VTXOA
Go Back   VTXOA > VTXOA Message Boards > VTX 1800 Tech Board
Notices
VTX 1800 Tech Board Tips, Tricks, Mods, Maintenance and VTX 1800 questions go on this board. Jump on in and post "Tech" related messages here.
Thread Tools Display Modes
Old 2 Weeks Ago   #1
Sealion50
Junior Member
Default Kury R-T-B and LEDs
I am planing to install the Kury RTB plug and play. I have a 2007 1800T which uses the PR21W bulbs in the rear turn signals. My question is, does anyone make a good red LED that is made to fit the 7507 light socket, which is standard in my rear turn signal housings ?
Or have those installing red LEDs in these rear turn signals been using 1156 style LEDs and grinding one knob off a bit to make it fit. Or do you need to change the rear turn signal sockets out to 1156 sockets?
I realize that one could hard wire the LEDs in and eliminate the sockets altogether. I would rather not do this, as I would rather maintain stock while under warranty.
I also understand that Kury makes a PR21W red single filament light which could be used. But understand that the LEDs would be brighter. Can anyone confirm the difference in the brightness between the Kury bulb and good quality LEDs. I realize that would be a very generalized comparison due to different LEDs, etc.
Thanks.
__________________
2007 1800TT2, Cobra Fatties
Sealion50 is offline   Reply With Quote
clearance
Old 2 Weeks Ago   #2
1800 spec 3
1800 spec 3's Avatar
Default
Check out "Custom Dynamics"-- they got everything
__________________
"There is no alarm clock that beats chrome in the morning"2006 1800C spec 3 Hard Krome Strippers, Corbin, PCIII, Hypercharger, Desmog, Woody's fairing, BDs Custom paint, Alpine sound, Barons X Bars
1800 spec 3 is offline   Reply With Quote
Old 2 Weeks Ago   #3
Sealion50
Junior Member
Default
Thanks. Still looking for anyone that can give me a brightness comparison between the Kury red single filament bulb and decent red LEDs when used with the Kury RTB. I am wanting to install which ever gives the most brightness, and greatest visibility.
__________________
Old 2 Weeks Ago   #4
scribe5
Default
I run the RTB and use the Custom Dynamics red LEDs and they are really bright...brighter than the filament
__________________
Bikes I've owned since 1967: Bridgestone 50, Honda 90, Honda 305 Scrambler, 1972 Harley Sportster, Yamaha 650, Kawasaki 900 Z1a, Yamaha Venture-1982, Yamaha Venture Royale-1992, Yamaha 650 V-Star, Honda 2003 VTX1800c.
scribe5 is offline   Reply With Quote
Display Modes
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
