Oil change - VTXOA
 12Likes
  • 1 Post By rangers4u
  • 3 Post By Harkon
  • 3 Post By chuck_VTX F
  • 2 Post By TennX
  • 2 Post By Hans&Feet
  • 1 Post By Lou_VTX
post #1 of 9 (permalink) Old 04-16-2019, 12:17 PM Thread Starter
Jim Preston Reams's Avatar
Oil change
03 VTX 1800 S ok I keep hearing that there are 2 drain plugs, to fully drain the oil ? Is this so ? Also do yall recommend full synthetic or regular oil, I'm a do it yourself guy, change my own oil in cars, but hadn't before on my bike, all you experienced people please help out a fellow biker. Thanks in advance.
Jim Preston Reams is offline
post #2 of 9 (permalink) Old 04-16-2019, 12:27 PM
YES. GET DOWN there and LOOK! Or at the very least FEEL. When I switched to Mobil 1 4T Racing synth 10W40, my shifting became noticeably smoother.
post #3 of 9 (permalink) Old 04-16-2019, 12:27 PM
Both drain holes are for engine oil. You do have 2 drain plugs, but only one filler, and that gets 10W40 motor oil. The gear case and crank case are shared. Others can elaborate on why 2 oil drain plugs, but do drain both for optimal results.
Not all bikes are the same so it's good you asked.
You can download a service manual here;
https://www.dropbox.com/s/k4lqm7s1xs...20ENG.pdf?dl=1
or here;
https://www.dropbox.com/s/v8prpalbv0...1800r.pdf?dl=1
And owners manual for a '02C;
https://www.dropbox.com/s/w7tz8duj4t...anual.pdf?dl=1
Some have a different requirement for engine and transmission, and some have engine, transmission, and primary, like my Harley.
post #4 of 9 (permalink) Old 04-16-2019, 12:37 PM
yep
2 drain plugs
download a HONDA service manual... its around here... FREE...
for ME.. full synthetic motor oil.. in everything since 1974....
remember NON Energy Conserving ... to save your clutch...
Harkon, rangers4u and DrDolittle like this.
post #5 of 9 (permalink) Old 04-16-2019, 12:42 PM
It’s been recommended that u straddle the bike and rock side to side to make sure empty.....good luck
chuck_VTX F and DrDolittle like this.
Phil...(71)ĒNobody told me I die at the endĒ
TennX is offline
post #6 of 9 (permalink) Old 04-16-2019, 01:03 PM
Front drain for the dry sump, about a cup of oil will drain out.
Rear drain is the reservoir which is below the transmission gears. About 3.5 to 3.75 quarts will drain out.
When the major oil has drained out, sit on the seat and hold the X upright to get more oil out.
Aluminum crush washers are recommended to be changed. I rarely change mine. Do not use Gorilla strength...Gut an tight...
I prefill my oil filters, less oil light time and oil is where it is needed quicker.
2005 1300c Red, Mustang seat, HK 2.5 straights. Leds for safety-front & back. 192,882 VTX miles
post #7 of 9 (permalink) Old 04-16-2019, 03:32 PM
Lou_VTX's Avatar
Originally Posted by Hans&Feet View Post
Gut an tight...
I think you meant the German precision torque spec "guten tight".
FWIW, punch a hole in the bottom of the filter and let it drain out at the same time so that there is no mess when you unscrew it.
Here are the illustrations with location of the drain plugs and the filter itself:
VTX 1800C
Lou_VTX is offline
post #8 of 9 (permalink) Old 04-16-2019, 03:42 PM
Yes you have 2 drain bolts. I use T6 Rotella.
post #9 of 9 (permalink) Old 04-16-2019, 03:52 PM
Click here, from our How To board..... https://tech.bareasschoppers.com/eng...ngine-oil-vtx/
