240 tire 16 or 18 inch rim ?
+ Reply to Thread
Results 1 to 11 of 11
Thread: 240 tire 16 or 18 inch rim ?
  1. #1
    Join Date
    May 2004
    Location
    Kennesaw Ga.
    Posts
    553
    Default 240 tire 16 or 18 inch rim ?
    when doing a 240 kit on a 1800-C is there any reason to move up to a 18 inch rim or is it Ok to stay with the 16 inch. The apperance of the two tires should be same; height & width when mounted. I am thinking the main diff. would be unable to move up to a 250 or 260 tire. am I missing anything else ?
    thanks
    mike
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Join Date
    Nov 2004
    Location
    Southeast Texas
    Posts
    814
    Default
    Have you calculated your frame ground clearance with the 16" rim? Would that be a concern?
    MONSTER...sweeeeeet
    That's about all I got to say about that.
  4. #3
    Join Date
    May 2004
    Location
    Kennesaw Ga.
    Posts
    553
    Default
    would that be a problem since bike has a 16 inch from factory ?
    Mike
  5. #4
    Join Date
    May 2004
    Location
    Where ever I choose!
    Posts
    533
    Default
    A 240/16 will not look like a 240/18 I believe the side wall of the 240/16 is not a low profile although I am not sure I have never seen one!
    Full on Custom Not much Honda Left!!! THANK GOD!!!!
  6. #5
    Join Date
    Nov 2003
    Posts
    790
    Default
    I put a 16" 240 tire on my bike, I think it gives a more dragster look.....and like Ron said in a previous post...."why put something on your bike that anyone else has" .......18" 240's are everywhere
    [/img]
  7. #6
    Join Date
    Nov 2003
    Location
    Topeka, Kansas
    Posts
    1,215
    Default
    In answer to your original question, no there is no real reason to have to move up to a 18" wheel when you go to a 240.
  8. #7
    Join Date
    May 2004
    Location
    Kennesaw Ga.
    Posts
    553
    Default
    bump
  9. #8
    Join Date
    Jan 2004
    Location
    Cleveland, Ohio
    Posts
    1,107
    Default
    I'm pretty sure it's just a matter of preference. I know when I get mine it will certainly be a 16". Too much wheel is just gaudy, like those ridiculous Honda Civics with the giant wide wheels. I like the way rubber looks from the back and the side. Looks great Night Train.
    04 VTX 1800C Orange Flame-RH Shorty-PCIII-Thunder Air-DeSmogged
    http://www.riffster.com/vtx/main.htm
  10. #9
    Join Date
    Nov 2004
    Location
    Latvia
    Posts
    176
    Default 16 versus 18
    Ok, 16th tire looks good from side as well, but what about wheel diameter? Should be smaller - and result: clearance and speed if you do not modify transmission.
  11. #10
    Join Date
    Nov 2003
    Posts
    790
    Default
    The outside diameter of the tire is the same as using an 18" rim, the 240/16 has a bigger side wall.
    [/img]
  12. #11
    Join Date
    Nov 2003
    Location
    Edwardsville IL (Near STL MO)
    Posts
    1,750
    Default Re: 240 tire 16 or 18 inch rim ?
    Quote Originally Posted by mca1989
    thanks
    mike
    I do the 16" 240 set ups for guys all the time. I prefer it persosally to the 18" 240 for a number of reasons.
    The overall diameter of the 16" vs the 18' is slighlty smaller thus putting you a bit closer to the ground in the back end. That is a plus for the 16".
    The 16" 240 tire is only made by Metzler, you will find that there is a signifciant difference in the contruction of the tire in a 16 vs 18". The 18" is a flimsy tire by comparision. The 16" has more sidewall and tread belts than its 18" counterpart.
    The 16" tire offers a better ride that a 18" tire all things being equal.
    You will find that a bike with a rigid frame or a very stiff rear will benefit from the extra sidewall of a 16" tire.
    Also, the 16" is unequalled in looks. I too want to see the tire. When you look at a 240 x 16 from the side, it is obvious you ar running a fat tire.
    On an 18" set up, you really have to walk around the back of the bike to be sure of what the bike is running.
    I just did a 240 set up with a 9.5" wide wheel and it's smoken hot.
    Typically, the 240 x 16" would be mounted on a traditional 8.5" wide wheel.
    I am finding that when mounted to a slighlty wider wheel such as a 9", the tire looks just awsome and looks more like a 250/260.
    Much of this is personal preference. Some like to see wheel and some like to see tire. The benefit of the 18" is that everyone in the world makes a 8.5" x 18" wheel. In the case of the 16" wheel, I dont know anyone who makes a 16" x 8.5" in a cast wheel.
    That is why we go the custom built wheel route.
    previous owner of Gateway Xtreme Motorcycles and Chrome exchange
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
