Results 1 to 9 of 9
Thread: idle problems
  1. #1
    Join Date
    Feb 2012
    Location
    United States
    Posts
    98
    Default idle problems
    I have an 2002 1800c model. It only has 4000 miles. The bike was running fine. I started it the other day and its not idling properly, or when you hit the throttle its sluggish. It was sitting idling, then it kicked up like it should have been idling all along after it was warm. Then same thing today. Is it the FPR? Its the original battery, could it be that? I just bought the bike last year and put it away for the winter. Where should I start? It does have a dynojet fuel commander which when I look at it, the lights are all the way down on the bottom to lean. when i rev it it jumps up to the middle. Does anyone know where you can get the 9 pin cable connector to hook to laptop to do a map??Thanks
  2. #2
    Junior Member icybear's Avatar
    Join Date
    Sep 2009
    Location
    Dallas,TX
    Posts
    12
    Default my best guess
    i would take it to a friend with a dyno or to shop it sounds like it need to be programed and check all the ground spots there a post by Chicago/spike that details all this. have you done the desmog mod and the block off plates if not this could be the problem remember Chicago/spike is the man around here ask him if he don't know then it ant known ....pull the plugs that will tell you a lot
    have you smoked ur daily bowl
  3. #3
    Join Date
    Jan 2013
    Location
    Washington
    Posts
    217
    Default
    As far as a 9 pin adapter, you should be able to get one at Radio Shack. I have no idea what your computer looks like. I run a PC3. As far as your idle, My guess there is something you are not telling us. What intake are you running? Vacuum hoses? Show me some pictures. I would bet you have a vacume line that has got into a hot part of the motor, become brittle and cracked. Without being there or seeing pictures, I can't tell but, that is exactly what it sounds like.
  4. #4
    Senior Member RBS's Avatar
    Join Date
    May 2008
    Location
    Corrupticut
    Posts
    4,121
    Default
    Quote Originally Posted by codeman8372 View Post
    Always start with the simple things.
    Did you use a stabilizer in the gas when you put it away?
    Democrats & Republicans - 2 sides of a counterfeit coin
    4 Boxes Keep Us FREE: The Soap Box, The Ballot Box,
    The Jury Box, And The Cartridge Box.
    07 C/B/C 1300S Cobra Speedster Slashdowns, Ultra-Flo Intake
  5. #5
    Join Date
    Feb 2012
    Location
    United States
    Posts
    98
    Quote Originally Posted by RBS View Post
    Yes I did use stabil. I had no problems a couple of weeks ago when I had it hooked up to a tender. Then I unplugged tender for a couple of weeks, it hesitantly started. Didnt want to stay running. I had a mechanic come get it, fixed the ground problem, put front fork springs in. He dropped it off, I started it, running rough. Sounded like it was only firing on two cylinders. Left it running, walked inside my house, sounded like it went to firing properly.It also stutters when you hit the throttle til it warms. Smoke is coming out of the exhaust, sometimes black. Tried this morning, same thing. Rough at first, then seemed to smooth out. I just ordered a new battery. Im gonna try that first. Where can I buy a FPR? Thanks
  6. #6
    Join Date
    Aug 2008
    Location
    Springdale, Arkansas
    Posts
    1,879
    Default
    Drain the gas and put in fresh gas. If it sounds like it is running on 2 cylinders that would be good.
    2007 1300C with Woody's Fairing, HD King Tour Pack, and Cavalry Hard Bags.
  7. #7
    Join Date
    Jun 2004
    Location
    Central Wisconsin
    Posts
    742
    Default
    Read this and the other links on FPR, symptoms, how to test and replace & where to buy if needed, our sponsor HDL.
    http://www.vtxoa.com/forums/showthread.php?335880-How-to-test-Fuel-Pressure-Regulator&highlight=test+fuel+pressure+regulator
    http://www.californiavtxriders.com/phpBB3/viewtopic.php?f=26&t=32640
    Here is my original search with many more threads on the FPR
    http://www.vtxoa.com/forums/search.php?searchid=1583453
    2002 1800C ILLUSION BLUE - COBRA ANGLE SLASH CUTS TRI-POT Memphis Fats 21" HONDALINE BAGS EASY BRACKETS
    ====>> KEEP IT VERTICLE <<====
  8. #8
    Senior Pirate KeyWasted's Avatar
    Join Date
    Jan 2008
    Location
    Keys
    Posts
    4,269
    Default
    There's your problem!
    Seriously, you'll get more answers putting this on the Tech board. Spike lives there.
    BTW, mine was idling horribly or not at all, and it was a loose battery connection.
    Hope you find those other cylinders.
    2003 VTX1800 ARRRGH
    I ride just fast enough to make the raindrops sting.
    BACKFLIP FACEPLANT IN THE SNOW!
    http://www.break.com/usercontent/201...-plant-1881385
    VTX BEATS HARLEY and Hitler is Pissed!
    http://www.break.com/usercontent/2010/9/7/keywasted-1912477
    Red Knights MC
    "343"
  9. #9
    Senior Member heffly's Avatar
    Join Date
    Apr 2011
    Location
    South
    Posts
    2,395
    Default
    The reason it sounds like it is only running on two cylinders is because thats all it has.................
    What you own is your own kingdom, What you do is your own glory. What you love is your own power, What you live is your own story. In your head is the answer, let it guide you along. Let your heart be the anchor and the beat of your song. Neil Peart
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
