Any one use these lights off of ebay.
+ Reply to Thread
Results 1 to 17 of 17
Thread: Any one use these lights off of ebay.
  1. #1
    Senior Member LeeK's Avatar
    Join Date
    Jan 2013
    Location
    Kennesaw, Georgia
    Posts
    129
    Default Any one use these lights off of ebay.
    Looking for some good bright driving/recon lights for visibility. Any on use these before.http://www.ebay.com/itm/250920806728...84.m1423.l2649. Wondering on how they would mount. Any other ideas for some reasonable lights. Thanks.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member DreamVTX's Avatar
    Join Date
    Apr 2010
    Location
    Cornwall, PE
    Posts
    118
    Default Driving lights
    Found some at local Princess Auto store for around 15 bucks that had close to the same setup as shown in the link you provided...slightly different design but same idea...I ended up using one of my bike and one on my wife's bike more for daytime visibility and mounted both down low on the left side off the left footpeg mounting bolts. They work fine and you could probably find something similar at Harbor Freight or Autozone in the USA.
    Attached Images Attached Images
  4. #3
    Senior Member Hans&Feet's Avatar
    Join Date
    Jun 2005
    Location
    Conyers/McDonough, GA
    Posts
    5,908
    Default
    A flat mounting bracket. A piece of sheet metal from under the headlight bucket could be a mounting point.
    Fender mount like they show???
    I don't like the 55watts x 2 = 110watts power consumption.
    364 watts VTX charging system at 5,000 RPM.
    Better to use 25watt or 35watt H3 bulbs.
    Some use an Optronics driving lights, remove the MR-16 halogens and installed 4w led bulbs drawing about .5amp each(6 watts). Power consumption so low you do not need to use a relay.
    2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back.
    160,048 VTX miles...​On 10th frt tire, 14th rear tire
    When you stop learning, you are dying.
  5. #4
    Join Date
    Nov 2006
    Location
    So. Ca.
    Posts
    1,078
    Default Driving Lights
    I picked mine up from Wal Mart for $20, wiring, switch,etc included. Mounted them to my fender brace just below my front tire line. Trying to keep my center of gravity low.
  6. #5
    Senior Member mightywarrior72's Avatar
    Join Date
    Apr 2010
    Location
    Long Beach, Ca.
    Posts
    1,336
    Default
    Whatever you install, use a relay to avoid burning up headlight/starter $80 switch.
    The earlier I get behind, the longer I will have to try and catch up.
    It doesn't take me all day to get nothing done; I can get nothing done by break time.
  7. #6
    Senior Member Capt. Rory's Avatar
    Join Date
    May 2008
    Location
    Metairie, LA
    Posts
    4,898
    Default
    Forget the lights and go with and HID headlight. Way, way more light output. I had driving lights on my bike at one time, but when I went to an HID it made them useless.
    '04 1300S or at least used to be.
  8. #7
    Senior Member moondogger's Avatar
    Join Date
    Dec 2008
    Location
    good old tennessee
    Posts
    246
    Default
    Quote Originally Posted by Capt. Rory View Post
    where do u get this hid light? is it just a bulb are the whole head light replacement?
    2006 VTX 1300R,,black cherry maroon,mustang tour seat,large studded sbags,iso grips with boss,phat-11 risers,wide chrome clutch & brake levers, HK DD 3" strts pipes,freeway bars,chrome back rest,19in. memphis shade sheild,louvers frt&back,lowers,etc,etc.
  9. #8
    Join Date
    May 2008
    Location
    Metairie, LA
    Posts
    4,898
    Default
    Quote Originally Posted by moondogger View Post
    There are lots of places to get one and I along with many others here have bought them from DDM Tuning. I have found them cheaper since then on both Ebay and Amazon. It is a replacement bulb that goes in your stock headlight bucket. There is a ballast for it that needs to be mounted. Some have mounted the ballast under the neck cover and others under the tank. The light output put can not be matched and HID bulbs far outlast any halogen bulb out there. There are lots of threads here on HID lights. http://www.vtxoa.com/forums/search.p...860&pp=&page=2
  10. #9
    Join Date
    Nov 2006
    Location
    So. Ca.
    Posts
    1,078
    Default HIDs
    The purpose of driving lights is not only to see but to be seen. If you have an HID that's great, but both HID & driving lights will make you more VISIBLE. Now there are HID lights that are adaptable to modulators, even better. Remember.......those cagers can't see us. Regardless of who's right or wrong we're the ones that end up dead. We're invisible to them!!!!!!!! Same with our brake lights. Get a high brake light installed that blinks.....BE SEEN; it's most of the battle out there!!!
  11. #10
    Join Date
    Jan 2013
    Location
    Kennesaw, Georgia
    Posts
    129
    Default Went with the HID Headlight kit, now
    Would still like more vis with a set of very bright driving lights, any ideas on brands or kits. I do not currently have a light bar installed?
    Quote Originally Posted by naparisi View Post
  12. #11
    Join Date
    Nov 2006
    Location
    So. Ca.
    Posts
    1,078
    Quote Originally Posted by LeeK View Post
    I'd go back to Walmart & buy their's for $20. Always buy the spots with H type bulbs that give you the option of changing to different watt bulbs & the optically engineered lenses that give you bright white light which you'll be able to target properly unlike a flood type bulb with a glass/plastic lens cover. I bought part # QH-83Cd more than a year ago; no problems. Don't know if they still handle the same ones, but do get the H type bulbs with optically engineered lenses. You can spend hundreds of dollars on spots which I think is unnecessary.
    Nick
  13. #12
    Senior Member motorcyclereb's Avatar
    Join Date
    Jun 2005
    Location
    Ocean Isle Beach NC
    Posts
    3,243
    Default
    Myself I like the old style of light bar from Cobra. The new one is not as wide and the turn signals stick straight out to the side instead of down.
    2003R..................... Darkside Rebel and Proud of it. 100,000 Mile Club
    Home made doolies, Crash Bar, Light Bar, Harley Bags, Reckless Batwing,
    Kuryakyn Hypercharger, Highway Pegs, Corbin Tourer Seat, to name
    some of the many mods. Leo
  14. #13
    Join Date
    May 2008
    Location
    Metairie, LA
    Posts
    4,898
    Default
    Quote Originally Posted by motorcyclereb View Post
    All depends on what you want. If a light bar look is what you want go for it. But small driving lights will be completely drowned out and be hardly visible with an HID head light. As for modulators, personally can not stand them. My brighter whiter color HID is much more noticeable than a dim blinking halogen headlight. And it also does not give a false impression to an idiot in a cage that you are giving them the right of way. To each their own.
  15. #14
    Join Date
    Oct 2010
    Location
    Portage, IN
    Posts
    1,186
    Default
    Does the HID work for low and high beams? I have been kicking around driving lights for the look and night riding better visibility. The HID sounds very good for the better ability to see at night...
  16. #15
    Senior Member heffly's Avatar
    Join Date
    Apr 2011
    Location
    South
    Posts
    3,691
    Default
    I dont think so........i kinda wonder how easy parts are to get also....do you have to order everything. IDK
    We can walk our road together, If our goals are all the same. We can run alone and free, If we pursue a different aim.
    Let the truth of love be lighted. Let the love of truth shine clear. Sensibility, Armed with sense and liberty. With the heart and mind united in a single. Perfect. Sphere. Neal Peart
  17. #16
    Join Date
    Apr 2010
    Location
    Long Beach, Ca.
    Posts
    1,336
    Default
    Quote Originally Posted by WillyD View Post
    DDM Tuning seems to be very reasonably priced. $22.50 for one light level; $37.50 if you want hi/lo.
    Yes they do have hi/lo. But not in the traditional sense. The intensity of the light does not change. The HID lamp moves back and forth to change the angle the light is reflected in the housing. That is what gives the hi/lo.
    http://www.ddmtuning.com/Product-Cat...-Kits-Lighting
  18. #17
    Join Date
    Oct 2010
    Location
    Portage, IN
    Posts
    1,186
    Default
    Quote Originally Posted by mightywarrior72 View Post
    So basically you just run the HID all the time?
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
