Fumoto Oil Drain Valve - VTXOA
 14Likes
post #1 of 23 (permalink) Old 05-04-2019, 03:04 PM Thread Starter
icopus's Avatar
I was just wondering what your thoughts are on this. Seems like a very good idea for both cars and motorcycles. But maybe y'all know something I don't? Your thoughts are appreciated.
The Fumoto Valve - https://www.fumotooildrainvalve.com/...modelId=589220
A Video -
steveroy60 likes this.
"It's my life and I'll get pissed if I want to." - icopus
"Just because your voice reaches halfway around the world doesn't mean you are wiser than when it reached only to the end of the bar." - E.R. Murrow
icopus is offline
post #2 of 23 (permalink) Old 05-04-2019, 03:11 PM
Great way to rip your oil pan a new hole where the plug used to be when you go over a speed bump. Unless the oil drain was on the side of the block and does not hang lower than the frame, no way. Tthe car in the video will have a skid plate to protect it, your bike will not
icopus, TennX, chuck_VTX F and 2 others like this.
post #3 of 23 (permalink) Old 05-04-2019, 03:17 PM
ervin260's Avatar
Brilliant idea, but non of motorcycle and car companies had this idea before? I think, there is a reason, why they do not use it.
(Edit:You can find factory drain valve on the radiator of many cars, but not on the oil pan.)
BTW, you need two of them for the VTX.
icopus, Harkon and steveroy60 like this.
VTX 1800/280
You can say anything stupid. It's the internet. No real consequences for YOU.
ervin260 is offline
post #4 of 23 (permalink) Old 05-04-2019, 03:18 PM Thread Starter
icopus's Avatar
Thanks for the replies. I still may get one of the cages, though.
icopus is offline
post #5 of 23 (permalink) Old 05-06-2019, 06:11 PM
JPT
JPT's Avatar
I had one on a previous motorcycle. It is all about where the drain plug is, and how protected it is.
I havenít spent enough time under my VTX yet to determine if it will fit and I feel safe with the Fumoto yet. If I do, I will have it at least on the rear drain. This is where most of the oil comes out anyways.
I have had one one previous cars for almost 100k miles, not a drop of oil leaked out of the valve.
2009 VTX1300R
JPT is offline
post #6 of 23 (permalink) Old 05-07-2019, 12:09 AM
Super Moderator
vtox's Avatar
My family has them on all of our cars, and on some that we no longer have. Most of our cars have had a plastic shield that sits lower than the pan, and the various valves can be ordered with no nipple, a short nipple, or a long nipple, for cars with various plug orientations. They do not necessarily sit any lower than the pan or factory plug. And I never have to worry about over-tightening the drain plug. My daughter changes her own oil, in part because of the plug on her Outback.
M8 Fat Boy S Bonneville Salt Pearl
vtox is offline
post #7 of 23 (permalink) Old 05-07-2019, 12:34 AM
Thank you Ervin260! I've owned my 1300 for a year and only changed the oil once. I pulled the rear drain plug not knowing there was a front drain plug. I'm getting ready to change the oil for a Tennessee trip and really glad that you noted the two plugs! Now I know!
ervin260 likes this.
2007 VTX1300C
unit505 is offline
post #8 of 23 (permalink) Old 05-07-2019, 09:01 AM
shadango's Avatar
I have toyed with the idea once or twice over the years.
But in the end, clearance issues and security issues sway me.
Consider that this gizmo makes it easy for anyone to drain their....or your....oil without tools.
If you have jokester friends or any enemies, just saying....LOL
Its easy enough to break out a wrench for as many times a year I do oil changes.
Harkon and rangers4u like this.
2005 1800R (Ol' Ruby)
RIP: 2005 1300R (Ol' Silver)
Courtesy and Tolerance.........Courtesy begets Tolerance and Tolerance begets Courtesy.
AKA -- "Do Unto Others"
shadango is offline
post #9 of 23 (permalink) Old 05-16-2019, 06:34 PM
Lou_VTX's Avatar
THAT ^^^^
The valve has a MUCH bigger profile than a flat drain plug. If the valve is exposed, it can be snagged by something, broken off or just bent to create a small enough leak to trash your engine.
I can see a big benefit on vehicles where you change the oil a lot. But on our bikes, not so much. Especially since you'd need two for the two drain plugs.
Just my $0.02.
VTX 1800C
Lou_VTX is offline
post #10 of 23 (permalink) Old 05-16-2019, 07:04 PM
Super Moderator
vtox's Avatar
They also now come with a little plastic clip that slide around the valve body and the lever and snaps into place. It keeps the lever from being pulled or pushed out of its locked position.
But as others have said, you gotta have the clearance and have it sit in a place that is protected.
vtox is offline
