Hi Everybody! - Page 2 - VTXOA
 7Likes
post #11 of 18 (permalink) Old 08-09-2019, 01:50 PM
If they rattle, then the bushings are worn out. Contact Kuryakyn for parts to fix it as it should make no noise
post #12 of 18 (permalink) Old 08-09-2019, 01:54 PM
P/N Description UOM Price
9332 Pro-Series Butterfly Shaft Caps with Screws, Washers, Bearings, & Spring SET $17.99
ADD TO CART
https://www.kuryakyn.com/products/90...s-hypercharger
I believe those are the parts you need, call to and ask to be sure
post #13 of 18 (permalink) Old 08-09-2019, 09:08 PM Thread Starter
drperry's Avatar
It's constantly opening and closing from 1/4 open... I probably have a vacuum leak going to the thing, lol. It felt solid when I tried wiggling by hand, but I'll look at i5 closer, thanks!
Sent from my SM-G965W using Tapatalk
drperry is offline
post #14 of 18 (permalink) Old 08-10-2019, 11:07 AM
Check teh vacuum line that's hooked into the Hyper. If there is a check valve on that vacuum line, you have to remove it. It needs a solid line from the canister to the Hyper, no check valve or it won't work as it should. It should open and close with the throttle like on a old school funny car
post #15 of 18 (permalink) Old 08-10-2019, 12:44 PM Thread Starter
drperry's Avatar
Will double check it, thanks! For the most part it works, but at 30 - 40MPH in 3rd gear it flaps like crazy
drperry is offline
post #16 of 18 (permalink) Old 08-25-2019, 09:31 AM Thread Starter
drperry's Avatar
Well, there goes any plans for awhile... Two months into ownership, and head gaskets need to be done
drperry is offline
post #17 of 18 (permalink) Old 08-25-2019, 06:33 PM
Xerothermic's Avatar
That's a lot of bugs on that ride. All from one ride or are you continuing the collection?
Just dickin' with you.
drperry likes this.
When you are young you want what everyone else has . . when you are old you want what everyone else had.
D. Lee Schulte I ride a Honda because Toyota doesn't make motorcycles. 2005 VTX 1800N3 (black)
Xerothermic is offline
post #18 of 18 (permalink) Old 08-25-2019, 08:09 PM Thread Starter
drperry's Avatar
100km worth of bugs
drperry is offline
