been doin some reading gonna go with the new clutch gonna try reuse steels they have less then 5k on then just gonna scuff them up like on the you tube vid, and do a oil change. DLP sell the new 10.9 blots
I got my bolts from Biglry. The Honda Bolts are cool looking - but I don't think they are super durable.
I did shim my clutch .075 which is middle of the road. Have a good in/lb torque wrench on hand - a beam type works just fine. Don't forget Exhaust Gaskets.
My steels were just fine at 3k miles. You could see the pressure plate slip marks the best. The dimpled steels Honda uses mask the slip a little. Your mainly wanting to stay away from any (blue or blackened) hot spots or complete disk issues on the steels. Scuffing won't bring them back. The metal at those spots isn't like the rest of the surface anymore - think very hard and soft. If you have just light marking on the steels your likely gonna be fine. I had a good used set of steels ready to go just in case.
http://biglry.com/ClutchBoltKit.html
Just a guy named Dan reliving his childhood on a 800 lb Gorilla Bike!
2008 VTX 1800 F, VH Bigshots, Thunder Hurricane, PCIII, Desmog, ISO Grips w Throttle Boss, Mustang Seats, Kuryakyn Ergo Engine Guards w Silver Bullet Driving Lights, MTC Clutch
My first day out with the MTC ,I was gettin on it hard,and surprised when I hit second gear,
and the front end came off the ground.Never did that with the stock clutch...
2002 1800 RETRO SPOKE ILLUSION BLUE, SOME MODS
ANTI-DARKSIDE CRUSADER
You guys use Honda Bond or some other gasket maker for the side cover?
