FRONT FORKS 2003 VTX C
+ Reply to Thread
Results 1 to 5 of 5
Thread: FRONT FORKS 2003 VTX C
  1. #1
    Junior Member
    Join Date
    Apr 2005
    Location
    ohio
    Posts
    16
    Default FRONT FORKS 2003 VTX C
    WAS WONDERING IF ANY BODY HAVING TROUBLE WITH FRONT FORKS, ME AND A FREIND OF MINE HAVE 2003 VTX BOUGHT NEW LAST YEAR AND ONE OF THE FORKS ARE SHORYER THAN THE OTHER. I HEARD THIS WAS A PROBLEM WITH SOME 2003 C, BUT NO RECALL. MY FREIND HAD HIS REPLACED AND NEW TIRE AND HONDA PAID FOR IT NOW I HAVE TO TAKE MY VTX IN AND SEE IF HONDA IS GOING TO COVER IT. JUST THOUGHT I WOULD CHECK AND SEE IF ANYBODY ELSE HAD THE SAME PROBLEM OR KNOWS OF ANYONE HAVING IT?
  2. Remove Advertisements
    VTXOA.com
    Advertisements
  3. #2
    Junior Member
    Join Date
    Apr 2005
    Location
    ohio
    Posts
    16
    Default
    CORRECTION ONE FORK IS SHORTER THAN THE OTHER
  4. #3
    Join Date
    Jul 2005
    Location
    Phoenix, Az
    Posts
    202
    Default
    I'm not the best in this field , but this I do know. Other than there actually being a manufactures error on one fork, this may be explainable by what i read in the manual, and also in one of the Fork mod Writeup. There is a threaded rod in the fork that has a nut. If you don't keep this nut in the same place, it will cause a problem. hope thats helps. If the dealer replaces it for you, Cool. Good luck. Stepper
    03C, G-Man Inserts,6* T's, Headlight Extended w/ mod,Hand polished TTT-speedo-fork lowers-wheels,custom mirors, Supreme Legends Forwards and Rears, Ope Mod, Chrome Dip, chome ring, Paint- Vagurple w/ Pearl, desmog, Mustangs, Kuryakyn lic plate w/ Chicken Lights, ground and diode Fix, Met200
  5. #4
    Join Date
    Nov 2003
    Location
    St Charles, IL.
    Posts
    58,929
    Default
    It is NOT a problem. Once the forks are linked together with the wheel and the axle they operate a one solid unit. They are different legths when no wheel or axle is holding them because one fork is for extension, and one fork is for compression. So they work differently to counteract one another. So the compression fork will be longer. The uneveness will not cause uneven tire wear, will not cause the bike to track to one side. They are one solid suspension unit when the wheel is in place. This is from suspension experts Progressive Suspension.
    http://www.vtxoa.com/forums/viewtopic.p ... solid+unit
    DLP Sells Victory Too
    2002 VTX1800 C
    AMA Life Member 721314
  6. #5
    Join Date
    Jul 2005
    Location
    Phoenix, Az
    Posts
    202
    Default
    I'll send thanX Mr. Spike. I was conserned for the man, but what you said is clearly correct. I have mine sitting on the Jack , and I don't see an obvious difference in the length.
+ Reply to Thread
Quick Reply Quick Reply
Where you live
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
