Stalling
+ Reply to Thread
Results 1 to 3 of 3
Thread: Stalling
  1. #1
    Senior Member ewcaron's Avatar
    Join Date
    Oct 2010
    Location
    richmond, virginia
    Posts
    501
    Default Stalling
    My bike stall from time to time, as if it were out of gas. Fuel filter maybe? I bought it last September is an 04 with 7600 mile. It now has 14,400.
    2004 1300s GOD GAVE US THE RIGHT TO RIDE THE HIGHWAYS AND BARE ARMS.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member RandyHut's Avatar
    Join Date
    Jul 2010
    Location
    Troy Ohio Area
    Posts
    823
    Default
    Check to easy things first:
    Battery Connections, Clean and Tight(wrench, not screw driver)
    Ground Connections, same as above.
    Check ECM wires while at battery, green and black known to break
    Check Vacuum lines for cracks
    Could be Petcock going bad. Check it by applying vacuum and make sure it flows fuel freely.
    Yes could be rust or junk in tank filter
    Could be pinched line at right rear of tank -remove gas cap and listen for sucking sound.
    2005 VTX-1300R PAIR done, Stock FURY Pipes, Decapped Airbox, K&N Filter, #210 Main Jet, #58 Pilot Scar Mod with 1 shims, AF @1.875 turns. 10 Min AF Adjuster, All Balls, Nylon Shock Bushings, 1800F Risers, Avon Front w/Dyna Beads 205/70/15 Grabber UHP rear w/Airsoft Pellets, J&P $40 Passenger Floor Boards, LED Red Run/Stop Lights in Yellow lens, Rotella T6 Synthetic 5-40w Ultimate Seats! Headlight Relay
  4. #3
    Senior Member Donut's Avatar
    Join Date
    Jan 2005
    Location
    Coloma, Mi. MixRider Member
    Posts
    6,201
    Default
    Is your Idle set too low. X's have to idle higher to maintain proper oil pressure than HD's.
    Doug
    Donut Doug
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
