VTXOA
Go Back   VTXOA > VTXOA Message Boards > VTX 1300 Riders Board
Notices
VTX 1300 Riders Board Tips, Tricks, Mods, Maintenance and General VTX 1300 chat on this board.
Thread Tools Display Modes
Old 05-13-2009   #1
diehard2006
Default flashers
i am looking for something to make all 4 signals flash at once is there such a thing??
__________________
09 vtx 1300C, blue L.E.D.s
diehard2006 is offline   Reply With Quote
Old 05-13-2009   #2
footprintsinconc
footprintsinconc's Avatar
Send a message via Yahoo to footprintsinconc
Default
here is a link that shows how to get a four way flasher going:
http://www.vtxcafe.com/showthread.php?t=22585
but check this link out too, it has a lot of interesting reference for our 1300:
http://www.vtxcafe.com/showthread.php?t=21645
__________________
21" Fats Memphis Shades, V&H Bigshots, AB neck bearings, Jeff's Power Box, Matejj's Driving Lights, VTX1300Retro's Backrest Plate, Glen's CPR, Drive Shaft Cover, CustomCruiser 2.5" Headlight Extension, Ultimate LowRider w/ backrest, 150mm Avon Venum Radial FT, Darkside CT General Grabber 205-70R15, Stebel Twin TM80 Magnum Horns ....& more to come
footprintsinconc is offline   Reply With Quote
Old 05-13-2009   #3
xblue
xblue's Avatar
Default
Look at this also
http://glensvtxgarage.com/turnsignal_beeper.html
__________________
Ride Safe
06 1300R Blue
xblue is offline   Reply With Quote
Old 05-13-2009   #4
Football_Bill
Football_Bill's Avatar
Default
Originally Posted by xblue View Post
Super easy to install. I didn't use the included wire clips, I soldiered them myself, still took less than 30 minutes.
One oddity, which would probably happen no matter how you do it, with the bike on, all four flash when activated, with the bike off, only the rear two flash, but I think that has to do with the front signals also being running lights, at least on my scoot.
I would go with Glenn just for the fact of using a tried and true product instead of just hacking your wiring.
Football_Bill is offline   Reply With Quote
Old 05-14-2009   #5
dearsleigher
dearsleigher's Avatar
Default
Thanks for all the support.
Enjoy your ride.
Glen
__________________
www.glensvtxgarage.com
dearsleigher is offline   Reply With Quote
Old 05-14-2009   #6
footprintsinconc
Default
Originally Posted by Football_Bill View Post
One oddity, which would probably happen no matter how you do it, with the bike on, all four flash when activated, with the bike off, only the rear two flash, but I think that has to do with the front signals also being running lights, at least on my scoot...............
glen,
is that correct, only the rear two are on when the ignition switch is off? if i want to get it so that all 4 blink with the ignition switch off is it possible? if not, why.
thanks,
__________________
Old 05-14-2009   #7
dearsleigher
Default
Originally Posted by footprintsinconc View Post
glen,
thanks,
The design is to have all four flashers working. What year and model bike does Football Bill have?
Glen
__________________
Old 05-14-2009   #8
traildad
Member
Default
Hey Glen,
Will your flasher work with LEDs in the turn signals sockets? Is this a digital flasher unit or one that needs to see current? The reason I ask is I am planning to change my front and rear turn signals (and add running lights) with LEDs using the OEM sockets and wiring loom.
Mike
__________________
07 VTX 1300S
04 KTM 450 EXE (woods weapon)
06 Shadow Areo 750 (wife's bike)
traildad is offline   Reply With Quote
Old 05-14-2009   #9
dearsleigher
Default
Originally Posted by traildad View Post
Hey Glen,
Mike
My flashers need current. 2 blub minimum.
Enjoy your ride.
Glen
__________________
Old 05-20-2009   #10
Football_Bill
Default
Glen
It is an 06 VTX1800F. Only variation from the directions I did was to splice and solder the wires instead of using the wire clips. All four flash when the key is in the "on" position, but when I turn the bike off and engage the flashers, only the rear two flash. That works for me, but just wanted to point it out, I bought the 4 way for runs, if I ever am on the side of the road, at least the rear two facing oncoming traffic will be working.
Old 05-20-2009   #11
jpshaver
Junior Member
Default
Great post, I was wanting to do this soon.
jpshaver is offline   Reply With Quote
Display Modes
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
