1 day to get rims off, take the tires off, rotors off and remove bearings.
6 days to get the wheels back. I then decided to take the new rims, new tires, and new bearings to the local shop to have pressed and mounted.
New tires are metezler 880 front. Goodyear assurance 205/55/16 on rear. Note: tires are not balanced at this point. PSI 35 rear. 40 front
1 day to moly paste axel, rear gear, loctitie rotor bolts, and put both tires on.
Note: follow all directions provided on
www.bareasschoppers.com
Note: the rear tire and rear calaper bolts gave me the most trouble.
On the test drive I completed my very first figure 8 on the road. The darkside makes it easier to turn. Feels a little like floating?.... So far darkside is the BOMB. I'm also lower of the ground with a smaller rear tire. So I got that going for me.
I noticed a little bounce while slowing down. Do I need dyno beads to balance?
Front rotor seems to be rubbing the break pad only on right side. What's the easiest fix? Sand paper?
