Speed sensor for my vtx 1800
2K views 1 reply 2 participants last post by  Hans&Feet
#1 ·
The speedometer doesn't work a friend of mine say that there is a speed sensor near ignition key must be replaced. Anybody can help me to have the part no. Thx
#2 ·
There are some voltage measurements that can be done to verify if it is defective(usually is).
+12v and ground to the VSS, +5V pulses from the VSS when the rear wheel is turning.
http://i1185.photobucket.com/albums/z350/hans1300/1800 stuff/1800VSSserman19-9.png
http://i1185.photobucket.com/albums/z350/hans1300/1800 stuff/1800VSSserman19-10.png
http://i1185.photobucket.com/albums/z350/hans1300/1800 stuff/1800VSSlocMain-FIfuses.png
Also a 6pin connector in the front going to the speedo unit that should be checked.
10 37700-MCV-003
SENSOR ASSY., SPEED
$111.89 $73.85 Partzilla.com
