Results 1 to 10 of 10
Thread: LED underglow
  1. #1
    Junior Member ndepin87's Avatar
    Join Date
    May 2011
    Location
    Lakeland, FL
    Posts
    21
    Default LED underglow
    SO i am thinking of putting some LED lights on the bottom of my bike for extra lighting while driving at night. I am an engineer but not an eletrical engineer ... that being said I don't know what i would need to wire it right. Thinking of getting something like the link at the bottom of this post. any help would be great.
    I know i am probably going to need to get a relay of some sort and wires but what else?
    THANKS FOR ANY HELP
    <http://www.ebay.com/itm/MOTORCYCLE-WHITE-LED-LIGHT-STRIP-Harley-Davidson-Sportster-fat-Dyna-Softail-HID-/270916128439?hash=item3f13dc0eb7&item=270916128439 &pt=Motorcycles_Parts_Accessories&vxp=mtr>
    Light travels faster than sound. This is why some people appear bright until you hear them speak.
  2. #2
    Pope "papa" of the VTXOA Chicago-Spike's Avatar
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    53,263
    Default
    Get some masking tape and a 9 volt battery. Tape up a pod in an area you think will look good and wire it up to the 9volt. Back away and see how it looks. If it is good, use the permanent tape, if it doesn't look so good, move it a try again.
    I started with the old Kuryakyn Spider Light kits. Added more Spider light kits, then some 3 LED pods and 5 LED pods from Custom Dynamics and finally a remote control key fob switch.
    I had them all over;
    4 pods under the tank
    1 pod under the airbox(had 1 pod INSIDE my old Hypercharger )
    1 five light pod on the fork lock shining on the front fender
    1 pod on the fan support shining on the front cylinder
    1 pod on the rear engine mount
    6 pods on the frame shining on the ground
    2 five light LED pods inside the rear fender shining onto the chrome rear wheel
    1 five LED pod on the battery box shining onto the chrome swingarm
    There was more, but I can;t think of where I had them. All on a remote control unit to turn them on from a distance
    Got them at http://www.customdynamics.com/index.htm add "VTXOA" in the coupon code box and get an extra 5% off
    DLP Sells Victory Too
    2002 VTX1800 C
  3. #3
    Senior Member Abe1800N's Avatar
    Join Date
    Aug 2011
    Location
    Findlay, Ohio
    Posts
    114
    Default
    Check out joeflorida.com. He has great kits, easy instructions and he sends you everything you need. I got the 120 light kit and I am very happy with it. PS-I'm an engineer too (ME). Pm me if you need additional help with the LEDs.
    2005 1800N spec3, Cruiser Performance VTX 1.5" Massive T-Bar, Vance & Hines Longshots, Mustang seat, Joe Florida white LEDs, more to come soon hopefully
  4. #4
    Join Date
    May 2009
    Location
    canyon, tx
    Posts
    1,096
    Default
    I have a total of 350 psycho led's from custom dynamics. I suggest you do anytype of placement at night (or clean dark garage) were you can see what the lights will look like. if you have a spare 12 volt battery laying around that would be great. LED's can only go one way. as in if you connect the negative to the positive side and the positive side to the negative youll burn the LED. if you get it from custom dynamics read the instructions and make sure to connect the proper wire to the proper terminal on the battery. use 2 conductor as a " rail " to hang your lights off of. Also if you do get LED's from ebay, I doubt you will be happy with the quality of them. some are good some are meh and some are just downright worthless. I know nothing about joeflorida but I can attest to the quality of custom dynamics.
    example.
    place your lights how you like using the extra 12volt battery and your test LED. I suggest you make the leads to a test LED about 4 foot long so you have plenty of wire to play with. Once that is done run 2 conductor (black and red) wires along a solid route not to close to your pipes and heat and all that. then just simply connect your LED's to the conductors. Make sure that the black is ground and the red is +12volt, and do NOT mix em up. or youll have some "interesting " fireworks.
    Stranded main conductors are best, make sure to solder all your connections and put the connections in a good shrink wrap. should look almost factory if you do it right.
    use a switch trigger if you don't get the wireless one.
    any other questions lemme know.
    Canyon, tx
    2003 VTX 1800R
    HID headlight, psycho accent lights, how to section has a cruise control
    Something Something Something DARKSIDE michelin hydroedge 205/65 R16
    sent from my R2D2 unit on TATOOINE
  5. #5
    Join Date
    May 2011
    Location
    Lakeland, FL
    Posts
    21
    Default
    So i think i will be going with Custom Dynamics (2) 4 LED pod (or possible 6) light kits ... i am assuming i need to also get one of the installation kits (which i believe has a switch)
    It looks like I should be able to hook both of the light together into the connectors provided in the installation kit ... where would be a good place to mount the switch?
  6. #6
    Senior Member 1badta95's Avatar
    Join Date
    Mar 2010
    Location
    Milwaukee Wi
    Posts
    1,306
    Default
    Quote Originally Posted by ndepin87 View Post
    I like to mount switches that i want to keep somewhat hidden, on the side cover. Not on the outside but on the small surface that faces towards the front of the bike
    220mm Tire Polished and Blacked out engine CP Punisher internally wired bars / Avon grips Accutronix forward controls Sumo X rear fender Long Boy front fender Arnott air ride Stretched seamless tank / Matt Hotch pop up gas cap/ FSD exhaust/ Thunder Manufacturing intake Sterling Magnum chromite cables and brake lines My Build Page: http://www.vtxoa.com/forums/showthre...-s-1300C-build
  7. #7
    Senior Member jeff hughes's Avatar
    Join Date
    Sep 2011
    Location
    Goshen indiana
    Posts
    175
    Default Lights
    I was thinking od adding about 6 lights to my bike... looks like I need to kick it up a notch.. Lol
  8. #8
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    53,263
    Default
    That's the beauty of most systems. You can start with a few and add more all the time. I didn't put all my lights on at one sitting. It was a few here and few there, etc....
    2002 VTX1800 C
  9. #9
    Senior Member TASSY5's Avatar
    Join Date
    Nov 2003
    Location
    FLOOD LANDS OF THE SOUTH New Orleans, Louisiana
    Posts
    4,279
    Default
    video in action
    http://s126.photobucket.com/albums/p...301_224704.mp4
    all custom dynamics lighting ORDERED and INSTALLED by BARE AT WWW.BAREASSCHOPPERS.COM
  10. #10
    Join Date
    May 2009
    Location
    canyon, tx
    Posts
    1,096
    Default
    I have my remote switch on my R plastic speedometer cover. Ive had other vtx riders come up and look and thought it was a stock switch.
    Canyon, tx
    2003 VTX 1800R
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
