VTX 1800F wheels on a VTX1800C
+ Reply to Thread
Results 1 to 8 of 8
Thread: VTX 1800F wheels on a VTX1800C
  1. #1
    Junior Member
    Join Date
    Mar 2008
    Location
    Houston,Tx
    Posts
    14
    Default VTX 1800F wheels on a VTX1800C
    Will VTX1800F Wheels fit on a VTX1800C ? Has anyone put F rims on a C.
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Senior Member Trackman's Avatar
    Join Date
    Jun 2007
    Location
    1000 Islands, Brockville
    Posts
    1,043
    Default
    I have switch the rears without any problem.
    You just need different sized tires. (profile)
  4. #3
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    58,924
    Default
    Yes, they are a direct swap, just need new tires
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  5. #4
    Junior Member
    Join Date
    Mar 2008
    Location
    Houston,Tx
    Posts
    14
    Default
    Thanks for the information.
  6. #5
    Senior Member Jon's1800VTXC's Avatar
    Join Date
    Aug 2004
    Location
    Seattle/Everett (AZ in my heart)
    Posts
    15,653
    Default
    front tire is the same size, but as said the rear is an 18" and yes a 200/18 fits and looks great. All the rotors will swap straight over, just use a dab of blue loctite and torque to specs
    Why is common sense not so common
    Why doesn't P.E.T.A. ever attack a biker
  7. #6
    Senior Member Yaesu's Avatar
    Join Date
    Oct 2011
    Location
    Rineyville, KY Hernando Beach, FL
    Posts
    815
    Default
    What is the advantage of the 18" over the 16" wheel? Or the advantage over the 16" over the 18" wheel? I know there are fewer car tires available for the 18" wheel, but other than that, does the ride or handling differer between the two?
  8. #7
    Senior Member X'N's Avatar
    Join Date
    Apr 2006
    Location
    MN
    Posts
    10,582
    Default
    Quote Originally Posted by Yaesu View Post
    one may notice the F rear wheel a little better in turns because of the shorter sidewall but for the most part there is no difference other than they are harder to find a(18" vs the 16") tire when your out in the boonies found that out first hand.
    2012 Victory Cross country
    http://www.vtxoa.com/forums/attachment.php?attachmentid=75391&d=1342403272
  9. #8
    Senior Member sskillett's Avatar
    Join Date
    Nov 2003
    Location
    Greensburg, PA
    Posts
    1,271
    Default
    Nope don't fit at all - my sig states otherwise
    200/50-18 Metz fits real nice. 200/55-18 Avon is too tall and skinny. Both will work.
    I did my swap back in 2005 or so. The F wheels really make a C look its best.
    Tod Hoffmann
    2002 VTX1800-C
    1990 Chevy 454SS Accel DFI/6 speed
    1966 Pontiac GTO hdtp Tri Power/4 Speed
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
