Smells like gas?
+ Reply to Thread
Results 1 to 10 of 10
Thread: Smells like gas?
  1. #1
    Junior Member
    Join Date
    Apr 2013
    Location
    Greencastle, IN
    Posts
    16
    Default Smells like gas?
    New to the VTX fourm and just did not know why my oil smells like gas?
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member gregory940's Avatar
    Join Date
    Dec 2005
    Location
    North Vernon, IN.
    Posts
    210
    Default
    What year is your vtx?
    2004 VTX1800C
  4. #3
    Senior Member Trackman's Avatar
    Join Date
    Jun 2007
    Location
    1000 Islands, Brockville
    Posts
    1,043
    Default
    The early models it's usually the fuel pressure regulator FPR.
    Just scroll down throu the recent posting.
    Lots of gas smell posts.
    Do not ride it with gas in the crankcase.
  5. #4
    Junior Member
    Join Date
    Apr 2013
    Location
    Greencastle, IN
    Posts
    16
    Default
    Quote Originally Posted by gregory940 View Post
    2003
  6. #5
    Senior Member chuck_VTX F's Avatar
    Join Date
    Aug 2007
    Location
    Upper Right Ohio
    Posts
    4,381
    Default
    FPR = fuel pressure regulator . I have answered this question 3 times this morning by 3 different people must be 100 posts with this very question.
    all 2002 and 2003 have this problem.. and has since 2004...
    2005 VTX1800 "F" type II...... Silver Tribal .... 57,100, purchased Feb, 2005.
    I am Right, ...................... because I am a lefty.................. I am retired,, .................and NO I will not fix your car...
  7. #6
    Join Date
    Dec 2005
    Location
    North Vernon, IN.
    Posts
    210
    Default
    I just replaced mine. Biglarry on the California site has a good how to on it. Do yourself a favor and get most of the gas out of the tank or the return line on the fpr valve will make a big mess!
    2004 VTX1800C
  8. #7
    Senior Member fastspek's Avatar
    Join Date
    Jan 2006
    Location
    Belgium(Europe)
    Posts
    1,191
    Default FPR mania
    I have a feeling that the FPR is blamed too easily on this forum. Before deciding to buy a new one check if it is broken by the simple test of removing the vacuum tube and look for the presence of gas. If not the FPR is OK and a replacement is NOT necessary. There maybe several other reasons why a bike is running rich. Oil that smells like gas but without an increase in the volume is not caused by a bad FPR but can also be the result of a low Air/Fuel ratio. If we all start with replacing the FPR for no reason very soon their won't be any left for the people that really need one.
    President MC Bourgondische Slakken: http://www.mc-bgs.com/
    2003 VTX 1800C (forever)
    2002 HD FLSTF since 07/2008
    " Today you raised more questions than giving answers "
  9. #8
    Junior Member
    Join Date
    Apr 2013
    Location
    Greencastle, IN
    Posts
    16
    Default
    I should tell you all about her. She has not been rode for about 3 years or so. And before that not much at all. I am buying it from my Father. I will start riding her next spring. She has cobra straight pipes with baffles that I will remove, cobra fule processer or whatever they call it for fule injected. K&N air filter inside the original air filter housing. I would ride her now, but I can not give up my beloved 2002 yamaha roadstar(Horney Girl). She is just broke in at a mere 129,000. Just wonder how the two bikes compare. He also has a service manual for her. By the way the VTX only has 5,000 on her.
  10. #9
    Junior Member
    Join Date
    Apr 2013
    Location
    Greencastle, IN
    Posts
    16
    Default
    As of now I know very little about the VTX. Where is the fpr located at? I will change the engine oil, gear oil, brake fluid, what ever is in the clutch lines. What elese sould I do to her before I start riding her. Should I change the water as well?
  11. #10
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    58,246
    Default
    Tires, coolant, gas, brake&clutch fluid, battery, air filter
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
+ Reply to Thread
Quick Reply Quick Reply
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
