VTX1800 Neutral switch
+ Reply to Thread
Results 1 to 6 of 6
Thread: VTX1800 Neutral switch
  1. #1
    Junior Member
    Join Date
    Apr 2013
    Location
    Damascus, Arkansas
    Posts
    2
    Default VTX1800 Neutral switch
    I thank everyone for all the help. Turned out that the neutral switch was stuck. I simply had to take it off and clean it. Bike is running beautifully now.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    58,443
    Default
    Behind the left rear engine chrome side cover, where your shift lilnkage runs behind. Pop off the 7 screw if I remember right, and the switch is behind the cover
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  4. #3
    Senior Member biker.chef's Avatar
    Join Date
    Sep 2006
    Location
    Burnsville, MN
    Posts
    2,552
    2003 VTX 1800R
    Ya know, I think we're all Bozo's on this bus.
  5. #4
    Senior Member Hans&Feet's Avatar
    Join Date
    Jun 2005
    Location
    Conyers/McDonough, GA
    Posts
    6,367
    Default
    #1 Find what is blowing the fuse... Neutral switch can still work---just no visual indication.
    Speedo, front running light, temp/oil/neutral lights, tach, tail light, license plate light all on the
    Black/Brown wire. You do anything on that wire?? Any adds or changes????
    Neutral switch puts out a ground---cannot blow a fuse---also sends a signal to ECM. ECM has to see a ground to run in neutral. This same "ground" to the ECM also goes to the "Starter relay" so you can crank the engine. IF it does not crank in neutral than there is a problem.
    Kickstand switch(UP) puts out a ground--sends a signal to ECM, engine will die if kick stand goes down in gear. ((OR if kickstand bolt loose, damaged or wiring problem)).
    This same "ground" from the kickstand switch goes through the clutch lever switch when you pull the lever to allow cranking in gear.
    A diagram of the starter relay with ECM safety status leads(neutral, kickstand)
    http://i1185.photobucket.com/albums/...relayckt-2.png
    Last edited by Hans&Feet; 04-22-2013 at 03:10 AM. Reason: added cranking info 0306 EDT
    2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back.
    162,388 VTX miles...​On 10th frt tire, 14th rear tire
    When you stop learning, you are dying.
  6. #5
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    58,443
    Default
    Quote Originally Posted by Hans&Feet View Post
    Thanks, I missed that part
    2002 VTX1800 C
  7. #6
    Junior Member
    Join Date
    Apr 2013
    Location
    Damascus, Arkansas
    Posts
    2
    Default Neutral Switch
    Thank you very much!
    Quote Originally Posted by Chicago-Spike View Post
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Tags for this Thread
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
