Radiator. Help - VTXOA
 4Likes
  • 3 Post By chuck_VTX F
  • 1 Post By Chicago-Spike
post #1 of 6 (permalink) Old Today, 02:14 PM Thread Starter
Radiator. Help
Hi there. I had a small leak coming from the front of the radiator hose where it meets the radiator down under the engine. I got a new hose and clamps and when removed notice that the bottom of the radiator connector to the hose is flat and not rounded. See picture. Thoughts? Do I put. New hose and problem goes away? Do I need a new radiator? Thanks.
File Type: jpg 7FF0A9F2-2D1D-4CCD-B375-F8E3C47208AC_1555265636136.jpg (207.8 KB, 7 views)
Irod2 is offline
post #2 of 6 (permalink) Old Today, 02:23 PM
my advice
remove the radiator..
go to a radiator repair shop..
have them re-round the port...
pressure check it..
reinstall it..
or just purchase a new one..
round hose.. round clamp.. not-round port.. guess what ?
post #3 of 6 (permalink) Old Today, 02:46 PM
Yep, it will leak again. Round up the pipe or buy a new rad
Harkon likes this.
post #4 of 6 (permalink) Old Today, 03:33 PM
If you try to round it yourself, do not pry on it. It will result in the point at which it attaches to the rad crack and fail. This point, in particular, can be rather fragile. If you go to your local plumbing store and get a PEX expander of the right size that should get it back to round without stressing the actual joint.
post #5 of 6 (permalink) Old Today, 03:55 PM
My guess is the saddle (tightening screw) formed it to that shape. Too large a clamp possibly.
Smaller clamp for smaller hose sizes.
Many have leaked from the reduction of clamping pressure after many years.
Usually a small amount of tightening will stop the leak.
I do not see any crushed area, should be good..
A few 1800 have developed leaks from stress fractures on the mounting flange to the radiator.
[B]2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back. 190,260 VTX miles
post #6 of 6 (permalink) Old Today, 05:31 PM Thread Starter
Thank you all. Yes the clamp was larger. Probably someone before me had it placed there instead. I got new ones and they are smaller. I was able to round it up a bit by using a socket, got it inside and wiggled it a bit. Seems much better now. I will try by placing the new hose with the new clamps. Thank you for the quick response everyone.
Irod2 is offline
