bike won't shut off - VTXOA
post #1 of 43 (permalink) Old 07-13-2009, 01:39 PM Thread Starter
bike won't shut off
Hey guys and gals I'm new at this, so bare with me. Been owning my 02 vtx C model since 02 and have close to 40,000 miles. About a month ago i was getting ready to ride, but looked at all the clouds here in sunny florida and decided to put it back in the garage, but when i went to shut it off the bike kept wanting to crank even when i turned the key off. I disconnected the battery and left it for a couple of days and then went back and re-connected the battery. Everything must have reset and had no problem until yesterday when it did it again. I tried tapping on the starter and the switch to see if maybe something was stuck and once again I had to disconnect the battery. Can anyone tell me what the heck the problem may be. Much appreciated and ride hard, but safe.
ccoop106 is offline
post #2 of 43 (permalink) Old 07-13-2009, 01:52 PM
Knight's Avatar
My guess is your starter switch may be fried
[SIGPIC]https://www.vtxoa.com/forums/picture.php?albumid=211&pictureid=950[/SIGPIC]
Knight is offline
post #3 of 43 (permalink) Old 07-13-2009, 02:11 PM
snush's Avatar
The solenoid switch is bad. It's located behind the left side cover.
SNUSH
I don't sweat the petty things,But I do pet the sweaty things.
snush is offline
post #4 of 43 (permalink) Old 07-13-2009, 03:19 PM
coltergeist's Avatar
Yep. starter solenoid. replace with Honda for $$$$ or pull old one and go to NAPA or AutoZone or similar and match up one from a lawn tractor.
PGR - LA State Captain - 03 1800 Retro, red, Mustang seats, ISO grips, V & H Bigshots, de-smog and Pair block by Bareass, eng. guards, CW sissy bar and luggage rack, HitchDoc trailer hitch, 9/30/07 new Quadzilla fairing, 5/13/11 Darkside GYTT and HID headlight.
coltergeist is offline
post #5 of 43 (permalink) Old 07-13-2009, 04:21 PM
GTvtx's Avatar
Don't assume that the push button switch on the handle bar is good.
Check it with a tester before u put it all back together.
Its going to be the Solenoid or the push to crank button.
GT
GTvtx is offline
post #6 of 43 (permalink) Old 07-13-2009, 04:53 PM
If it is still cranking after you turned off the engine that means the starter was engaged (turning) while the bike was previously running = not good for the starter. Listen closely after it starts - you can hear the starter turning over, behind all the engine/exhaust noise (it'll sound "different").
If it does happen again, tap on the solenoid (behind left side cover) with a wrench - it'll likely break the contacts (that are internally stuck) and it'll stop turning over. This is a lot faster than trying to disconnect the battery.
The solenoid is getting stuck, in the first place, because the starter is drawing too many amps. This can be caused by a weak battery as the starter draws down the battery voltage, the amps soar high enough to 'fuse' the internal contacts together in the solenoid. Poor battery connections can contribute/cause this also.
Although a new solenoid may stop this for a while because the contacts are fresh (smooth and clean). The problem will likely return until the root cause is corrected (new battery w/ cleaned, tight connections).
I had the same problem and dicked around with everything (soldered all wire connections, temporarily doubled up on wire cables, added grounds, installed heavy duty truck solenoid, swapped out a new starter, cleaned all connections, etc.) before coming to this conclusion. Nothing 'solved' my problem until I replaced the 1 year old battery, and the problem stopped. If your problem persists -- well, you know my advice.
Good luck.
Todd
Todd2 is offline
post #7 of 43 (permalink) Old 07-13-2009, 05:23 PM
VTX-1800_IJzervreter's Avatar
Sticking contacts in the starter relay
I went exactly the same route as Todd2. After changing the starter motor I finally bought a new starter relays and a good battery. No damage to the Starter Sprag Clutch. Problem solved.
02VTX-1800C, Hondaline Custom Windshield, Deluxe Backrest with Rear Carrier & Trim, Roadhouse Shorty Slip-on, PCIII, K-Drive Saddlebags, HAC Radiator Cover, NC Paladin Bars, Custom Wings Spotlights with 2 specially made ss mount brackets, Zodiac Mini push button swith and Pulse-Relay, Ledrie Cylinder type suitcase, Rivco Electric Horns with Relay, Highway Hawk Licenseplate holder, Prog Fr.Springs
VTX-1800_IJzervreter is offline
post #8 of 43 (permalink) Old 07-13-2009, 05:29 PM
Horror Show's Avatar
Use caution when replacing your starter solenoid with a car solenoid. Gasoline engine solenoids from cars can have an internal wiring difference that makes them unacceptable. Use a Diesel engine solenoid for your replacement. See my post on this topic "Darkside Starter Solenoid". https://www.vtxoa.com/forums/showthread.php?t=227486
[SIGPIC][/SIGPIC]2003 VTX 1800C: Stock with a few add-ons.
Horror Show is offline
post #9 of 43 (permalink) Old 07-21-2009, 10:56 PM Thread Starter
Hey thanks for the replies I received on my starter problem.
ccoop106 is offline
post #10 of 43 (permalink) Old 07-22-2009, 10:06 AM
I replaced the stock solenoid with a Standard Ignition SS608 solenoid. Its a heavy duty model, made for some GMC and Dodge V-8 trucks. I did have to modify the wiring slightly to match up, but its been working great for years now. I just chose a BIG solenoid that had two connections (not 3 or 4) for the small wires (and of course the two large connections for the battery cables). This didn't create any problems for me.
Todd
Todd2 is offline
