Oil filter
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 30 of 33
Thread: Oil filter
  1. #1
    Join Date
    Mar 2009
    Location
    Conroe, Texas
    Posts
    105
    Default Oil filter
    Has anybody used the fram oil filter--is it as good as honda filter? About half price of honda--any feedback is appreciated
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member soflvtx's Avatar
    Join Date
    Apr 2010
    Location
    South Florida
    Posts
    231
    Default ...
    I use the supertech from walmart. Change my oil every 3000 and I have 19500 on it now. Never had any issue.
  4. #3
    Senior Member Jon's1800VTXC's Avatar
    Join Date
    Aug 2004
    Location
    Seattle/Everett (AZ in my heart)
    Posts
    15,471
    Default
    Fram filters aren't as good as they used to be. I would recomend Bosch at about 7.50 each, you can use a 3300 or a 3323 (part #s)
    Why is common sense not so common
    Why doesn't P.E.T.A. ever attack a biker
  5. #4
    Senior Member akuser47's Avatar
    Join Date
    Apr 2010
    Location
    hancock county,Ohio
    Posts
    477
    Default
    I use a prulator L14612 for the classic and you can upgrade to better filter media with a pure one same number in that series! These have great reviews and can be had at advanced auto. They are car filters that are the same size as the fram cycle filter ph6017a. They work I have been useing them! This link should show you a cut away and review of filters for our bikes this is what helped me decide! scroll down to honda filters and read!
    http://www.calsci.com/motorcycleinfo/FilterStudy.html
    Live Free, Ride Free, Or die Fighting for the Right to do so!
  6. #5
    Join Date
    Mar 2009
    Location
    Conroe, Texas
    Posts
    105
    Default oil filter
    the fram filter was all my autozone had to offer--guess i better look @ other filters
  7. #6
    Join Date
    Aug 2004
    Location
    North Carolina
    Posts
    6,772
    Default
    Here is a very informative site on oil filters.
    http://www.calsci.com/motorcycleinfo/FilterXRef.html
    Plenty of choices for "Size #5".
    Si vis pacem, para bellum.
  8. #7
    Join Date
    Mar 2011
    Location
    NW Arkansas
    Posts
    384
    Default
    Just say no to Fram.
    I use the Bosch 3300.
  9. #8
    Join Date
    May 2009
    Location
    canyon, tx
    Posts
    1,170
    Default
    bosch for sure, I personally like the longer 3.25" one
    http://www.vtxoa.com/forums/showthre...ht=oil+filters
    this is the link to all the different filters that members have compiled. its down the page about 1/2 way.
    Canyon, tx
    2003 VTX 1800R
    HID headlight, psycho accent lights, how to section has a cruise control
    Something Something Something DARKSIDE michelin hydroedge 205/65 R16
    sent from my R2D2 unit on TATOOINE
  10. #9
    Senior Member scup's Avatar
    Join Date
    Sep 2005
    Location
    NorthWest NJ, W.Haven, CT
    Posts
    3,506
    Default
    Quote Originally Posted by danater View Post
    I personally hate the 3.25" filter... it's a pita to work with on bikes w/ the coolent tank under there
    but on Bosch & Purolator One filters... I use the Puro One as there easier for me to locate
    "The American Paratrooper exists to give the enemy soldier the best chance to die for his country." ~~ General George S Patton.
    '03 1800S '04 1300S
  11. #10
    Senior Member Dave 13's Avatar
    Join Date
    Jul 2004
    Location
    Jacksonville FL
    Posts
    538
    Default
    Quote Originally Posted by soflvtx View Post
    supertech from walmart good for me also
    Dave
    05 1800N Black Go Fast BUT don't get in a hurry
    Are you a whosoever? <><
    John 3:16
  12. #11
    Join Date
    Jun 2011
    Location
    JACKSONVILLE FL
    Posts
    1,167
    Default
    Quote Originally Posted by scup View Post
    Scup, I had no problem using that 3.25 supertech on mine and was curious why you had a problem. Did you use the strap wrench to remove?
    maurice
    VTX 1800t 2007
  13. #12
    Senior Member NDAna's Avatar
    Join Date
    Aug 2005
    Location
    Seattle Metro, U.S.A.
    Posts
    12,836
    Default
    My coolant tank isn't even remotely close to the oil filter? 04 1800 C.
    Nothing but 3323s for me.
    Sam/NDAna #15542 IB#38401 '04 1800 C, HID, Audiovox Cruise, 2xDarkSide & enough other stuff to keep me comfortable. Now have H4 HID & LED headlights available NDs.HIDs@gmail.com "Can you see me now?" For DarkSide info go here http://mcdarksiders.forumotion.com
  14. #13
    Join Date
    Mar 2011
    Location
    NW Arkansas
    Posts
    384
    Default
    I tried to put the 3323 on mine. Would have been able to start buying my filters in bulk. That's the same filter my Polaris uses. There was no way it would go on without removing the coolant res. though.
  15. #14
    Member halfpricevtx1800's Avatar
    Join Date
    Dec 2010
    Location
    Virginia Beach,VA
    Posts
    70
    Default
    supertech st6607 on mine
    2004 VTX 1800C, PCIII usb (current map M109-009), V&H Bigshots baffles removed, Desmog, Black T-Motorsports Spike Intake(ebay spike) 200 Battlax rear, Elite3 front, Willie& Max bags, grip end key mod
  16. #15
    Senior Member HDKLR's Avatar
    Join Date
    Jan 2004
    Location
    Appleton, Swissconsin
    Posts
    4,169
    Default
    Yes, with anything longer than the stock filter, you have to move the coolant reservoir to get it in and out. You can spin it on and off, you just can't actually remove it. I was using Motorcraft filters, but switched to the shorter (stock length) AC Delco. I also use the Pure ONE filters.
    Riding like my ass is on fire since 1982.
  17. #16
    Join Date
    Jun 2011
    Location
    JACKSONVILLE FL
    Posts
    1,167
    Default
    maybe this is related to model, yr since some of us use the longer one with no problem. I first couldn't remove it because of a different filter remover, some kind of plastic cover that was too thick to fit between C. tank and filter, but then got the strap wrench with a fairly thin strap. Worked great.
    maurice
    VTX 1800t 2007
  18. #17
    Junior Member jore346's Avatar
    Join Date
    May 2011
    Location
    Schertz, Texas
    Posts
    25
    Default wix filter
    I haven't heard anyone mention using a wix filter. Went to get a bosch tonight and ORielly's does not carry them. It cross referenced that a Wix filter would work measured the same length, just wondering what experiences y'all have had with them?
    Thanks.
  19. #18
    Join Date
    Aug 2005
    Location
    Posts
    12,836
    Default
    Quote Originally Posted by jore346 View Post
    Thanks.
    Odd they carry them up here. Wix is adequate certainly.
  20. #19
    Join Date
    May 2009
    Location
    canyon, tx
    Posts
    1,170
    Default
    Quote Originally Posted by FISTer View Post
    actually I have my coolant tank right by the rear tire underneath were it is normally from the factory. I have no problem putting the long ones on because you can actually angle it on for a lil bit of play and itll be just fine. since I found I could do that with no damage to the filter ive changed over to bosch 3323 exclusively and I change my oil once a month.
    Canyon, tx
    2003 VTX 1800R
  21. #20
    Join Date
    Aug 2005
    Location
    Posts
    12,836
    Default
    Just out of curiosity - why every month? You put on 5-8K every month?
  22. #21
    Junior Member ShawnShady's Avatar
    Join Date
    Jul 2011
    Location
    New Hampshire
    Posts
    26
    Default
    Thanks.
    Wix is the way to go. Great filters and will be my choice when I do my first oil change on the bike. Stay away from Fram.
  23. #22
    Join Date
    Aug 2010
    Location
    WI
    Posts
    894
    Default
    i like the k&N filters, they even have a little nut on the end so you can use a wrench to get it off instead of dinking with a strap wrench and i figure for a once a year oil change i can splurge the extra couple bucks (and i don't have deep pockets either )
    You can't take it with you...
  24. #23
    Join Date
    May 2009
    Location
    canyon, tx
    Posts
    1,170
    Default
    Quote Originally Posted by NDAna View Post
    I put 1500 to 2000 miles a month on it, 1/2 in town 1/2 highway. I figure as black as the oil is when it comes out, that I better change it every month just to make sure. I cannot afford to have the bike down for more than 4 days at a time, my truck cost 3x times the gas lol.
    I use lucas treatment in it also for that added punch
    im also using 18 wheeler heavy duty oil
    Canyon, tx
    2003 VTX 1800R
  25. #24
    Join Date
    Aug 2005
    Location
    Posts
    12,836
    Default
    FWIW black oil means it is doing its job. For economy- maybe not an issue and for environment- I'd go to at least every other month. Right now you have piece of mind but the only real thing being accomplished is making the oil co richer.
  26. #25
    Senior Member dan3's Avatar
    Join Date
    Aug 2006
    Location
    MD burbs of Baltimore and DC
    Posts
    12,597
    Default
    Bosch 3300 here. Easy on and off.
    Dan
  27. #26
    Senior Member Justa_Poser's Avatar
    Join Date
    Oct 2005
    Location
    Missouri
    Posts
    4,808
    Default
    Lucas oil treatment? If so, please be aware that Lucas oil treatment is nothing more than mineral oil with virtually no additives. The net result is to lessen the overall additive package of the other motor oil.
    You've probably seen that little crank thingy with the little gears. The one with the Lucas oil treatment shows the oil with substantially more "cling" and "climb". However, this is a trait that also causes more foaming and you certainly wouldn't want that, especailly in a shared sump engine that shares the motor oil with the transmission.
    My two cents.
    Your mileage may vary
  28. #27
    Join Date
    Nov 2008
    Location
    Newark, NJ
    Posts
    1,501
    Default
    The regular (orange) Fram filters use a cardboard endcap on the filter media. The others mentioned in this thread use a stamped steel end cap. Supposedly (I have never known anyone who's had it happen) the cardboard can rupture, disintegrate and send that material out into the engine. I used to use them until I became aware of the cardboard contruction. Figure why take that chance. I now use either the Purolator, Bosch, or Supertech. And to 'danater', holy cow I thought I was an oil change nut (I change out at 3500 miles) but, every month!? With only 1500 to 2000 miles. Wow! I have used the longer filters on my '02, it is a bit of a squeeze to get it off and on but, I can do it without moving the overflow tank.
  29. #28
    Join Date
    Oct 2005
    Location
    Missouri
    Posts
    4,808
    Default
    One thing about the Fram that turns me away is the price.
    I cut open a Wal-Mart SuperTech filter and it is much better constructed and much cheaper.
    Same goes for the Purolator "Classic" filters.
    In MY mind, the Fram is over-advertised/marketed and under-engineered. Basically a cheap filter. Not saying that they aren't adequate - just saying that there are better filters available for less money.
  30. #29
    Senior Member Trackman's Avatar
    Join Date
    Jun 2007
    Location
    1000 Islands, Brockville
    Posts
    1,043
    Default
    I was using purolator filters. But I found out the by-pass valve opens at 14 psi. Where the Honda is 10 psi. Not an exact match. It might not make a difference. I don't know. Other car filters may be different also. I just know about the purolators as I was using them. They are a good filter. I use them on my other vehicles.
    For anyone that does not know about the by-pass valve. It is a valve in the filter
    designed to open when the difference in pressure across the filter
    reaches 10 pounds or more. It is to ensure oil delivery if a filter is too
    restricted or in cases where the engine may be at high revs creating a larger pressure drop across the filter. Better to get unfiltered oil than not enough.
    2005 F2, Black Cherry,Cobra speedster,Kuryakyn Pro, PC3
  31. #30
    Super Moderator mneccspv's Avatar
    Join Date
    Feb 2009
    Location
    Portland, TN
    Posts
    1,312
    Default
    Does the 13 and 18 use the same filter? what is the walmart filter again? st14610?
    Does anyone get their oild from wally world? Which one?
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
