I have an 2002 1800c model. It only has 4000 miles. The bike was running fine. I started it the other day and its not idling properly, or when you hit the throttle its sluggish. It was sitting idling, then it kicked up like it should have been idling all along after it was warm. Then same thing today. Is it the FPR? Its the original battery, could it be that? I just bought the bike last year and put it away for the winter. Where should I start? It does have a dynojet fuel commander which when I look at it, the lights are all the way down on the bottom to lean. when i rev it it jumps up to the middle. Does anyone know where you can get the 9 pin cable connector to hook to laptop to do a map??Thanks
have you smoked ur daily bowl
