Ok, Can anyone direct me to a VTX 1800f Manual on line? If not does anyone know what to torque the Triple trees Bolts and Pinch bolts on my front shocks![]()
If nobody gets to you sooner I will get it for you tonight when I get off and can look in my manual. You have stock trees right??
top is 55N-m (41 l bf-ft)
bottom 24 N-m (117 ft f-lb)
B.F.L............W.I.V.O.
Getting old is not for sissy's
The steering stem nut should be set at 74 ft lbs
top fork pinch bolts set at 41 ft lbs
bottom fork pinch bolts set at 17 ft lbs
and the fork caps if you took those lose should be set at 25 ft lbs
