Vance and Hines Bigshots
+ Reply to Thread
Results 1 to 4 of 4
Thread: Vance and Hines Bigshots
  1. #1
    Member
    Join Date
    Feb 2010
    Location
    Northern WI
    Posts
    50
    Default Vance and Hines Bigshots
    I just bought some used V&H Bigshots that were on a 2006 S Retro, I own a 2006 C. My question is do I need to remove the heat shields and install per instructions or should I leave them bolted together like he took them off and expect them to bolt up correctly on my bike? I also understand that this model pipe came with the quiet baffles, is that correct? Thanks for the help, Tim
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member MR VTX's Avatar
    Join Date
    Nov 2003
    Location
    Magnolia, TX
    Posts
    11,475
    Default
    Tim, you should be able to just leave them as they are and mount them. I got some Bigshots that were used and mounted them up without taking off the heatshields.
  4. #3
    Senior Member xblue's Avatar
    Join Date
    Oct 2008
    Location
    Kissimmee, Florida
    Posts
    1,271
    Default
    Should be able to leave heat shields on.
    Don't know if the ones for the 1300R will fit over to the 1300C, I think the bracket are different but I might be wrong.
    As far as baffles is concerned:
    Quiet Baffles have a one closed end and about 12" long
    Regular Baffles are open on both sides, straight through and also about 12" long
    Take a flashlight and look down your pipes and if you see straight through, you got the regular ones.
    Look at this thread as well
    http://www.vtxoa.com/forums/showthread.php?t=301332
    I have the quiet baffles and like the sound unfortunately since I went down in March, my bottom shield got road rash so I am looking into buying just the shield or buying a whole different exhaust.
    Hope this helps
    Hope this helps
  5. #4
    Join Date
    Dec 2010
    Location
    Tamarac, FL
    Posts
    275
    Default
    I left my heat shields on as well.
    Make sure you have all the parts.. I was missing the mounting bracket.. $42 from V&H.
    they are a tricky pair of sons-a to get lined up, but well worth it.
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
