How often should tires be balanced?
+ Reply to Thread
Results 1 to 10 of 10
Thread: How often should tires be balanced?
  1. #1
    Junior Member roadrash76's Avatar
    Join Date
    Apr 2012
    Location
    phoenix, az
    Posts
    18
    Default How often should tires be balanced?
    Greetings,
    I mounted new front and rear tires on my 1300C. Both were balanced, but my question is how often during the life of the tires should they be balanced? The front was easy enough to remove but the rear was a pain in the butt with the stock exhaust in the way of the large retaining nut for the rear axle. It took two of us to do it. For my cars I usually get them balanced about every 8,000 miles or sooner if I notice wobble at highway speeds.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member Titanium-X's Avatar
    Join Date
    Mar 2011
    Location
    Chattanooga, TN
    Posts
    1,657
    Default
    My original Dunlops lasted about 11K and were never rebalanced. They were smooth to the end. So far my Metzelers are smooth and have about 6K on them. I was wondering the same thing tonight because I had the air compressor out and decided to check all the pressures on my MC and vehicle tires. While looking at my wheels, I realized that they will need to come off for a polishing this winter and I'm concerned about disturbing the stick-on weights when I do it. Other than that you may be able to to get away with what you have until the tires are worn out.
  4. #3
    Senior Member mightywarrior72's Avatar
    Join Date
    Apr 2010
    Location
    Long Beach, Ca.
    Posts
    1,352
    Default
    Quote Originally Posted by roadrash76 View Post
    Greetings,
    I balance my tires everytime that I ride it. Actually my tires balance themselves. I use Dyna-Beads inside of the tires. Check this video.
    The earlier I get behind, the longer I will have to try and catch up.
    It doesn't take me all day to get nothing done; I can get nothing done by break time.
  5. #4
    Senior Member chuck_VTX F's Avatar
    Join Date
    Aug 2007
    Location
    Upper Right Ohio
    Posts
    4,900
    Default
    Tires, car of bike.
    should NEVER need redone.
    unless the weights fall off.
    if a tire gets out of balance, check for lost weights. otherwise there is DAMAGE to the tire.
    2005 VTX1800 "F" type II...... Silver Tribal .... 60,000 Miles, Purchased Feb, 2005.
    I am Right, ...................... because I am a lefty.................. I am retired,, .................and NO I will not fix your car...
    MTC clutch & springs.. K&N Air Filter. Garmin GPS.
  6. #5
    Join Date
    Apr 2012
    Location
    phoenix, az
    Posts
    18
    Default
    Quote Originally Posted by charlesmote View Post
    Tires, car of bike.
    you are right about car tires. I confused them with rotating them. When I get them rebalanced its because it's lost a weight. Thanks for the info.
  7. #6
    Senior Member steph's Avatar
    Join Date
    Dec 2008
    Location
    Ottawa, Canada
    Posts
    1,176
    Default
    When I got my bike, i had stockers on that had been factory balanced. Soon after, I installed the Avon 230/60-15 and it ran perfectly smooth without balancing. Last winter, I modded my bike even more and am now running Avon Venom front and Avon Cobra 250 rear and they both run perfect without balancing.
  8. #7
    Member
    Join Date
    Feb 2012
    Location
    Dayton Ohio
    Posts
    51
    Default
    Quote Originally Posted by mightywarrior72 View Post
    I agree. Use Dyno-Beads and you don't have to worry about weights flying off. They will keep your wheels balanced for the life of your tires, perfectly
  9. #8
    Senior Member vtx13rider's Avatar
    Join Date
    Jul 2004
    Location
    LaFayette, NY
    Posts
    698
    Default
    Quote Originally Posted by snowmon View Post
    What he said...
    [SIGPIC]
    It's not what you ride, but that you ride.
  10. #9
    Senior Member House O' Pain's Avatar
    Join Date
    Jul 2008
    Location
    Santa Barbara California where RED is the FASTEST color!
    Posts
    4,070
    Default Go Dyna Beads!
    +1 on using Dyna Beads.
    Unlike lead weights if your tire goes out of balance due to wear (e.g. 'cupping') the Dyna Beads will still balance the tire, but the lead weights will not. The beads are constantly correcting/maintaining balance.
    You can read more and/or buy some here:
    http://www.innovativebalancing.com/motorcycle.htm
    "A man's got to know his limitations" Clint Eastwood as Dirty Harry
    _______________________________________________
  11. #10
    Member
    Join Date
    Nov 2011
    Location
    Riverside, Ca
    Posts
    82
    Default
    I just installed new tires. DynoBeads all the way. I even convinced my lifelong Harley riding neighbor into using them. He'd never heard of them until I used on my Shadow Sabre at the beginning of the year. He's now a believer.
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
