Location
    Tulsa, OK
    Posts
    262
    Default
    Quote Originally Posted by enduro View Post
    That was my first plan. I found a couple by placing a wanted ad on craigslist. I found one that was used for only $400.
  9. #8
    Join Date
    Jan 2011
    Location
    Tulsa, OK
    Posts
    262
    Default
    Quote Originally Posted by pappy in MN View Post
    Yes I need to make new spacers. I originally made them and had it centered then I rebuilt the swing arm to a slightly different width so i need to make all new spacers for the swingarm and the wheel. This was just for the initil test
  10. #9
    Senior Member cruiser7734's Avatar
    Join Date
    Mar 2008
    Location
    Haines City fl
    Posts
    786
    Default
    Quote Originally Posted by imabass View Post
    Used? that is just scary
  11. #10
    Senior Member Xman/qc's Avatar
    Join Date
    Jan 2006
    Location
    Quebec Canada
    Posts
    1,322
    Default
    It look like easy to handle empty but if you put load in it ? In a tight area did it still easy to handle ?
  12. #11
    Join Date
    Feb 2009
    Location
    Alabama
    Posts
    244
    Default
    That just ain't right....
    But I guess you could use it instead of a tent... probably be a lot more comfortable than sleeping on the ground... but again... that just ain't right!
    2005 VTX1300R, Darkside and too much other crap to mention!
  13. #12
    Senior Member heffly's Avatar
    Join Date
    Apr 2011
    Location
    South
    Posts
    3,952
    Default
    Sicka$$ Yankees. Geez I just cant see pullin that, hell I am trying to stay away from one dont need it following me,,lol
  14. #13
    Join Date
    Oct 2010
    Location
    Largo, Florida
    Posts
    150
    Default
    How will the hitch keep the trailer from tipping over?
    '04 1300 C, Michelin HE 205/70/15
  15. #14
    Join Date
    Jan 2011
    Location
    Tulsa, OK
    Posts
    262
    Default
    Quote Originally Posted by pcdavis View Post
    That was my thought. Just take the gear out and cover it with a tarp and get a good night rest. It would be like a camper for the bike. The one that I found that was used was for display of bodies that were being creamated. Just hanging out in there for a couple of hours before going in the furnace.
  16. #15
    Seasoned Member VTX1300cnME's Avatar
    Join Date
    Feb 2008
    Location
    Southern Maine
    Posts
    7,743
    Default
    I see the one wheel having issues when loaded. Issues when parked, and issues when towing, if the load shifts. .
    I dunno. . seems like two wheels might be a better plan. Would you be able to maybe set two wheels set a foot or two apart under the frame?
    If you stay on the one wheel track, I'll be curious how it turns out. I'm clearly not engineer material, cuz it seems like it'd fail to me. . unless I'm missing something. . .
    Bub Club member #361
  17. #16
    Join Date
    Jan 2011
    Location
    Tulsa, OK
    Posts
    262
    Default
    Quote Originally Posted by smooth View Post
    Its all in the U joint. This is a U joint for a tractor PTO shaft. Example the drive shaft that would hook up a mower to the back of the tractor.
  18. #17
    Senior Member texasmike's Avatar
    Join Date
    Aug 2009
    Location
    el paso texas
    Posts
    5,326
    Default
    i've seen a guy around here that has one thats a smoker he takes it to partys and bike rallys and does the cookin on it pretty cool'
    texasmike
    1300c 8 degree rake, cobra pipes, c&c seat, darkside and lots more
  19. #18
    Join Date
    Nov 2003
    Location
    OREGON
    Posts
    2,316
    Default
    Very impressive. The best of luck to you on that build, I can't wait to see it when it is all complete and how well it handles for you.
  20. #19
    Join Date
    Feb 2009
    Location
    Alabama
    Posts
    244
    Default
    That's an interesting concept four your trailer... never seen one up close. Didn't really understand the u-joint concept until the picture. With the u-joint 'fixed' the trailer will lean exactly like the bike. Cool! I wonder how it affects the feel of the bike since when you lean you are forcing the trailer to lean as well... I wonder if you will even notice it??? Hmmm... Will the tail ever wag the dog?
    Please keep the pictures coming!
    Will you have some 'kickstands' or such to keep it upright when unattached to the bike? Something to assist with hooking it up? I bet that could be a struggle trying to slide the hitch in with the trailer leaning to match the bike. Might not be an issue at all... just thinking out loud.
  21. #20
    Join Date
    Jan 2011
    Location
    Tulsa, OK
    Posts
    262
    Default
    Not sure yet until i try it out. more of trial and error since its all homemade and I have never used one before. From what I have read, people love the one wheel trailer since it leans and tracks behind the bike well it is ideal for curves vs the tradition 2 wheel trailer.
  22. #21
    Senior Member SCteach's Avatar
    Join Date
    Feb 2009
    Location
    Charleston, SC
    Posts
    1,823
    Default
    That is a pretty cool design that you have going. My only question is why didn't you use aluminum instead of steal? I also am curious about the loads you add and the concern for balance with only one wheel. Seems like a lot of wieght/torque to the bike where connected when standing it up from the side stand as well. What kind of cover will you have for the wheel since it is inside and can kick up road debris onto your items inside.
    Candy red 05 1300C-Sold
    A-10 Thunderbolt paint 03 1800R, PCIII, Reinhardt pipes, Tornado intake, Dyno'd, PAIR mod, ultimateX lowrider seat, ISO grips w/boss, brake away cruise.
    01 Harley Road Glide Screaming Eagle
  23. #22
    Senior Member kodiak536's Avatar
    Join Date
    Jul 2010
    Location
    West Valley, Arizona
    Posts
    1,131
    Question My thoughts exactly...
    Quote Originally Posted by SCteach View Post
    When you complete this project, what would you estimate the total weight of the trailer will be unloaded?
    What capacity(carrying load) would you expect fully loaded?
    With what looked to be a 2" steel square tubing for frame, I'm guessing that the gas mileage will take a substantial hit in your wallet when it's fully loaded???
    Good concept regardless
    I've been toying with the trailer idea for a while and I'm sure to monitor your progress and the results on the road.
    Keep us posted all the way
    “Better to remain silent and be thought a fool than to speak out and remove all doubt.”
    “America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.”
    Abe Lincoln
  24. #23
    Senior Member drtrider's Avatar
    Join Date
    Apr 2005
    Location
    lasalle-peru illinois
    Posts
    5,297
    Default
    Same question I was going to ask.
    2003 c cobra floorboards-memphis windshield-roadhouse shorty
  25. #24
    Senior Member Philscbx's Avatar
    Join Date
    Jun 2004
    Location
    Mpls, Mn
    Posts
    9,838
    Default
    For one wheel, I'd want very low CG, boat bottom shape.
    Anything acting top heavy like a loaded wheel barrel, is it going
    to take me down at a stop sign?
    Now fight both machine and trailer back up?
    Maybe air assisted landing gear to get vertical?
    Aluminum canoe shortened & chrome molly hardware sitting an inch
    off the ground is one I might do with motorcycle wheels with brakes.
    Hope the best, and way more guts than me.
  26. #25
    Senior Member Classic Rider's Avatar
    Join Date
    Dec 2009
    Location
    Oklahoma near Norman
    Posts
    659
    Default
    I'm just wondering whether one little scooter wheel is going to be sturdy enough for the weight and stresses? Guess we'll find out.
  27. #26
    Senior Member snush's Avatar
    Join Date
    Jul 2004
    Location
    Dayton,Ky.
    Posts
    1,413
    Default
    How are you going to beef up the bike suspension ? That trailer is looking good, but I'll bet it will top out at over 350 lbs. unloaded.
    SNUSH
    I don't sweat the petty things,But I do pet the sweaty things.
  28. #27
    Join Date
    Feb 2008
    Location
    St. Pete Florida
    Posts
    4,176
    Default
    Really killing me, want to see how this works out. Lots of different views. , Smitt
  29. #28
    Senior Member Kealii's Avatar
    Join Date
    Dec 2008
    Location
    Providence Forge, VA
    Posts
    326
    Default
    I think this is a very good idea in thinking out of the box. Yes, i'm very curious to find out how it handles. The one wheel tracking while moving is a good idea because it'll be in the same plane as the bike, but i wonder about the mechanics in weight balance while stopped, lateral weight shift and counter balance and steering in a turn.
    07 VTX1300C, Hondaline Sissybar & Rack, Saddlebags, Kuryakyn Acc. Switch Assm, Kuryakyn GranTour Travel Bag, National Cycle Switchblade-Chopped, Stebel Horn, Cobra Fatty Bars, Kuryakyn Aux Lights, Mustang Seat, Cobra Slash Cuts, Kewl Risers, SpeedDRD corrected Speedo at -06.8
  30. #29
    Join Date
    Jan 2011
    Location
    Tulsa, OK
    Posts
    262
    Default
    It is currently about 100 pounds. including wheel, suspension, and tounge. It was 84 pounds before adding the tounge. My dad has a high $ digital scale in his garage that I used. Weight was a concern when i was building. I built it from the thin 1x2 steel tubing because it was free and for me it is a lot easier for me to weld steel vs aluminum. I am expecting it to weigh about 130-140 pounds complete.
    I will add a lightweight track down both sides on the inside to secure the goods. I will cover the trailer with pine. I am leaning towards using pine flooring and planing it down fairly thin. The finishing it in a waterproof varnish. My dad has a full wood shop so woodworking tools and experience is no problem. Plan to attach the boards to the steel frame with some countersunk stainless fasteners.
    The scooter tire is rated for 330 pounds. I will likely replace it with a regular trailer tire.
    I am not expecing to pull heavy loads with this even though I think it could easily handle it. The widest section i will fill with sleeping bags, pillows, etc because that area will cause the most torque when leaning the bike in turns.
    There are a few places that make one wheel MC trailers and they have a hefty price tag.
  31. #30
    Join Date
    Jul 2004
    Location
    Dayton,Ky.
    Posts
    1,413
    Default
    Quote Originally Posted by Kealii View Post
    One wheeled trailers are nothing new. I've had one for 10 years now. Mine is about the size of a 30 gal. garbage can. Frame is made with 1X1 steel and a fiberglass body. It weighs in at about 75 lbs. empty.
    www.uni-go.com When we get to our motel, I just un hitch it and roll it right into my room.
    SNUSH
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
