Barnett clutch kits: carbon fiber vs. kevlar
+ Reply to Thread
Results 1 to 13 of 13
Thread: Barnett clutch kits: carbon fiber vs. kevlar
  1. #1
    Join Date
    Jan 2004
    Location
    Valencia, CA
    Posts
    145
    Default Barnett clutch kits: carbon fiber vs. kevlar
    On Viking's website, the kevlar set is 8 bucks more than the carbon fiber.
    What's the diff between the two? Is one significantly better than the other?
    "A man's got to know his limitations." - Dirty Harry
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    Nov 2003
    Location
    Burton, Michigan
    Posts
    299
    Default
    MegaMike,
    Here's some things to question:
    (1) Why is it that the Barnett Clutch Website (www.barnettclutches.com) doesnt refer to ANY Kevlar Kits available for the VTX, ONLY Carbon Fiber ??
    (2) Why is Viking promoting something that doesnt seem to exist, let alone charging 8 bucks more ??
    (3) If such a kit exists, why doesnt Hal offer it on Directline ?? The picture on his website displays the Barnett Kevlar design, however, Directlines description states it's a Carbon Fiber Kit !!!
    If you contact Barnett (as I did), they DO NOT OFFER A KEVLAR KIT FOR THE VTX !!! Barnett: 1-805-642-9435
    See this link to Barnett: http://www.barnettclutches.com/applicat ... _menu=1800
    Hope this helps !!!
    Eric (NASTYX)
  4. #3
    Join Date
    Jan 2004
    Location
    Valencia, CA
    Posts
    145
    Default
    Thanks for pointing that out, NastyX. I don't know what's up with Viking.
    I looked at the part numbers on Viking's site. The Kevlar kit is HPK-86, and the carbon-fiber kit is HPK-86CF.
    Then I looked at Barnett's site, and sure enough they only list the HPK-86CF kit, and the fine print says:
    "Carbon Fiber clutch kit part # end in "CF". All others Kevlar."
    Okay, so someone at Viking is on crack. But I'd still like to know what the difference between a carbon-fiber and a kevlar clutch kit would be, even though there is apparently no such thing as a Barnett kevlar kit for the VTX. Does anybody know what the difference is (just in general, not specifically in regard to the VTX) ??
  5. #4
    Join Date
    Nov 2003
    Location
    Jacksonville, Fl.
    Posts
    148
    Default
    I just switched from the carbon fiber to the Kevlar and the Kevlar hooks up much more strongly, almost too strong in fact. I find it somewhat difficult to modulate the clutch and keep it in the friction zone to smoothly transmit power to the rear wheel and keep the engine revved up to a point where it runs smooth without lugging. The Kevlar tends to not want to slip as much as I am accustomed to with the old carbons making me clumsy (again) when making very slow maneuvers. I was able to scrape the floor boards on either side with ease at a walking pace before I changed and now I am finding it difficult to achievie the same smoothness again. I’m sure that I will get more accustomed to the subtleties of the new clutch as time goes by and I sure do like the way it launches from red lights. Anyway, I just wanted to share with you that there is a difference in performance and I’m sure the Kevlar will be more durable. At least I sure do hope so as I have gone thru both the stock and the Barnet carbons rather quickly. You think them burnouts and drag launches might have anything to do with it?? Nagh, couldn’t be that.
    GatorX
  6. #5
    Senior Member VTXnVa's Avatar
    Join Date
    Nov 2003
    Location
    Virginia, Warrenton
    Posts
    2,571
    Default
    Quote Originally Posted by Gator
    Ok folks, now I'm even more confused. Gator, where did you get your Kevlar clutch pack? Barnett doesnt list one, Viking does but how if the vendor doesnt? Pior posts/research seemed to indicate no such thing as a kevlar clutch pack for the X.
    Greg
    <<<<< Virginia XRiders BB >>>>>
    07 ST1300A
    03 VTX 1800C - Gone, but never fogotten!
  7. #6
    Join Date
    Dec 2003
    Location
    escondido ca
    Posts
    113
    Default
    this is a really good question. i poked around on this to get some facts but never really did. but i heard lots of storys of kevlar discs slipping on the vtx but maybe they were using the 856 springs and the 114's are only 10 percent stronger. i put the carbon fiber in and they feel great. but if you read the discriptions on there web site they say that if you are hard on your clutch to use the cf and the carbon fibor is there newer design so i wonder being that barnett is in the racing biz if the kevlar is more of a racing clutch and better suited for lihgt weight racing bikes and not verry good fof the heavy vtx. because when the x first came out all barnett had was the kevlar and they were slipping on the vtx's and then they came out with the cf and thats all they list for the bike on there web site. and they sent biglary a set of carbon fibor's with the older 856 springs and after like i think he said 16 k the clutch is still strong. i figure if it hooks up a guy as big as him it will work for me. but i would love to know the real diference between these two clutches.
  8. #7
    Join Date
    Nov 2003
    Location
    Round Rock, Texas
    Posts
    2,508
    Default
    just take a guess what clutchs work best with 340HP and 240 Torque?????
    OEM period the Kevlar went bye bye in less than 2 miles
    Builder and tuner of some of the worlds record breaking motorcycles
  9. #8
    Join Date
    Nov 2003
    Location
    Virginia, Warrenton
    Posts
    2,571
    Default
    Quote Originally Posted by Johnnycheese
    So what are you saying? OEM clutch with 114 springs is better that Barnett CF with 114 springs?
    Greg
    07 ST1300A
  10. #9
    Join Date
    Nov 2003
    Location
    Jacksonville, Fl.
    Posts
    148
    Default
    VTXnVa, I got a local vendor to order them from Barnet they sold them individually ie I ordered 8 single disks rather than a "pack' or kit. They were about $8 each. When I replaced the stock friction pads with the CF from Barnet I used the stock steel plates and so had the Barnet from the CF kit left over for this time. Leaving the stock plates was probably an error and may be why the new friction plates wore out so fast. I think I had probably cooked them so they lost temper and wore quickly causing slippage and accelerated ware on the friction pads.
    GatorX
  11. #10
    Join Date
    Nov 2003
    Location
    Round Rock, Texas
    Posts
    2,508
    Default
    OEM are always better you just need HD springs or lock up weight
  12. #11
    Join Date
    Nov 2003
    Posts
    1,517
    Default
    Quote Originally Posted by NASTYX
    MegaMike,
    Hope this helps !!!
    Eric (NASTYX)
    Eric I just called Andy at Viking and am told that he orders the Kevlar plates special and puts the kits together with no carbon fiber plates.
    That is the reason for the 8 dollar difference.
    Hope this clears everything up for all of you.
  13. #12
    Junior Member SOAR's Avatar
    Join Date
    Jul 2009
    Location
    Jacksonville,FL
    Posts
    8
    Default Barnett does offer
    Barnett does offer a kit and the kevlar clutch plate stock number is 301-45-10008. I called Barnett and verified what I got was kevlar, because on the packaging it just says friction plate.
    Quote Originally Posted by NASTYX View Post
    MegaMike,
    Hope this helps !!!
    Eric (NASTYX)
  14. #13
    Senior Member NDAna's Avatar
    Join Date
    Aug 2005
    Location
    Seattle Metro, U.S.A.
    Posts
    12,910
    Default
    Quote Originally Posted by Johnnycheese View Post
    Sorry Johnny- that is just wrong. I know- way old post but some things don't improve with age either!
    Sam/NDAna #15542 IB#38401 '04 1800 C, HID, Audiovox Cruise, 2xDarkSide & enough other stuff to keep me comfortable. Now have H4 HID & LED headlights available NDs.HIDs@gmail.com "Can you see me now?" For DarkSide info go here http://mcdarksiders.forumotion.com
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
