Vtx 1300c Electrical problem
+ Reply to Thread
Results 1 to 5 of 5
Thread: Vtx 1300c Electrical problem
  1. #1
    Junior Member
    Join Date
    May 2005
    Location
    Prairieville La.
    Posts
    15
    Question Vtx 1300c Electrical problem
    This bike has 30k miles on it and I have changed the starter switch harness 2 times.Looks it might have to be a 3rd.Honda has changed the part # twice.Turned on the key headlight lit up ,pushed start button it went dead like no power.Does anybody have a wiring diagram?I had a manual but seemed to have misplaced.Any help would be appreciated.
    Thanks Neilmel
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member heffly's Avatar
    Join Date
    Apr 2011
    Location
    South
    Posts
    3,953
    Default
    I think you can get a copy here....http://depositfiles.com/files/1761507
    Sounds more like connection or battery problems. Have you cleand up the grounds at the front coil, helps. I would go over connections.
    We can walk our road together, If our goals are all the same. We can run alone and free, If we pursue a different aim.
    Let the truth of love be lighted. Let the love of truth shine clear. Sensibility, Armed with sense and liberty. With the heart and mind united in a single. Perfect. Sphere. Neal Peart
  4. #3
    Senior Member mightywarrior72's Avatar
    Join Date
    Apr 2010
    Location
    Long Beach, Ca.
    Posts
    1,352
    Default
    Do you have lightbar, spotlights or any other added lighting load to the front of the bike. These bikes are notorious for burning out starter switch due to heavy headlight load. Solution is easy. Install a relay for the headlight loads. Very simple process. I am eager to help, if you think this is the problem.
    The earlier I get behind, the longer I will have to try and catch up.
    It doesn't take me all day to get nothing done; I can get nothing done by break time.
  5. #4
    Senior Member Donut's Avatar
    Join Date
    Jan 2005
    Location
    Coloma, Mi. MixRider Member
    Posts
    6,185
    Default
    Neilman .. I sent you a PM message.
    We need to talk.
    Doug
    Donut Doug
  6. #5
    Senior Member Xman/qc's Avatar
    Join Date
    Jan 2006
    Location
    Quebec Canada
    Posts
    1,323
    Default
    You just have to clean the starter switch some will give you link of how to do it and if you have acc use a relay like
    mightywarrior72 suggestion
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
