Adjusting the Clutch on an 1800R
+ Reply to Thread
Results 1 to 13 of 13
Thread: Adjusting the Clutch on an 1800R
  1. #1
    Senior Member Smack's Avatar
    Join Date
    Aug 2004
    Location
    Boston, MA
    Posts
    833
    Default Adjusting the Clutch on an 1800R
    Searched first but did not find anything specific to adjusting this clutch.
    I have almost 1800 miles my Retro and I have noticed the clutch seems to engage farther out than I would like. In other words, I do not hit the friction zone until I am almost all the way off the clutch - I would like it to engage sooner rather than later like it is doing now.
    Is this a difficult adjustment?
    Thanks in advance.
    "Willie G didn't bend me over!"
    ________________________________
    03 Black VTX 1800 Retro
    NC Highway Bars
    Valk Kury Grips
    Honda Studded Tank Panel
    Kisan TailBlazer
    Neo Retro Light Bar
    Ultimate Big Boy Studded
    Hondaline Studded Bags
    Hondaline Windshield
    Coyote Hinge, Palladin Bars with Kuryakyn Pegs
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    Nov 2003
    Location
    Missouri
    Posts
    371
    Default
    The clutch is hydraulic, it uses a hydraulic cylinder similair to the brake cylinders. There,s a fluid line that runs from your handle bar control to the clutch push rod on the left side of the bike. Therefore there are no cables or adjustable linkage to allow adjustment,
  4. #3
    Join Date
    Nov 2003
    Posts
    1,830
    Default
    nope no adjustment on it. And wih 1800 miles on it I don't think it would be worn out yet. did you check you fluid level? A freind just had a clutch put in (BY A STEELER) when he stoped on my left at a red light I could see his clutch fluid sight glass was empty. I asked him how's the new clutch working? He wasn't shure yet. So I pulled over and looked closer at his bike and shure enough it was way low from the dealer.
  5. #4
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    57,965
    Default
    Agree with both of the above posts, no adjustment on hydraulic clutch.
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  6. #5
    Join Date
    Nov 2003
    Location
    TX, Allen
    Posts
    2,324
    Default
    Quote Originally Posted by Chicago-Spike
    Not quite true, Spike old chap... there are no EASY adjustments. You can do one of two things, tho....
    Note that there is a small pin that sits in a bushing in the lever. You can shorten the pin or drill the hole a little deeper in the bushing. I took the bushing route as it appears cheaper to replace if I screwed up.
    The seat pin mod "inventor".
    First with the Dakota Digital 5000 dual set-up
    2008 Can-Am Spyder
    1998 Yellow Honda Valkyrie
  7. #6
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    57,965
    Default
    You got me ataDude! No easy ways to improve the position of the lever.
    2002 VTX1800 C
  8. #7
    Join Date
    Aug 2004
    Location
    Boston, MA
    Posts
    833
    Default
    Well that kind of blows - no way to adjust the feel of the clutch? My fluid is full and it seems that the friction zone is too far out - guess I will have to get used to it. I would like it to start grabbing earlier than it does now.
    NC Highway Bars
    Valk Kury Grips
    Kisan TailBlazer
    Neo Retro Light Bar
  9. #8
    Join Date
    Nov 2003
    Location
    Southeast Texas
    Posts
    526
    Default
    Just for grins, try bleeding your clutch first.
  10. #9
    Member
    Join Date
    Aug 2004
    Location
    Fort Smith, AR Area
    Posts
    52
    Default
    Don't the Barnett Springs engage a bit sooner?
    2002 VTX 1800S. V&H Pipes, Memphis Shade, Kury ISO Grips with Kury Stiletto Spikes, Kury Stiletto Passenger Pegs, Cobra Engine Guard, Kury Stiletto Highway Pegs, Kury Elipse Mirrors, Kury Chrome Levers, Kury LED Spark Plug Covers, Clear Lenses, Kury License Plate Holder
  11. #10
    Join Date
    Aug 2004
    Location
    Paragould, Ar
    Posts
    112
    Default
    If you changed to braded lines wouldn't that help just a little since you wouldn't have line expansion like you do with the rubber ones??????
    Orange VTX 1800c
    LED lighting kit, Vertical mount license plate.
    Every soldier is an Army of One but together we are an Army of Many.
    Gotta love that Candy Orange!!!!!!
  12. #11
    Member
    Join Date
    Sep 2004
    Location
    Snyder,Tx
    Posts
    61
    Default
    I had a 02 Mean Streak that did the same thing about 10k, I talked to Johnny Cheese Performanche shop in Austin, Tx and he said that the clutches were getting thin and that was normal. He said there was a way of testing the clutches to see how thing they were by putting some weight on them and measuring how tall the stack was. You may email him and see if he has any ideas about your problem. johnnycheese@sbcglobal.net
    03 1800 R
  13. #12
    Member
    Join Date
    Aug 2004
    Location
    Lodi, WI
    Posts
    55
    Default
    I'm not a tech guy, but I think there is a simple solution to his problem that wouldn't cost more than a clutch lever if it failed. The problem is finding someone to heat and bend the lever handle closer to the handlebar.
    Good things happen to people who do good things.....Santa
    2002/1800S/IBlue....H-lightbar&windshield...Kury-ISO+TB+levers+mirrors+covers...Palladin EG....Rivco risers
  14. #13
    Join Date
    Dec 2003
    Location
    rapid city Sd
    Posts
    9,766
    Default
    You might check if the clutch lever off some other models will work. The brake lever on my CBR is adjustable and I think the brake and clutch on my VFR were both adjustable, but I can't remember for sure. They do bend fairly easily if you want to go that route.
    Never put your motorcycle where your brain hasn't already been.
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
