Ideas needed - Page 2 - VTXOA
post #11 of 13 (permalink) Old 05-16-2012, 07:58 AM Thread Starter
t-dog's Avatar
Originally Posted by Taffer View Post
How old is your battery? I had similar problems last year....lights, everything works, but nothing on the starter. (this is after I hooked the battery to a charger overnight) Was ready to clean/replace switch. Then I talked to someone at Southeast and they told me this could be the battery...that everything will work, but if there is not enough voltage/current the starter won't turn AT ALL. Replaced battery with glass matt unit from Fleet Farm for $80 and all is good to go. If you battery is more than 3-4 yrs old, maybe try this first.
Thanks Taffer.....replaced the battery last year and I have good voltage so I'm leaning towards the switch
t-dog is offline
post #12 of 13 (permalink) Old 05-18-2012, 05:01 AM
Brycesdad's Avatar
Tim,
there is two large fuses under the left side cover. large wires going to it with fuse inside white cover. I had this happen once. Good Luck!
2008 BMW R1200RT
2001 BMW K1200LT gone
2002 VTX1800R gone
Ironbutt Association Member
Brycesdad is offline
post #13 of 13 (permalink) Old 05-18-2012, 01:32 PM
Smoken'JOE's Avatar
Under left side cover there is the starter relay. Behind the relay is a white plug with red wires. Pull plug apart and see if anything is burnt.
B.F.L............W.I.V.O.
Getting old is not for sissy's
PLEASE DON'T TEXT AND DRIVE!
Smoken'JOE is offline
