Rear flange bearing...how do I know - Page 2 - VTXOA
 33Likes
post #11 of 22 (permalink) Old 04-16-2019, 01:46 AM
enduro's Avatar
Not wheel bearings but rather flange bearings, on mine I saw mangled chunks of metal hanging in the grease when I changed the rear tire. No symptoms whatsoever. The pair of bearings are standard 6905RS bearings available anywhere. What it looked like cleaned up.
rangers4u and DrDolittle like this.
enduro is offline
post #12 of 22 (permalink) Old 04-16-2019, 08:20 AM
Originally Posted by Jon's1800VTXC View Post
I still do the remanufactured flanges - $175 exchange with refundable $65 core when I get the good core back
Jon
Send me a pm or email [email protected]
Thanks, Jon. I mislaid your contact info. Keep up the good work.
post #13 of 22 (permalink) Old 04-16-2019, 08:34 PM
Bilge's Avatar
So looking at the 2002-2008 VTX1800C/F service manual per page 14-7, the diagram at bottom indicates to replace 3 bearings
1. Final Driven Flange A bearing (6905 RS) with new O-ring
2. Bearing (6304UU)
3. bearing (20 x 47 x 20.6mm) - does this one have bearing number ??? with new O-ring
3. Dust seal
5. Brake Disc bolts
In post #11 above, Enduro mentions a pair of 6905RS bearings. Is that in a 1300 ?
That doesn't seem right according to 1800 pic attached.
Would it not be a good idea to buy double seal bearings to keep crap out ?
2005 Honda VTX 1800C1....5,700 miles;
1982 XJ750 Maxim, 18.5k miles, original owner
Bilge is offline
post #14 of 22 (permalink) Old 04-17-2019, 09:05 AM
2. Bearing (6304UU)
3. bearing (20 x 47 x 20.6mm) = 5204-2RS Sealed Ball Bearing, 20x47x20.6 (Double row)
3. Dust seal
5. Brake Disc bolts
1300 and 1800 Bottom right corner of the PDF shows cut open view,
you can see double 6905RS bearings.
I should have spent 30 minutes with a brake cylinder hone to get the light press in on the driven flange,
I used a 5/8" bolt and the bearing stack tilted some on install. I had to correct that. My vise would have done better,
How do you know if the bearings are GOOD? Put your finger(s) on the inner race and twist back and forth.
Remove flange, insert favorite finger into inner race, and spin the unit. Anything but smooth turning is bad...
2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back. 191,975 VTX miles
post #15 of 22 (permalink) Old 04-17-2019, 09:51 AM
Greg_PL's Avatar
Send a message via Skype™ to Greg_PL
hi all,
one of bearings when I did an ispection during tire chnage... the second was stacked. when riding there were no symptoms somethis was wrong.
Greg_PL is offline
post #16 of 22 (permalink) Old 04-17-2019, 10:55 AM
Bilge's Avatar
Hans & Feet,
Wow, not sure I know how to read that cut open view to see that....
So, please correct me if I am wrong here.....so to replace all bearings, it takes
2 6905-2RS or RS
1 6304UU
1 5204-2RS
What does the 2 stand for before the RS....just curious......
Thanks and much appreciated.....
Bilge is offline
post #17 of 22 (permalink) Old 04-17-2019, 11:04 AM
Ball Bearing nomenclature RS Rubber Shield or Rubber seal;RS is one side, 2RS both sides.
There is a more extensive list somewhere.
post #18 of 22 (permalink) Old 04-17-2019, 11:54 AM
Bilge's Avatar
Hans & Feet,
Most excellent explanation of cut-out view.....
That double row ball bearing here in San Diego from Kaman bearing - Koyo brand - $54 for one ......wow expensive.....however I have seen other brands for cheaper....
The 6905 & 6304 are reasonable.....
Bilge is offline
post #19 of 22 (permalink) Old 04-18-2019, 02:18 AM
Jon's1800VTXC's Avatar
When I build them I use 6905-2RS (double sealed) and yes there are 2 - stacked together. Look on Fiche for actual part #s of other bearings. I use a Honda bearing for the flange but it's not on the fiche. If you want the part # send me a pm
2. Bearing (6304UU)
3. Dust seal
5. Brake Disc bolts
Why is common sense not so common
Why doesn't P.E.T.A. ever attack a biker
Jon's1800VTXC is offline
post #20 of 22 (permalink) Old 04-18-2019, 03:28 AM
Honda 91051-KZ4-J21 BEARING, RADIAL BALL (69052RS) here you go if you Honda parts for the flange bearings
