VTX 1800C Red Line RPM (HELP)
+ Reply to Thread
Results 1 to 4 of 4
Thread: VTX 1800C Red Line RPM (HELP)
  1. #1
    Junior Member
    Join Date
    Jul 2005
    Location
    Bloomsburg, PA
    Posts
    10
    Default VTX 1800C Red Line RPM (HELP)
    I just installed a tachometer for my 2004 VTX 1800C but cannot find the red line RPM anywhere. It is not even in the manual.
    I am looking for max RPM, peak power RPM if anyone knows I would appreciate it.
    Hard Krome 3" Dual Sideburners
    Kuryakyn Pro Hypercharger
    Kuryakyn grips, Highway Bars, Retro Pegs
    Custom Mirrors (Maltese Cross w/ flames)
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Junior Member
    Join Date
    May 2005
    Location
    maryland hts. missouri
    Posts
    27
    Default
    as the rocketeer says, If you have a good reaction time (0.5sec) then set the shift light at 5450. this gives you the begining of the torque curve in the next gear.
    hope this helps
    04 1800c
    ________________________________
    don't force it ,it should slip right in
  4. #3
    Join Date
    Sep 2004
    Location
    Greer, SC
    Posts
    113
    Default redline
    From other posts, 5750 is where the rev limiter is set.
    '04 Neo, Magenta, Spec II, Memphis Shades Fats 21", lowers, Hopnel windshield bag, Honda low Neo backrest, Neo luggage Rack, Hondaline Saddlebags, Kury Iso grips, throttle boss, switch covers, Kewlmetal helmet locks, Brown County Custom airbox cover, K&N filter, PC III USB, V&H Bigshots, Rivco drive shaft cover, frame covers, swingarm cover, highway pegs, passenger floorboards w/extensions.
  5. #4
    Senior Member tin-indian's Avatar
    Join Date
    Mar 2005
    Location
    N/E Ohio
    Posts
    1,197
    Default
    I might have this backwards of wrong all together.but I think the fuel shuts off at 5750 then the ignition cuts out at 6000.
    '02 VTX1800C
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
