Those w/fairings-Speaker ?? - Page 2 - VTXOA
post #11 of 21 (permalink) Old 11-15-2010, 11:12 AM
I got the Hogtunes set up much better than the stock harley speakers, I forget what size speakers they are but they are not marine grade and I have had no problems whatsoever.
In a world filled with shades of grey there is one absolute... it is impossible to pick up a turd by the clean end.
locodude is offline
post #12 of 21 (permalink) Old 11-15-2010, 12:34 PM
Gonzo1970's Avatar
Send a message via AIM to Gonzo1970
As long as the speakers dont have paper in them, you should be ok.
I run Sony Xplod's - Not listed as "Waterproof" but have been completely soaked, no problems..
However, the Polk 521's are pretty damn incredible speakers.. If I need to change, Ill be going with them for sure. I just happened to come across these Sony's for nothin..
-Gonz
Harley Owners Need Dependable Alternatives
"Dear Fox News: I am writing today to request that you add a laugh track to your coverage to properly identify it for the comedy that it is.
Also, clown noses for the reporters would be nice."
Gonzo1970 is offline
post #13 of 21 (permalink) Old 11-15-2010, 03:42 PM
Glenn W's Avatar
+1 to the Polks mentioned above, and I'd also recommend the Memphis Car Audio offerings if they'll fit. The PR series is a nice compromise between sound and price tag.
Glenn W is offline
post #14 of 21 (permalink) Old 11-15-2010, 06:48 PM Thread Starter
TCB
Mad Hatter
TCB's Avatar
I am now looking at the Kicker PS5250's.. What do ya all think??
I Am A Down and Out "CHROM WHORE"
Keep it Up Strait
TCB is offline
post #15 of 21 (permalink) Old 11-15-2010, 08:27 PM
Glenn W's Avatar
They look like a well made speaker but they are 2 ohm, to match the Harley Harmon-Karden radios. They might not play well with a 50w/ch (15-18RMS) head unit because they will have quite a draw at top volume. Personally, I'd stick with 4 ohm choices if that's what the Victory radio was designed for. If you are going to add an amp then you'd just want to make sure the amp was designed & rated to be stable down to 2 ohms.
Glenn W is offline
post #16 of 21 (permalink) Old 11-15-2010, 08:34 PM Thread Starter
TCB
Mad Hatter
TCB's Avatar
The Vic uses a 2 ohm like HD.. As for an amp, still not sure I will go that route. The local Audio stor I go to said to get these 2 ohm speakers. He said I would get better sound and responce than if I went to the 4 ohm ones. And he knew I was thinking of an amp as well..
Keep it Up Strait
TCB is offline
post #17 of 21 (permalink) Old 11-15-2010, 09:01 PM
MR VTX's Avatar
What did you pay for the Hogtunes setup?
MR VTX is offline
post #18 of 21 (permalink) Old 11-15-2010, 10:15 PM
Glenn W's Avatar
That sounds like a great choice then if they fit. The H-D radio is a little on the under-powered side so anything designed for the stock H-D radio will probably be done with efficiency in mind, to get max volume out of it.
Glenn W is offline
post #19 of 21 (permalink) Old 11-16-2010, 08:22 AM
bluto's Avatar
Check the depth you have available. There has been a few discussions on the Vision-riders forum about changing speakers and depth has been an issue for some of the "better" speaker options. I simply (and cheaply!)installed some baffles and that really helped the stock speakers.
[SIGPIC]https://www.vtxoa.com/forums/image.php?type=sigpic&userid=324&dateline=12263298 49[/SIGPIC]
bluto is offline
post #20 of 21 (permalink) Old 11-16-2010, 11:22 AM Thread Starter
TCB
Mad Hatter
TCB's Avatar
ThankX, no issue with depth, I can fit the KS or SP speaker, no problem..
What I am really wanting to know, will I be better with the more expensive SP over the KS?? SP has a 2ohm and KS 4 ohm
PS about 200.00 and KS 80.00
Keep it Up Strait
TCB is offline
