seized lug nuts. HELP.
+ Reply to Thread
Results 1 to 14 of 14
Thread: seized lug nuts. HELP.
  1. #1
    Senior Member Fr8Hauler's Avatar
    Join Date
    Nov 2003
    Location
    Pearl River, La.
    Posts
    1,567
    Default seized lug nuts. HELP.
    My son has an 03 Eclipse. Some time back he had a shop install some tires on new rims. They didn't have "standard" lugs, so they installed some type of "torx" nut. They are the female, and of course the tool to remove it is male.
    Don't know the correct terminology.
    Well, they have seized onto the lugs. One shop has broken 3 of the torx trying to remove them, though they did get the wheel off to repair the tire.
    He brought it back again yesterday to try and get them all changed, but they couldn't remove any of the nuts.
    My question is, how do we get them off? I've searched on the net, but have not found any similar situations. ANY HELP WOULD BE APPRECIATED.
    Si vis pacem, para bellum
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member Sandman333's Avatar
    Join Date
    Jul 2004
    Location
    Mahomet, IL
    Posts
    7,108
    Default
    probably going to have to break the studs and replace them. Usually the studs will just pound out.
    There are no stupid questions,
    There's just a lot of inquisitive idiots.
  4. #3
    Senior Member madmax's Avatar
    Join Date
    Jul 2008
    Location
    reading,Pa
    Posts
    1,280
    Default
    also if aluminum wheels make sure you use ant-seize on threads and don't over tighten lug nuts
    Ride free ,always ride defensive as though your invisible to people around you2006 1300R
  5. #4
    Join Date
    Jul 2009
    Posts
    3,516
    Default
    I don't if this will help but try this and see.
    Drill a hole in the nut if you can and pump Wd-40/slick 50 or another liquid to seize nuts loose. Let it set and repeat .
    Get a small propane torch (Lowes,Home Depot) and heat up the nut and not the stud , heat expands metal and get the right tool on the nut.
    Like I said it is a shot in the dark but what have you got lose.
  6. #5
    Senior Pirate KeyWasted's Avatar
    Join Date
    Jan 2008
    Location
    Key West
    Posts
    6,600
    Default
    Most tire shops will have special impact gun socket tools for removing locking lug nuts you've lost the key to or broken. As do wheel thieves.
    2003 VTX1800 ARRRGH
    VTX BEATS HARLEY and Hitler is Pissed!
    http://www.break.com/usercontent/201...wasted-1912477
    Red Knights MC
    "343"
  7. #6
    Member monsterops's Avatar
    Join Date
    Mar 2011
    Location
    Iowa
    Posts
    92
    Default weld
    If you have enough space, and a wire welder, you can weld another lug nut, or 1/2" nut on the stuck nut. Make it a pretty good weld, then you can use a regular socke and air impact to remove it. Also the heat from welding may help loosen the original nut. Use wet rags around the area to keep from splatter and damage to wheel.
  8. #7
    Banned
    Join Date
    Mar 2010
    Location
    Feeling the Loveland, Colo
    Posts
    2,530
    Default
    Good advice from Key Wasted and monsterops.
    Oh, and next time, tell them to drop the 1" air impact and back away from the vehicle.
  9. #8
    Senior Member RoadDawg's Avatar
    Join Date
    Nov 2003
    Location
    Third Rock (just to the right of the moon)
    Posts
    3,140
    Default
    Spray on PB Blaster and let it sit for a few minutes... Then heat with a butane or propane torch for a few seconds and use a big wrench on it.
    Works for me...
    Darth RoadDawg
    Charter Member: Liberals Anonymous and, Red light in a Blue State...
    Tapatalk ads SUCK... Sent from my smokey fire pit with a wet blanket
  10. #9
    Senior Member lv2cruz's Avatar
    Join Date
    Jul 2008
    Location
    Nampa,Idaho
    Posts
    1,416
    Default
    Quote Originally Posted by KeyWasted View Post
    Yes, many tire shops do have specialty socket kits designed for the purpose of removing "locking" style or torx type lug nuts. As for removing the standard lug nuts, I have often used a large wrench that I could get some leverage on, such as a torque wrench or breaker bar, and at times would have to use a cheater bar with it as well. Had much success breaking the nuts loose by hand this way where an impact gun wasn't doing it. Very rare to have many of the lug nuts that tight, I wonder if they got cross threaded or were wrong size threads?
    EDIT: And as Black MtnMan said, step away from the impact gun when installing the lug nuts. Use a torque wrench for final tightening according to vehicle manufactures specs.
    2004 VTX1300S
  11. #10
    Join Date
    Jul 2008
    Location
    Nampa,Idaho
    Posts
    1,416
    Default
    Another tid-bit that may seem simple, but effective the majority of the time is to have a helper spin the wheel at the same time while running the impact gun. On the passenger side, spin the wheel forward. On the driver side spin the wheel backward.
    2004 VTX1300S
  12. #11
    Senior Member kf4ocj's Avatar
    Join Date
    Jan 2009
    Location
    dyersburg tenn.
    Posts
    1,031
    Default
    Quote Originally Posted by Sandman333 View Post
    Just about the easiest thing you can do,If I am not mistaken there is a rubber plug in the back plate that you take out to replace the lugs,go buy some replacement lugs and nuts twist the old ones of****ock them out and put in the new ones
  13. #12
    Banned
    Join Date
    Mar 2010
    Location
    Posts
    2,530
    Default
    Quote Originally Posted by kf4ocj View Post
    You can pound the lugs out, yes, but the stuck nuts won't fit through that hole. Oh...and you still need the wheel off. Sorry, no points.
  14. #13
    Join Date
    Jul 2004
    Location
    Mahomet, IL
    Posts
    7,108
    Default
    Quote Originally Posted by BlackMtnMan View Post
    If it's that hard to get them off, it's likely that the studs will be stripped or broken anyway. It's just a matter of force and the studs will break. Either way, their strength will be compromised and they need to be replaced. My guess is that the real problem is incorrect thread pitch on the lugs.
  15. #14
    Join Date
    Jan 2009
    Location
    dyersburg tenn.
    Posts
    1,031
    Default
    sorry i guess i should have expanded my idea,put a six point socket on the lug nut with a breaker bar,tighten it till it twist off,a lot easier than you think,then knock them out and replace
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
