VTXOA
Go Back   VTXOA > VTXOA Message Boards > VTX 1300 Riders Board
Notices
VTX 1300 Riders Board Tips, Tricks, Mods, Maintenance and General VTX 1300 chat on this board.
Thread Tools Display Modes
Old 2 Weeks Ago   #1
toadross
toadross's Avatar
Default Maybe having some Clutch issues
I think i may be having some clutch issues, thought it just may need adjustment. Usually going into 5th gear I have to push hard on the shifter(harder than the other gears). Also I usually leave it in gear when i park it, so i need to pull the clutch lever in to start the bike. Sometimes it just wont start in first gear and I have to put in neutral to start.
It seems like the clutch just isnt disengaging all the way. Is this a sign of bad clutch or just an adjustment?
Thanks,
Todd
__________________
2005 1300 C - 2" Cobra Drag Pipes, Mustang Seat, Glens Clutch Relief, All Balls Bearing and Fork Seals, Progressive Front Springs
toadross is offline   Reply With Quote
clearance
Old 2 Weeks Ago   #2
vtxrosa
vtxrosa's Avatar
Default
Check the simple stuff first. Starting in not in gear might be the kickstand switch or clutch switch. How much free play do you have in the clutch lever?
__________________
'04 VTX1300C, Amsoil, V&H pipes, FPjet kit, Neutron air cleaner cover/ K&N filter, MY pair valve plates, mustang seat w/ honda deluxe backrests, Viking saddlebags. Memphis fats 21, Race Tech front springs, Fatty highway bars w/Dually pegs, ISO wing pegs. S/S brake lines, ISO grips, All-balls steering. HID headlight. 250 watt sound system w/Ipod.
vtxrosa is offline   Reply With Quote
Old 2 Weeks Ago   #3
Madness_MC
Madness_MC's Avatar
Send a message via MSN to Madness_MC
Default
Todd -
Time to drag out the Service manual and review the proper methods for adjusting your clutch. The instructions start on page 3-17 that shows the proper amount of clutch lever free-play. I'd personally start with the major clutch cable adjustment on page 3-18 down above the crankcase. Once that's set properly, use the adjuster up near the clutch lever.
I'd almost bet that between a slightly stretched clutch cable and a clutch with a little wear on it, you'll be needing to adjust both ends of the cable to get things back to working properly.
__________________
Joe Licketto - Owner
Madness Motorcycle, LLc
Lugoff, SC 29078
madness_mc@sc.rr.com
2004 VTX1300-C, Candy Red Metallic ... with a "few" mods
Madness_MC is online now   Reply With Quote
Old 2 Weeks Ago   #4
toadross
toadross's Avatar
Default
well the thing is, I installed a clutch tension reducer and probably didnt get things back to the way they were. I dont know why i didnt notice a difference until now.
__________________
Old 2 Weeks Ago   #5
donut
donut's Avatar
Default
How much play do you have in the clutch lever.
__________________
04 1300s Silver,Ultimate Seat with drivers backrest,Memphis21" Fat & Lowers,Headlight Extender,Backoff modgule,Eddie's Signal Beeper,4"Aeromach risers,Iso Grips,Paladin Highway Bars,Brake Away Throttle Lock,Kuryakin Right Angle Pegs, Cobra slipon's, Progressive Fronts,11"HD 412 rear,Honda Delux Sissy Bar,River Road Bags.
donut is offline   Reply With Quote
Old 2 Weeks Ago   #6
toadross
toadross's Avatar
Default
i think the right amount, im gonna do some checking this weekend on it, any tips for adjustment other than what the manual might show
__________________
Old 1 Week Ago   #7
Madness_MC
Madness_MC's Avatar
Default
Todd -
The manual is right on-the-money as far as adjustment procedures goes. No other special tips or tricks are necessary.
As Nike says "Just Do It !!"
__________________
Lugoff, SC 29078
Display Modes
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
