Looking for new bars and foot pegs - VTXOA
post #1 of 11 (permalink) Old 06-08-2016, 05:28 AM Thread Starter
jay1800f's Avatar
Talking Looking for new bars and foot pegs
Just got my 08 1800f.
I've been looking for options for bars for my f and it seems a little odd. I'm not sure if I'm not looking the right spot or if I'm blind or what. But im not seeming to find a decent selection of bars that "fit" an F model for the style i want.
I simply am looking for a 1300c style bar. No extra rise or stretch is needed. just that style and possibly black if there are some available somewhere but i havent been able to find them it seems.
Anyone know if the 1300c bars will work for an 1800f? If not some with relatively close if not the same dimensions that are different brand? maybe a little thicker?
When i bought the bike it came with what looks like Cobra footboards. Not my style. However, upon looking at the brackets and everything briefly before i got shipped offshore, due to not having time to look or inspect them enough to be able to come up with a solution, i have been looking for footpegs and or forward controls for an 08 1800f and im finding some, however the issue is im not sure if the bracket on the floor boards are all one piece and not finding aftermarket ones that come with new brackets to install with the controls for shifter, linkage, rear brake pedal etc. I wouldnt mind going back to OEM i just dont really care for the floorboards and would rather have my feet at the OEM position or similar, just more forward and than the boards provide.
Any input would be appreciated!!
jay1800f is offline
post #2 of 11 (permalink) Old 06-08-2016, 09:46 AM
Yep, bars, especially custom styles, made to fit metric bikes riser spacing, are very hard to find. Now, you can get almost any bars in 1 inch diameter to go inside your bar clamps but when you want one pice bar/riser combo this will be your highest hurdle. So much so that I gave up and had a set made for me and then painted to match my VTX.
post #3 of 11 (permalink) Old 06-08-2016, 10:44 AM
jammerwalker's Avatar
Another alternative for handlebars is to get an adapter that fits on top of the top triple tree, and then you can use HD spaced bars, which are much easier to find AND cheaper (usually). I've seen the adapters for the VTX for about $80 on eBay. Otherwise, like @Chicago-Spike said, the ones made for VTXs are hard to find and/or expensive, unless you JUST change the bars and not the risers.
As for the floorboards, you might check to see if someone with footpegs wants to 'swap' the whole thing. I suspect someone will like and want those floorboards.
(((=-JammeR-=)))
jammerwalker is offline
post #4 of 11 (permalink) Old 06-08-2016, 02:55 PM
primus's Avatar
Have a look at the Baron Extreme bars. They share some similarities to the 1300C and are thicker at 1.5".
To my eyes, they are the only bars that look right on an F
'03 1800R
primus is offline
post #5 of 11 (permalink) Old 06-09-2016, 12:52 AM
Just got these drag specialties and love the look, pullback, and just about everything about them.
yellowcolorado30 is offline
post #6 of 11 (permalink) Old 06-09-2016, 10:31 AM Thread Starter
jay1800f's Avatar
I like those. Just noticed your foot controls. Which ones do you have on there? are they oem? if not did they come with brackets and linkages and reservoir? want to trade for my floor boards!?
I saw some on *********.com that just are the bars and no risers that look like the 1300c bars beyond the risers and just attach in the risers. I may try those and see...
jay1800f is offline
post #7 of 11 (permalink) Old 06-09-2016, 10:43 AM
kimathigs's Avatar
Hello All, I'm new to the board and just picked up my 08 VTX 1800F 2 weeks ago. I'm having similar bar issues and have been searching to no avail. The Baron Extremes that Primus showed above look great, but seem a bit straight to me. What is the arm position? I'm 6'3" tall. Primus, can you send the specs on your bar (Height and pull-back)? I would like to try to find something like the Bitwell Tracker Handle (check the link below) or something similar, but not sure how that would look and because of the 6.5 center width needed for the stock risers, finding a bar seems daunting without changing the risers.
http://www.cruisercustomizing.com/tr..._campaign=HTML
Any additional thoughts?
Thanks in advance.
kimathigs is offline
post #8 of 11 (permalink) Old 06-09-2016, 12:12 PM
That site is banned here and many other sites for poor business practices. It is to protect the members so buy there at your own risk
post #9 of 11 (permalink) Old 06-10-2016, 01:49 AM Thread Starter
jay1800f's Avatar
Ahhh understood, thanks for the heads up i appreciate it. maybe ill try to find them from somewhere else then. they are a straight drag style bar, 1" dia. with 18 degree bend i think they ll look rather smashing. We shall see.
jay1800f is offline
post #10 of 11 (permalink) Old 06-15-2016, 12:10 AM
primus's Avatar
Hi kimathigs,
The bars on my R are beach bars, but the dimensions on the Extreme bars are 33" width; 7-1/2" rise; 7-1/2" pullback.
The 1-1/2" diameter looks right at home on the big VTX and no triple tree adapters are needed for compatibility.
'03 1800R
primus is offline
