Think I blew Max up ! - Page 2 - VTXOA
 10Likes
post #11 of 39 (permalink) Old 09-27-2016, 08:43 PM
Did your oil pressure warning light come on when this first happened? I too am thinking of a kinked vent hose that caused excessive pressure in the lower half. Normally a seal would blow however, not a gasket.
Sojourner is offline
post #12 of 39 (permalink) Old 09-28-2016, 12:18 PM Thread Starter
Boyz312's Avatar
No lights or warnings. Funny thing is I checked the vent hose last week by blowing air into the hole of the air cleaner and could easily feel air coming out the deep stick hole. I do and have had a small oil leak coming from shifter which is why I checked it. Gona pull the cover this week hopefully. Where is the seal you speak of located ?
02' 1800C Illusion Blue, 62k miles, "Blue Max" Medallions,, MTC clutch, V&H Big Shots, PC III, K&N Filter w/ Custom VTX Cover, Ultimate Seats, Custom Radiator cover, Leather Bags, Tank Bib, Memphis Shade, Wolo, Gregg's Alarm, Progressive suspension F/R.
Boyz312 is offline
post #13 of 39 (permalink) Old 09-28-2016, 12:37 PM
The seal for the shift rod is usually the one to start leaking.
post #14 of 39 (permalink) Old 10-03-2016, 05:27 PM
Ever figure this out?
Charlie_C is offline
post #15 of 39 (permalink) Old 10-03-2016, 08:11 PM Thread Starter
Boyz312's Avatar
Haven't had time yet and quite honestly to depressed and afraid to see what I find. Plan on opening it up later this week if the hurricane doesn't interfere
Charlie_C likes this.
Boyz312 is offline
post #16 of 39 (permalink) Old 11-04-2016, 01:58 PM Thread Starter
Boyz312's Avatar
This is where I am, replaced the oil seal on shifter (shot) and replaced water hose and seal on back jug and now found another leak in the small pipe that goes between the jugs, so I'm ordering all new seals for water system just to be safe. BUT, here is my question. When I was adding water to the system, (before I found 2nd leak) water started coming out of the end of my exhaust from the front jug??? How is this possible. Water only, no oil or mix thank god. But this has me scratching my head. Any thoughts ?
Thanks
Boyz312 is offline
post #17 of 39 (permalink) Old 11-04-2016, 03:06 PM
Thanks
The only way that could happen is if there is a crack in the water jacket at the exhaust port. If it's also in the cylinder (the water would come out milky most likely), then a bad, leaking head gasket or water jacket failure in the head or cylinder. You would see water in the oil if this were the case.
When water was coming out of the exhaust, is it possible you were seeing condensation? OR was it definitely coolant?
I don't mean to scare you but;
As far as I know, there is no seal or gasket in this engine that will allow coolant into the exhaust port and not into the cylinder. That is all water jacket. Again, this is as far as I know, hoping I'm wrong on this.
Harkon is online now
post #18 of 39 (permalink) Old 11-04-2016, 03:14 PM Thread Starter
Boyz312's Avatar
There is no water in the oil, which is whats throwing me
Boyz312 is offline
post #19 of 39 (permalink) Old 11-04-2016, 05:29 PM
And you are sure it's coolant?
Gotta be from the exhaust port then. I've been on this forum for a while and I gotta tell you, I have never heard of such a thing with these engines. For the jacket to crack and leak, it must have run dry or something. Even then you'd expect to soften the rings and score a cylinder well before anything would crack.
Back in the day I had a Datsun and the head cracked. I ran the ever luvin' snot outta that engine, and I ended up with oil in the coolant, but not he other way around, so who knows.?
post #20 of 39 (permalink) Old 11-04-2016, 06:03 PM Thread Starter
Boyz312's Avatar
Did a little research and think I might have a blown head gasket as well . Like I mentioned earlier the water comes out the front jug exhaust pipe almost as fast as I pour it in. Gona do a compression test next.
Boyz312 is offline
