rattling when hit bumps??
+ Reply to Thread
Results 1 to 14 of 14
Thread: rattling when hit bumps??
  1. #1
    Senior Member CAMOEDTJ's Avatar
    Join Date
    Sep 2010
    Location
    INDIANA, GREENWOOD
    Posts
    322
    Default rattling when hit bumps??
    hey all i have recently developed a sound coming from the rear of the bike.i notice when i hit some pretty good bumps i hear some kind of noise like something is loose..i checked my shock bolts and they seem pretty tight. also checked exhaust and all seems well. i do and can feel a little sometnig in the floor boards like something is loose but it dosent feel like the boards are loose if that makes sence..06 1800n.thanks
    06 1800n2 titanium
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member Kalten's Avatar
    Join Date
    Jul 2010
    Location
    Marysville
    Posts
    1,890
    Default
    are your shock bushings shot? If the bolt is not centered in the shock eye then they need to be replaced. I don't know where the picture is but someone will be along shortly with it.
    Woody's fairing, Parrot Asteroid, Rockford Fosgate 300x4 and Polk db521 speakers. All mounted and wired. Needs paint!
  4. #3
    Senior Member Gsebring's Avatar
    Join Date
    Aug 2010
    Location
    Houston
    Posts
    158
    Default Re
    I found mine to be from the cover under the key on left side, little o rings wore out
  5. #4
    Join Date
    Sep 2010
    Location
    INDIANA, GREENWOOD
    Posts
    322
    Default
    Quote Originally Posted by Kalten View Post
    i did notice that one of the bolts on the upper shock did not appear to be directly centered into or through the bushing..kinda looked like it was lopsided or somethin.
    06 1800n2 titanium
  6. #5
    Member
    Join Date
    Jul 2011
    Location
    Ontario Canada
    Posts
    57
    Default
    Try washing it had same problem (front fender after I painted it) took 5 sec. to find
  7. #6
    Junior Member
    Join Date
    Mar 2011
    Location
    Atlanta
    Posts
    28
    Default rattle
    My helmet lock always comes loose and rattles when I hit a bump.
  8. #7
    Senior Member Tiger66's Avatar
    Join Date
    Jul 2008
    Location
    Iowa
    Posts
    580
    Default
    I had the same type of "rattle". It sounded like a metal part was loose somewhere at the rear of the bike. Checked all bolts......nothing found. Finally replaced the shock bushings after reading some comments here on the forum and that took care of the problem.
    2005 1300R, 2007 1800T2
    Viet Nam Veteran (Medical Corps and Engineering Corps)
  9. #8
    Join Date
    Jun 2008
    Location
    usa
    Posts
    3,565
    Default
    Quote Originally Posted by CAMOEDTJ View Post
    http://www.vtxoa.com/forums/showthre...shock+bushings
  10. #9
    Senior Member dirtstiff's X's Avatar
    Join Date
    Aug 2007
    Location
    NW Orygone
    Posts
    1,273
    Default
    Saddle bag brackets?
    2005 VTX1800R Spec 2 Titanium Pearl
    2013 F6B Deluxe - Black - http://hondaf6b.com/album.php?albumid=106
    RIP JDJ / You will be missed brother, but never forgotten
  11. #10
    Senior Member fastspek's Avatar
    Join Date
    Jan 2006
    Location
    Belgium(Europe)
    Posts
    1,197
    Default
    Some load?
    President MC Bourgondische Slakken: http://www.mc-bgs.com/
    2003 VTX 1800C (forever)
    2002 HD FLSTF since 07/2008
    " Today you raised more questions than giving answers "
  12. #11
    Join Date
    Dec 2003
    Location
    panama city florida
    Posts
    241
    Default
    i vote on the shock bushing .there are better replacements for the bushings that can be used.there are threads that will tell where to get them.the shock bushings can cause other problems too,like front end wobble.i was in a curve about 5 years ago on another vtx that i owned and i had a wobble that put me in a swampy area and in the hospital.afterward i found out that the bushings could have been the problem.sure enough they were shot.when i bought this used vtx about 3 months ago it was one of the first things i checked and sure enough they were gone also.i replaced with the hard vinyl ones and i think that will solve the problem.i believe i got them from mcmaster carr or somewhere like that.ive done so much to this bike that i cant keep up with it all.but after a broke back and sternum and broke scapula i think its worth the added cost to replace them.
  13. #12
    Join Date
    Dec 2003
    Location
    panama city florida
    Posts
    241
    Default
    btw after i replaced them on the first bike i never had the wobble problem again.
  14. #13
    Junior Member
    Join Date
    Nov 2006
    Location
    TUCSON, ARIZONA
    Posts
    5
    Default
    I had the rear passanger pillon bolt come loose which made quite a rattle when hitting bumbs. May be worth a check.
  15. #14
    Join Date
    Sep 2010
    Location
    INDIANA, GREENWOOD
    Posts
    322
    Default
    Yeah I replaced my shock bushings with the newergreen ones that Honda had for the c model, it didn't stop the rattling but did notice a big improvement in the handling of the bike.i got her tore all apart right now for paint and didn't notice any loose bolts holding on the fenders intact it took a impact driver to get em all out. So I don't have a clue what it could be.
    06 1800n2 titanium
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
