Results 1 to 4 of 4
Thread: TP Sensor
  1. #1
    Senior Member Dtoolman99's Avatar
    Join Date
    Nov 2003
    Location
    Texas
    Posts
    785
    Default TP Sensor
    Am I understanding this correctly,I have to buy a whole throttle body for a TP sensor?
    '03 1800R Darksider 140K+
  2. #2
    Join Date
    Jul 2008
    Location
    Chiang Mai, Thailand
    Posts
    1,267
    Default
    Quote Originally Posted by Dtoolman99 View Post
    You are correct.
  3. #3
    Senior Member Hans&Feet's Avatar
    Join Date
    Jun 2005
    Location
    Conyers/McDonough, GA
    Posts
    3,903
    Default
    Honda probably uses the same TPS on a few different machines. I did a search and Dorman has many OE# that use one of their part number. One Dorman part # for Honda TPS that range from 1989-2004
    http://www.dormanproducts.com/applic...SEName=911-753
    OE# if you can find one, cross reference to below. Nice pix also of all sides and connector.
    http://www.dormanproducts.com/c-865-...on-sensor.aspx
    If in doubt test the TPS as per 5-18 to 5-21 of service manual.
    I believe there is a small setup angle/voltage and that is why they do not sell them separate.
    I believe the aftermarket fuel controllers can be used to test/set TPS.
    2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back.
    140,557 VTX miles...​On 8th frt tire, 12th rear tire
    When you stop learning, you are dying.
    http://s1185.photobucket.com/profile/hans1300
  4. #4
    Senior Member blackdog1972's Avatar
    Join Date
    May 2009
    Location
    Weatherford, ok Illinois transplant
    Posts
    664
    Default
    If your are in need of one let me know I have a used throttle body with all the sensors.
    02 1800 C Cobra Drag slash cut K&N PCIII MTC clutch pair valve remove Darkside MHE 205/65/16
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not edit your posts
