brake pad spring?
+ Reply to Thread
Results 1 to 8 of 8
Thread: brake pad spring?
  1. #1
    Join Date
    Nov 2012
    Location
    north arkansas
    Posts
    140
    Default brake pad spring?
    changing the rear pads today and two small metal pieces fell out before i could note their location. they look like this... l_l with some edges for grabbing something and one has a longer piece sticking off of it. i couldn't find any areas that looked like they may have been stuck to. any help would be appreciated
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    58,418
    Default
    You need to put them in, they go in the center of the caliper and the pads rest inside that clip
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  4. #3
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    58,418
    Default
    They are called brake pad retaining clips. The put a slight pressure on the pads to keep them in place and from making noise
    2002 VTX1800 C
  5. #4
    Join Date
    Nov 2012
    Location
    north arkansas
    Posts
    140
    Default
    got a pdf file off of the net and found they are the pad retainers, but it broke and should only be one piece. got it put back together, just have to bleed it. thanks
    john
  6. #5
    Join Date
    Nov 2012
    Location
    north arkansas
    Posts
    140
    Default
    be easy on me, just got this bike a week or two ago and i'm starting to go through it. the back pads were down to metal and done slight damage to the rotor, going to run it with the new pads until tax time when i can get it in the shop for new fork springs/oil, front tire and get the rear splines greased up. it's an 02 1800c with 28k. ended it giving $2750 for the bike so i don't think i got hurt in the deal
  7. #6
    Join Date
    Nov 2012
    Location
    north arkansas
    Posts
    140
    Default
    while i'm on here i'll ask another pad question. the front pads look ok but i have a replacement set, my delima is i am hearing a brake pad noise from the front and if i hit a bump it seems louder until i hit another bump or squeez the front brake lever a time or two. any ideas? i plan on replacing the front pads in the next day or two and if it keeps it up i'll have it looked at when it's in the shop. just wondering if that was normal for these because i never had pad noise from my 01 volusia
  8. #7
    Senior Member Harkon's Avatar
    Join Date
    May 2010
    Location
    Calgary, Alberta, Canada
    Posts
    727
    Default
    This tends to happen if the front wheel was re-installed incorrectly. Look here http://tech.bareasschoppers.com/ and look at the remove/install front tire in the wheels and tires section. The bareasschoppers website is a wealth of information and a valuable service.
    '02 1800C, V&H Big Shots, Kury Corsair intake, DeBadged, Desmogged, PCIII Dyno Tuned, Mustang seat, NDAna
    HID kit, 1300 final.
    '12 Road Glide Ultra, Kuryakyn Alley Cat intake, American Custom Bomber slip-ons, V&H Dresser Duals header, V&H Fuelpak, NDana HID kits
    '13 CRF450X (mine) , '09 KX85 (for my son) , '03 TTR225 (for my wife)
  9. #8
    Join Date
    Nov 2012
    Location
    north arkansas
    Posts
    140
    Default
    thanks
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
