Results 1 to 6 of 6
Thread: vtx 1300 Shop manual
  1. #1
    Join Date
    Jul 2009
    Location
    Proctor, WV westpennsyltucky
    Posts
    4,995
    Default vtx 1300 Shop manual
    ive been reading through the shop manual and honda missed something important. the forget to mention the torque value for the cam holder cap bolts. i have a 2003-2007 manual if you have a different manual can you check page 8-21 to see if the torque value is listed
    thanks
    "Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one." Thomas Paine
    Where is our government!
  2. #2
    Join Date
    Jul 2009
    Location
    Posts
    4,995
    Default
    i just checked the 2003-2004 service manual and its the same no torque value
  3. #3
    Senior Member Hans&Feet's Avatar
    Join Date
    Jun 2005
    Location
    Conyers/McDonough, GA
    Posts
    3,903
    Default
    You skipped right past it.... Check that bearing surface for clearance! 8-7 of 03-04 svc manual
    2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back.
    140,557 VTX miles...​On 8th frt tire, 12th rear tire
    When you stop learning, you are dying.
    http://s1185.photobucket.com/profile/hans1300
  4. #4
    Join Date
    Jul 2009
    Location
    Posts
    4,995
    Default
    i did catch the torque setting you posted but that is for checking bearing clearance. is it the same for actual torque during use
  5. #5
    Join Date
    Jun 2005
    Location
    Posts
    3,903
    Default
    Yes! The actual operating condition torque values are required to correctly determine
    bearing clearance.
    03-04 SM 1-10 has a torque chart, general fasteners on the left side, specialized fasteners on the right.
    The torque values should all be on a chart on the first few pages, not just a few for the fasteners used in that chapter/section.
    http://i1185.photobucket.com/albums/...bolttorque.jpg
  6. #6
    Join Date
    Feb 2011
    Location
    Orlando
    Posts
    158
    Default
    Ive got the 03-07 manual and dont see a value other than the 9 lbf-ft during the plastigauge bit. Exploded view on pg 8-2 doesnt even have it (nor is it in the values on the next page under the chart) Making a guess of it, and only a guess, it would seem the torque used to measure oil clearance would be the torque value for normal operation.
    2007 VTX1300R
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not edit your posts
